KDS U-M84WM84A-V2111-020
    LEUZE(劳易测)
    INTERCONNECTION CABLE
KDS U-M84WM84A-V2111-020 数据手册
Technical data sheet Interconnection cable Part no.: 50140303 KDS U-M84WM84A-V2111-020 Contents - Technical data - Electrical connection - Circuit diagrams Figure can vary Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 1/3 Interconnection cable • Part no.: 50140303 • KDS U-M84WM84A-V2111-020 Technical data Connection Mechanical data Connection 1 Type of connection Connector Thread size M8 Type Female No. of pins 4 -pin Version Angled Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Width across flats 9.6 mm Bending cycles 1,000,000 Piece(s) Environmental data Ambient temperature, operation, flexible use -10 ... 80 °C Ambient temperature, operation, stationary use -30 ... 80 °C Certifications Connection 2 IP 65 Degree of protection Type of connection Connector Thread size M8 Type Male Handle body material TPU No. of pins 4 -pin Encoding A-coded Customs tariff number 85444290 Version Axial eCl@ss 5.1.4 27279201 Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking eCl@ss 8.0 27279218 eCl@ss 9.0 27060311 eCl@ss 10.0 27060311 eCl@ss 11.0 27060311 IP 67 NEMA 6P Classification Cable properties Number of conductors 4 Piece(s) ETIM 5.0 EC001855 Wire cross section 0.34 mm² ETIM 6.0 EC001855 AWG 22 ETIM 7.0 EC001855 Sheathing color Yellow Shielded No Silicone-free Yes Cable design Interconnection cable Cable length 2,000 mm Sheathing material TPE Wire insulation SR-PVC Suitability for drag chains No Electrical connection Connection 1 Type of connection Connector Thread size M8 Type Female No. of pins 4 -pin Version Angled Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Connection 2 Type of connection Connector Thread size M8 Type Male Handle body material TPU No. of pins 4 -pin Encoding A-coded Version Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 2/3 Interconnection cable • Part no.: 50140303 • KDS U-M84WM84A-V2111-020 Circuit diagrams Wiring schematic 1 D 2 E 4 F 4 3 G 3 1 2 a Brown wire b White wire c Black wire d Blue wire Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 3/3
KDS U-M84WM84A-V2111-020 价格&库存
很抱歉,暂时无法提供与“KDS U-M84WM84A-V2111-020”相匹配的价格&库存,您可以联系我们找货
