RC-01W4121FT
RC-01W4121FT
    FH(风华)
    贴片电阻 0201
RC-01W4121FT 数据手册
GENERAL THICK FILM CHIP FIXED RESISTOR Miniature and light weight Suit for reflow and wave flow solder Stable electrical capability,high reliability Low assembly cost,suit for automatic SMT equipment Superior mechanical and frequency characteristics RoHS Compliant with RoHS directive Halogen f ree requirement R S 03 Product Code Rated Power Code Type Code 1003 F T Resistance Value Code Resistance Tolerance Code Packaging Style Code K T.C.R Code (E-24 Code Rated Power Series Code Type 01 C Normal Power Series Upgraded Power Series Three digits (E-24 series):The B 300 L 250 W 200 U 400 01005 0201 0201 02 0402 03 0603 05 0805 06 S Code Type Code 005 01005 Thick Film Chip Fixed Resistor ) Tolerance Code Packaging B 0.1% denotes number of zeros. (E-96 ) C 0.25% Four digits(E-96 series):The D 0.5% F 1% G 2% J 5% first two digits are significant Style figures and the third one T first three digits are Significant C 0402 0 K 100 W 200 should be expressed by "R". Example: U 400 C 0 K 100 L 250 1206 1210 1210 10 2010 12 2512 0603 0805 1206 1210 2010 2512 figures and the four one denotes number of zeros. R Decimal point 103 =10k (E-24) 1003=100k (E-96) 1R0 =1.0 (E-24) K 1 10% C Tape & Reel Case Ceramic Substrate Bottom Electrode Top Electrode Resistor Layer Primary Overcoat Secondary Overcoat Edge Electrode Barrier Layer External Electrode Dimensions(mm) Type L a t W b 01005 0201 0.40 0.02 0.20 0.02 0.13 0.03 0.10 0.03 0.10 0.03 0.60 0.03 0.30 0.03 0.23 0.03 0.15 0.05 0.15 0.05 0402 1.00 0.10 0.50 0.10 0.30 0.10 0.20 0.10 0603 1.60 0.15 0.80 0.15 0.40 0.10 0.30 0.20 0.25 0.10 0.30 0.20 0805 2.00 0.20 1.25 0.15 0.50 0.10 0.30 0.20 0.40 0.20 1206 1210 3.20 3.20 0.20 0.20 1.60 2.50 0.15 0.20 0.55 0.55 0.10 0.10 0.50 0.50 0.20 0.20 0.50 0.50 0.20 0.20 2010 5.00 0.20 2.50 0.20 0.55 0.10 0.60 0.20 0.60 0.20 2512 6.40 0.20 3.20 0.20 0.55 0.10 0.60 0.20 0.60 0.20 100 -55 70 : Operating Temperature Range: -55 ~125 Operating Temperature Range: -55 ~155 75 Percent Rated Load 50 25 0 -75 -50 -25 0 25 75 50 100 Ambient temperature( 125 155 ) 1 01005 0201 0402 0603 0805 1206 1210 2010 2512 Note 1 01005 0201 product be the same with curve 0402 0603 0805 1206 1210 2010 2512 be the same with curve . 2 70 ( ) Note 2 For resistors operated in ambient over 70 ,rated load (rated power) shall be derated in accordance with the above figure. 70 Rated Power at 70 Limiting Element Voltage Max. Overload Voltage (V) (V) (W) Type 01005 0201 0402 0603 0805 1206 1210 2010 2512 Normal Power Series Upgraded Power Series Normal Power Series Upgraded Power Series Normal Power Series Upgraded Power Series 1/32 1/20 1/16 1/16 1/10 1/8 1/4 1/2 1 / / / 1/10 1/8 1 /4 1/3 3 /4 / 15 25 50 50 100 200 200 200 200 / / / 50 150 200 200 200 / 30 50 100 100 200 400 400 400 400 / / / 100 300 400 400 400 / 1 2 Note Voltage of DC or AC RMS value. E= E= or Limiting element voltage whichever is lower. E Rated voltage(V) P Rated power(W) R Normal resistance( ) 2 GENERAL THICK FILM CHIP FIXED RESISTOR T.C.R(ppm/ ) Type 01005 10 100 1 0201 10 1M 1 0402 10 1M 0603 0805 1206 1210 2010 2512 Resistance Tolerance Resistance Range 1 10 1M 0.1% 0.25% 0.5% 1% 2% 5% 10% 300 300 300 R 100 / / / 300 R 1M / / / 250 250 250 250 R 10 / / / 400 400 400 400 200 200 200 200 400 400 400 400 R 1M / / R 10M / / R 10 / / / R 1M / / 100 or R / / / 400 400 400 400 10M / R 10 R 1M 100 R 10M / 200 / 100 or 400 400 400 200 200 100 or 200 100 or 400 200 100 or / 250 250 250 250 250 100 100 100 100 100 100 250 250 250 250 250 250 200 T.C.R(ppm/ ) Type 0402 0603 0805 1206 1210 2010 2512 Resistance Range 100 10 1M Resistance Tolerance 0.1% R 1M / R 1M R 10M / Solderability 95% 95% Cover Min Resistance to Soldering Heat No mechanical damage R (1.0%R+0.05 ) Substrate Bending Test No mechanical damage R (1.0%R+0.05 ) No mechanical damage No mechanical damage Rapid Change of Temperature 0.05 ) 0.5% 1% 0.05 ) 0.05 1% 0 0 0 0 0 0 0 0 (IEC 60115-1) Test Methods (IEC 60115-1) Specifications 01005: R (1.0%R Others: 0.1% 0.25% R (0.5%R 2% 5% 10% R (1.0%R 0.5% / 0 Item Shear Test 0. 5% ) IEC 60115-1 4.17 245 5 3s 0.3s. Lead-free solder bath at 245 5 IEC 60115-1 4.18 270 5 10s 1s. Lead-free solder bath at 270 5 IEC 60115-1 4.33 (Bending distance) 01005 3mm 0201 0402 0603 1206 1210 4mm 2010 (Duration):60s 5s. for 3s 0.3s. for 10s 1s. 0805 5mm 2512 2mm . IEC 60115-1 4.32 (Applying force):0201:2N 0402 1206 1210 25N 2010 2512 45N. (Duration):10s 1s. 0603: 5N 0805 9N IEC 60115-1 4.19 01005 0201 -55 (30 ) (5 ) 125 (30 ) 300 01005 0201 -55 (30min) normal temperature(5min) 125 (30min),300 cycles; 0402 0603 0805 1206 1210 2010 2512 -55 (30 ) (5 ) 155 (30 ) 300 0402 0603 0805 1206 1210 2010 2512 -55 (30min) normal temperature(5min) 155 (30min) 300cycles. 3 ; Continue Item (IEC 60115-1) Test Methods (IEC 60115-1) Specifications IEC 60115-1 4.8 +20 /-55 /+20 /+125 /+20 Within specified T.C.R T.C.R Short Time Overload No mechanical damage 01005: R (2.0%R 0.05 ) Others: 0.1% 0.25% 0.5% 1% R (1.0%R 0.05 ) 2% 5% 10% R (2.0%R 0.05 ) IEC 60115-1 4.13 2.5 ( ) 5 2.5 times rated voltage or max. overload voltage whichever is lower for 5 s. IEC 60115-1 4.39 Intermittent Overload Damp Heat, Steady State Endurance at 70 No mechanical damage R (5.0%R+0.05 ) No mechanical damage 01005: R (3.0%R 0.05 Others: 2.5 times rated voltage or max. overload voltage whichever is lower for 1s ON/ 25s OFF 10000 cycles. ) 0.1% 0.25% 0.5% 1% R (1.0%R 0.05 2% 5% 10% R (2.0%R 0.05 40 2 ,93% 3%RH,1000h,rated voltage or limiting element voltage whichever is lower for 1.5h ON/0.5h OFF. ) ) No mechanical damage 01005: R (3.0%R 0.05 Others: IEC 60115-1 4.25.1 2 1000 ( ) 1.5 0.5 70 2 1000h rated voltage or limiting element voltage whichever is lower for 1.5h ON/0.5h OFF. ) 70 0.1% 0.25% 0.5% 1% R (1.0%R 0.05 2% 5% 10% R (2.0%R 0.05 IEC 60115-1 4.24 40 2 93% 3%RH 1000 ) / ) No mechanical damage Endurance at Upper Category Temperature 01005: R Others: (3.0%R 0.05 ) IEC 60115-1 4.25.3 01005 0201 125 2 1000h. 0402 0603 0805 1206 1210 2010 2512 155 0.1% 0.25% 0.5% 1% R (1.0%R 2% 5% 10% R (2.0%R 0.05 ) 0.05 ) No