SCM7B22
SCM7B22
    DATAFORTH(Dataforth)
    ISOLATED BIPOLAR V-OUTPUT MODULE
SCM7B22 数据手册
Isolated Process Control Signal Conditioning Products S C M 7 B SCM7B22 Isolated Bipolar Voltage Output Modules Description SCM7B22 voltage output modules accept input signals in the ± 10V range from the process control system. The signal is isolated, buffered, and filtered to provide a unity gain field voltage output Figure . Features These modules incorporate a five pole filtering approach to maximi e both time and fre uency response by ta ing advantage of both Thomson Bessel and Butterworth characteristics. One pole of the filter is on the process control system side of the isolation barrier four are on the field side. • Provides High-Level Output to ± 10V After the initial process control system side filtering, the input signal is chopped by a proprietary chopper circuit and transferred across the transformer isolation barrier, suppressing transmission of common mode spi es and surges. The signal is then reconstructed and filtered for field side output. Modules accept a wide 19 - 29VDC power supply range (+24VDC nominal). Their compact packages (2.13”x1.705”x0.605” max) save space and are ideal for high channel density applications. They are designed for easy DIN rail mounting using any of the DIN bac panels. • Accepts High-Level Input to ± 10V • 1500Vrms Transformer Isolation • Accuracy, ± 0.03% of Span Typical, ± 0.1% Max • ANSI/IEEE C37.90.1 Transient Protection • Output Protected to 120Vrms Continuous • Input Protected to ± 35VDC • Noise, 2mVp-p (5MHz), 1mVrms (100kHz) • 100dB CMRR • Easy DIN Rail Mounting SA S ertified • CE and ATEX Compliant 1500Vrms Isolation Barrier + 1 + LOAD – – 2 Surge Suppression Protection. and LPF (2 pole) Iso-Chopper II™ Amplifier Pat. Pending LPF (2 pole) LPF (1 pole) Input Protection 5 X 0 NC Field-Side –V 3 DC Supply D ia g r a m ©1995-2017 Dataforth Corporation, All Rights Reserved COM Process Control System-Side +V 7 0 VIN + – Backpanel Term Block F i g u r e 1 : S C M 7 B 2 2 B l o ck 4 For information call 800-444-7644 ISO9001:2008-Registered QMS DC Supply/ Oscillator 5 VS (19-29VDC) COM Isolated Process Control Signal Conditioning Products Typical❇ at and Ordering Information D Module Output Signal Range Drive apability Resistance Protection Continuous Transient Voltage/Current Limit SCM7B22 CMV (Input-to-Output) Continuous Transient CMRR (50 or 60Hz) 1500Vrms ANSI/IEEE C37.90.1 100dB Stability to Gain Output Offset Noise Peak at 5MHz B/W RMS at 10Hz to 100kHz B/W Peak at 0.1Hz to 10Hz B/W Frequency and Time Response Bandwidth, – 3dB NMR (– 3dB at 400Hz) Step Response, 90% Span Supply Voltage Current Sensitivity Mechanical Dimensions (h)(w)(d) Environmental Operating Temperature Range Storage Temperature Range Relative Humidity Emissions EN61000-6-4 Radiated, Conducted Immunity EN61000-6-2 RF ESD, EFT Input Range Output Range ± 10V ± 10V 120Vrms ANSI/IEEE C37.90.1 ± 12.5V, ± 40mA ± 10V ± 0.5nA min ± 35VDC (no damage) Linearity(2) SCM7B22 ± 10V ± 20mA Input Signal Range Bias Current Resistance Protection Accuracy(1) Model S C M 7 B Specifications S C M 7 B ± 0.03% ± 0.1% ± 0.01% ± 0.02% . Span typical, Span max Span typical, Span max ppm Span 2mV 1mV RTI(3) 400Hz dB per Decade above 1ms H 19 to 29VDC 16mA ± 0.0001%/ %V S 2.13” x 1.705” x 0.605” max (54.1mm x 43.3mm x 15.4mm max) to to 0 to 95% Noncondensing ISM, Group 1 Class A ISM, Group 1 Performance A ± 0.5% Span Error Performance B NOTES: ❇ ontact factory or your local Dataforth sales office for maximum values. Accuracy includes the effects of repeatability, hysteresis, and linearity. Linearity is calculated using the best fit straight line method. (3) RTI = Referenced to Input. Visit our website www.dataforth.com ©1995-2017 Dataforth Corporation, All Rights Reserved 7 1 ISO9001:2008-Registered QMS
SCM7B22
物料型号:SCM7B22
器件简介:SCM7B22模块接受来自过程控制系统的±10V范围内的输入信号,并提供统一增益的现场电压输出。信号通过隔离、缓冲和滤波处理,以最大化时间和频率响应。
引脚分配:文档中提供了SCM7B22模块的块图,包括输入保护、LPF(两极)、Iso-Chopper II™放大器、隔离屏障、输出保护等部分,但没有提供具体的引脚分配图。
参数特性: - 输入/输出范围:±10V - 驱动能力:±20mA - 连续保护:120Vrms - 瞬态保护:符合ANSI/IEEE C37.90.1标准 - 输入信号范围:±10V - 电阻保护:最小2MΩ,±35VDC(无损坏) - 共模电压(输入至输出):1500Vrms - 共模抑制比(CMRR):100dB - 准确度:典型值±0.03%的量程,最大值±0.1% - 线性度:典型值±0.01%的量程,最大值±0.02%的量程 - 稳定性:增益±35ppm/°C,输出偏移±0.001%量程/°C - 噪声:5MHz带宽下峰值2mV,100kHz带宽下均方根1mV
功能详解:SCM7B22模块采用五极滤波方法,结合Thomson(Bessel)和Butterworth特性,以优化时间和频率响应。输入信号首先在过程控制系统侧进行滤波,然后通过专有的chopper电路重建和滤波,以进行现场侧输出。
应用信息:SCM7B22模块适用于需要高通道密度的应用,设计易于DIN导轨安装。
封装信息:模块尺寸为2.13" x 1.705" x 0.605"(最大),适用于紧凑空间。
SCM7B22 价格&库存
很抱歉,暂时无法提供与“SCM7B22”相匹配的价格&库存,您可以联系我们找货
SCM7B22
