KDS U-M124AM124A-T2104-010
    LEUZE(劳易测)
    INTERCONNECTION CABLE
KDS U-M124AM124A-T2104-010 数据手册
Part no.: 50140474 – KDS U-M124A-M124A-T2104-010 – Interconnection cable Technical data Connection Connection 1 Type of connection Connector Thread size M12 Type Female No. of pins 4 -pin Encoding A-coded Design Axial Connection 2 Type of connection Connector Thread size M12 Type Male Handle body material TPU No. of pins 4 -pin Encoding A-coded Design Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Cable properties Number of conductors 4 Piece(s) Wire cross section 0.82 mm² AWG 18 Sheathing color Yellow Shielded No Silicone-free Yes Cable design Interconnection cable Cable length 1,000 mm Sheathing material TPE Wire insulation PVC Suitability for drag chains Yes Mechanical data Width across flats 14.5 mm Bending cycles 1,000,000 Piece(s) Environmental data Ambient temperature, operation, flexible use -15 ... 90 °C Ambient temperature, operation, stationary use -35 ... 105 °C Certifications Degree of protection NEMA 6P IP 67 IP 65 Classification eCl@ss 8.0 27279218 eCl@ss 9.0 27060311 ETIM 5.0 EC001855 Leuze electronic GmbH + Co. KG, In der Braike 1, 73277 Owen Phone: +49 7021 573-0, Fax +49 7021 573-199 info@leuze.com • www.leuze.com We reserve the right to make technical changes • eng 2018-08-14 2/3 Part no.: 50140474 – KDS U-M124A-M124A-T2104-010 – Interconnection cable Electrical connection Connection 1 Type of connection Connector Thread size M12 Type Female No. of pins 4 -pin Encoding A-coded Design Axial Connection 2 Type of connection Connector Thread size M12 Type Male Handle body material TPU No. of pins 4 -pin Encoding A-coded Design Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Leuze electronic GmbH + Co. KG, In der Braike 1, 73277 Owen Phone: +49 7021 573-0, Fax +49 7021 573-199 info@leuze.com • www.leuze.com We reserve the right to make technical changes • eng 2018-08-14 3/3
KDS U-M124AM124A-T2104-010 价格&库存
很抱歉,暂时无法提供与“KDS U-M124AM124A-T2104-010”相匹配的价格&库存,您可以联系我们找货