mechanical damage Operation at Low Temperature 01005: R Others: (2.0%R 0.05 0.1% 0.25% 0.5% 1% R (1.0%R 0.05 2% 5% 10% R (2.0%R 0.05 ) ) ) 2 1000h. IEC 60115-1 4.36 -55 5 -55 5 , 1h without load rated voltage or limiting element voltage whichever is lower for 45min, 15min without load. IEC 60115-1 4.6 1000M Insulation Resistance Min Voltage Proof No breakdown or flashover Component Solvent Resistance No mechanical damage R (1.0%R 0.05 ) 83 90 Apply DC 100V 15V between substrate and terminations for 1min, then check insulation resistance. IEC 60115-1 4.7 Apply max. overload voltage of AC RMS at a rate of approximately 100V/s between substrate and terminations for 60s 5s. IEC 60115-1 4.29 (IPA) 23 5 Iso-propyl alcohol (IPA) Packaging see the 83-90 Page . 4 10 23 5 10h. PACKAGING AND PRECAUTION OF CHIP RESISTOR Chip fixed resistor C A B unit: mm unit: mm Thick Film Resistor and Thin Film Resistor Type 01005 0201 0402 0603 0805 1206 1210 2010 2512 A 0.17 0.23 0.45 0.80 1.05 1.90 2.00 3.50 4.80 B 0.60 0.84 1.45 2.50 3.25 4.50 4.60 6.50 7.80 Metal Foil Resistor Type C 0.22 0.38 0.60 0.95 1.40 1.75 2.70 2.70 3.40 0603 0805 1206 2010 2512 R003~R004 R005~R030 R003~R004 R005~R047 R003~R004 R005~R068 R003~R009 R010~R100 R002~R004 R005~R200 A 0.4 0.6 0.5 0.8 0.8 1.8 1.6 2.7 1.0 3.8 B C 2.8 1.0 3.2 1.4 4.4 1.8 6.3 2.9 8.0 3.4 Thick film chip network resistor A B Q1 Q2 Q3 Q2 Q3 Q2 Q1 RCMY08 / RCMT08 / RCML08 unit: mm A B Q1 Q2 Q3 RCMY08 0.30 0.90 0.20 0.20 0.20 RCMT08 0.38 1.60 0.40 0.20 0.30 RCML08 0.80 2.70 0.60 0.40 0.40 Type 83 Paper Taping 01005 0201 0402 RCMY08 RCMT08 For 01005 0201 0402 RCMY08 RCMT08 unit: mm Type A B W F E 01005 0.45 0.02 0.25 0.02 8.00 0.02 3.50 0.05 1.75 0.05 0201 0.70 0.10 0.40 0.10 8.00 0.20 3.50 0.05 1.75 0.10 0402 1.20 0.10 0.70 0.10 8.00 0.20 3.50 0.05 1.75 0.10 RCMY08 1.57 0.05 0.77 0.05 8.00 0.20 3.50 0.05 1.75 0.10 RCMT08 2.20 0.10 1.20 0.10 8.00 0.20 3.50 0.05 1.75 0.10 unit: mm Type P P0 P1 D0 T1 T 01005 2.00 0.05 4.00 0.10 2.00 0.05 1.55 0.02 0.17 0.02 0.31 0.02 0201 2.00 0.05 4.00 0.10 2.00 0.05 1.50 0.10 0.28 0.04 0.42 0.05 0402 2.00 0.05 4.00 0.10 2.00 0.05 1.50 0.10 / 0.42 0.05 RCMY08 2.00 0.05 4.00 0.10 2.00 0.05 1.50 0.10 / 0.60 0.10 RCMT08 2.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 / 0.60 0.10 0603 0805 1206 1210 RCML08: For 0603 0805 1206 1210 RCML08: 84 PACKAGING AND PRECAUTION OF CHIP RESISTOR unit: mm Type B A W F E 0603 1.85 0.10 1.10 0.10 8.00 0.20 3.50 0.05 1.75 0.10 0805 2.35 0.10 1.65 0.10 8.00 0.20 3.50 0.05 1.75 0.10 1206 3.50 0.20 1.90 0.20 8.00 0.20 3.50 0.05 1.75 0.10 1210 3.50 0.20 2.80 0.20 8.00 0.20 3.50 0.05 1.75 0.10 RCML08 3.50 0.20 1.90 0.20 8.00 0.20 3.50 0.05 1.75 0.10 unit: mm T Type P0 P D0 P1 Thick Film Resistor and Thin Film Resistor Metal Foil Resistor 0603 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.60 0.10 0.75 0.10 0805 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 0.95 0.10 1206 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 0.95 0.10 1210 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 RCML08 