SME-10M-DS-24V-E-0,3-L-M8D
    FESTO(费斯托)
    Module
SME-10M-DS-24V-E-0,3-L-M8D 数据手册
Proximity sensor SME-10M-DS-24V-E-0,3-L-M8D Part number: 551367 Data sheet Feature Value Design for round slot Conforms to standard EN 60947-5-2 Symbol 00991619 Certification RCM compliance mark CE marking (see declaration of conformity) As per EU EMC directive As per EU RoHS directive UKCA marking (see declaration of conformity) To UK instructions for EMC To UK RoHS instructions Special features Oil-resistant Note on materials RoHS-compliant Halogen-free Application note Support / actuator-sensor overview "The right sensor for the actuator" Measured variable Position Measuring principle Magnetic reed Ambient temperature -40 °C ... 70 °C Repetition accuracy 0.2 mm Switching output Contact-based, bipolar Switching element function N/O contact On time ≤1.2 ms Switch-off time ≤1 ms Max. switching frequency 50 Hz Max. output current 300 mA Max. output current in mounting kits 50 mA Min. switching capacity AC 9 VA Max. switching capacity DC 9W Max. switching capacity DC in mounting kits 1.5 W Max. switching capacity AC in mounting kits 1.5 VA Voltage drop ≤1.5 V Short-circuit protection no Overload protection Not available Rated operating voltage DC 24 V Operating voltage range AC 5 V ... 30 V DC operating voltage range 5 V ... 30 V Reverse polarity protection no Electrical connection 1, connection type Cable with plug Electrical connection 1, connection technology M8x1 A-coded as per EN 61076-2-104 10/20/22 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Electrical connection 1, number of pins/wires 3 Electrical connection 1, type of mounting Screw-type lock Electrical connection for input 1, connection pattern 00991155 Connection outlet orientation Longitudinal Connector cable test conditions Flexural strength: as per Festo standard Test conditions on request Cable chain: 5 million cycles, bending radius 28 mm Torsional resistance: > 300 000 cycles, ±270°/0.1 m Cable length 0.3 m Cable characteristic Suitability for energy chains/robot applications Material of cable sheath TPE-U(PUR) Type of mounting Screwed tightly Can be inserted in slot from above Max. tightening torque 0.4 Nm Mounting position Any Product weight 6.7 g Housing material PA-reinforced High-alloy stainless steel Switching status indication LED yellow Ambient temperature with flexible cable installation -20 °C ... 70 °C Degree of protection IP65 IP68 LABS (PWIS) conformity VDMA24364-B2-L 10/20/22 - Subject to change - Festo SE & Co. KG 2/2
SME-10M-DS-24V-E-0,3-L-M8D 价格&库存
很抱歉,暂时无法提供与“SME-10M-DS-24V-E-0,3-L-M8D”相匹配的价格&库存,您可以联系我们找货
