SPAN-B2R-G18M-PN-PN-L1
    FESTO(费斯托)
    SMD
SPAN-B2R-G18M-PN-PN-L1 数据手册
Pressure sensor SPAN-B2R-G18M-PN-PN-L1 Part number: 8035545 Data sheet Feature Value Symbol 00995686 Certification RCM compliance mark c UL us - Listed (OL) CE marking (see declaration of conformity) As per EU EMC directive As per EU RoHS directive UKCA marking (see declaration of conformity) To UK instructions for EMC To UK RoHS instructions Certificate issuing authority UL E322346 Note on materials RoHS-compliant Measured variable Relative pressure Method of measurement Piezoresistive pressure sensor Pressure measuring range initial value -0.1 MPa Pressure measuring range initial value -1 bar Pressure measuring range initial value -14.5 psi Pressure measuring range end value 0.1 MPa Pressure measuring range end value 1 bar Pressure measuring range end value 14.5 psi Max. overload pressure 5 bar Overload pressure 0.5 MPa Overload pressure 5 bar Overload pressure 72.5 psi Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Inert gas Information on operating and pilot media Operation with oil lubrication possible Temperature of medium 0 °C ... 50 °C Ambient temperature 0 °C ... 50 °C Accuracy in ± % FS 1.5 %FS Repetition accuracy in ± %FS 0.3 %FS Temperature co-efficient in ± %FS/K 0.05 %FS/K Switching output 2 x PNP or 2 x NPN switchable Switching function Window comparator Threshold value comparator Auto difference monitoring Switching element function N/C contact/N/O contact switchable Max. output current 100 mA Short-circuit protection yes DC operating voltage range 15 V ... 30 V 10/20/22 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Reverse polarity protection for all electrical connections Electrical connection 1, connection type Plug Electrical connection 1, connection technology Connection diagram L1J Electrical connection 1, number of pins/wires 4 Electrical connection for input 1, connection pattern 00995428 Type of mounting Front panel mounting With thread With wall/surface bracket Mounting position Any Pneumatic connection External thread G1/8 Internal thread M5 Product weight 46 g Housing material PA-reinforced Materials in contact with the media FPM High-alloy stainless steel Display type Illuminated LCD Displayable unit(s) MPa bar inH2O inHg kPa kgf/cm² mbar mmHg psi Setting options Teach-in Via display and pushbuttons Protection against tampering PIN code Setting range threshold value 0 % ... 100 % Setting range hysteresis 0 % ... 90 % Degree of protection IP40 Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Suitability for the production of Li-ion batteries Metals with more than 1% copper, zinc or nickel by mass are excluded from use. Exceptions are nickel in steel, chemically nickel-plated surfaces, printed circuit boards, cables, electrical plug connectors and coils 10/20/22 - Subject to change - Festo SE & Co. KG 2/2
SPAN-B2R-G18M-PN-PN-L1 价格&库存
很抱歉,暂时无法提供与“SPAN-B2R-G18M-PN-PN-L1”相匹配的价格&库存,您可以联系我们找货