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 Embossed Taping 2010 2512 For 2010 2512 unit: mm W B0 A0 Type t E F 2010 5.50 0.15 2.82 0.15 12.00 0.10 5.50 0.10 1.75 0.10 0.25 0.05 2512 6.78 0.15 3.45 0.15 12.00 0.10 5.50 0.10 1.75 0.10 0.25 0.05 unit: mm K0 Type P P0 D0 P1 D1 Thick Film Resistor and Thin Film Resistor Metal Foil Resistor 2010 4.00 0.10 4.00 0.10 2.00 0.05 1.50+0.10/-0 1.50 0.10 0.84 0.10 0.84 0.10 2512 4.00 0.10 4.00 0.10 2.00 0.05 1.50+0.10/-0 1.50 0.10 0.81 0.10 1.00 0.10 85 Reel unit: mm M W 01005 0201 0402 0603 0805 1206 1210 RCMY08 RCMT08 RCML08 178 2.0 9.5 1.0 2010 2512 178 2.0 13.0 0.5 Type A B C D 12.5 1.5 2.0 0.5 13.0 0.5 21.0 0.5 58.0 2.0 15.5 1.5 2.0 0.5 13.0 0.5 21.0 0.5 57.0 2.0 T Packaging Quantity Tape & reel Packaging style W M Type Quantity(pcs) 178 178 01005 2.0 E-24 ( 0201 0402 RCMY08 RCMT08 20000 10000 9.5 unit 0.001 1.0 1.1 2.0 1.2 1.3 g Quantity 0.01 0.1 2010 2512 5000 4000 12.5 1 10 100 2.2 1.6 0.52.7 2.0 A 0603 0805 1206 RCMY08 RCMT08 RCML08 01005 0201 0402 50000 10000 2.0 1.5 1210 2010 2512 4000 0.5 1 ) 1.5 13.0 1.8 T 0603 0805 1206 1210 RCML08 1.0 E-24 series( 10 n Case 2.4 1k 10k 100k 1M 3.3 15.53.6 1.5 3.9 3.0 4.3 86 10M 100M 4.7 5.1 5.6 6.2 1000M ) 6.8 2.0 7.5 0.5 8.2 9.1 1 PACKAGING AND PRECAUTION OF CHIP RESISTOR E-96 ( 10 n E-96 series ( unit 0.001 0.01 ) 0.1 1 10 100 1k 10k 100k 1M 10M 100M 1000M ) 1.00 1.33 1.78 2.37 3.16 4.22 5.62 7.50 1.02 1.37 1.82 2.43 3.24 4.32 5.76 7.68 1.05 1.40 1.87 2.49 3.32 4.42 5.90 7.87 1.07 1.43 1.91 2.55 3.40 4.53 6.04 8.06 1.10 1.47 1.96 2.61 3.48 4.64 6.19 8.25 1.13 1.50 2.00 2.67 3.57 4.75 6.34 8.45 1.15 1.54 2.05 2.74 3.65 4.87 6.49 8.66 1.18 1.58 2.10 2.80 3.74 4.99 6.65 8.87 1.21 1.62 2.15 2.87 3.83 5.11 6.81 9.09 9.31 1.24 1.65 2.21 2.94 3.92 5.23 6.98 1.27 1.69 2.26 3.01 4.02 5.36 7.15 9.53 1.30 1.74 2.32 3.09 4.12 5.49 7.32 9.76 E 96 0603 E-96 series(0603) multiplied Cross-reference List and Resistance Cross-reference List multiplied code Code 10 0 10 1 10 2 10 A B C D E-96 E-96 resistance 3 10 4 10 5 10 6 10 7 10 -1 10 -2 10 -3 E F G H X Y Z Code E-96 E-96 resistance Code E-96 E-96 resistance Code E-96 E-96 resistance 01 100 25 178 49 316 73 02 102 26 182 50 324 74 576 03 105 27 187 51 332 75 590 562 04 107 28 191 52 340 76 604 05 110 29 196 53 348 77 619 06 113 30 200 54 357 78 634 07 115 31 205 55 365 79 649 08 118 32 210 56 374 80 665 09 121 33 215 57 383 81 681 10 124 34 221 58 392 82 698 11 127 35 226 59 402 83 715 12 130 36 232 60 412 84 732 13 133 37 237 61 422 85 750 14 137 38 243 62 432 86 768 15 140 39 249 63 442 87 787 16 143 40 255 64 453 88 806 17 147 41 261 65 464 89 825 18 150 42 267 66 475 90 845 19 154 43 274 67 487 91 866 20 158 44 280 68 499 92 887 21 162 45 287 69 511 93 909 22 165 46 294 70 523 94 931 23 169 47 301 71 536 95 953 24 174 48 309 72 549 96 976 87 Description for Resistance Value Code and Marking of Thick Film Chip Resistor Resistance Value Code All the resistance value code of thick film chip resistor is corresponding with the marking . Marking E-24 (0603 5%) 10 E-24 series: Express resistance value on the glass side with three digits, the first tow digits should be significant and the third one denote number of zeros. 10K For example: 33 E-24 (0603 1%& 0.5%) E-24 series(0603 1%& 0.5%): One short bar under marking letter. For example: E-96 E24 1%& 0.5% 0805 1206 1210 2010 2512 4R02 4R03 E-96 series & E-24 series:For the dimension type of 0805 1206 1210 2010 2512 4R02 4R03 express the resistance value with four digits, the first three digits are significant figures and the fourth de notes the number of zeros. For example: 133 100K E-96 0603 E-96 For the dimension type of 0603, express the resistance value with three code, the first two digit code denote the resistance of E-96 series, and the third code of letter denote the multiplier (see the table three and four ). For example: R 2M The decimal point should be expressed by R For example: 0 . 1 5.6 The jumper should be expressed by For example: 01005 0201 0402 on the glass side. 0 0 For the dimension type of 01005 0201 0402 there is no mark For example: IEC IEC E24 For the resistance which don't belong to IEC serial, use the resistance of IEC serial which is most close to the required resistance of non-IEC serial for replacement. To get agreement by both party if there special requirement for the marking. 88 PACKAGING AND PRECAUTION OF CHIP RESISTOR Description for Resistance Value Code and Marking of Thin Film Chip Resistor Resistance Value Code 0201 0402 0603 0805 1206 1210 2010 2512 All resistance value code of thin film chip resistor,including 0201 0402 0603 0805 1206 1210 2010 2512 size used four digits. Example TD03G4701BT 4701=4.7K 1R50=1.5 To use four digits code represent resistance value , Example 4701=4.7K 1R50=1.5 Marking E24 E96 E96 . When resistance value belongs to E24 as well as E96 series, we suggest preferentially use E96 series. Example 10K=1002, 103 0805 1206 1210 2010 2512 Marking for 0805 1206 1210 2010 2512 Size Resistor 0805 1206 1210 2010 2512 For 0805 1206 1210 2010 2512 size resistor , express the resistance value with four digits code; Example 100K 0603 Marking for 0603 Size Resistor 0603-E96 For resistance value belongs to E96 series, express the resistance value with three digits code. Example 2M 0603-E24 For resistance value belongs to E24 series, express the resistance value with three digits code. Example 10K The decimal point should be expressed by "R" . Example 5.6 0201 0402 For the dimension type of 0201 0402 there is no mark on the glass side. Example 89 1 2 3 4 5 6 7 1 Use in various types of liquid, including water, oils, chemicals, and organic solvents. 2 Use outdoors where the products are exposed to direct sunlight, or in dusty places. 3 Use in places where the products are exposed to sea winds or corrosive gases, including Cl2, H2S, Nh3, SO2, and No2 etc. 4 Use in places where the products are exposed to static electricity or electromagnetic waves. 5 Use in proximity to heat-producing components, plastic cords, or other flammable items. 6 Use involving sealing or coating the products with resin or other coating materials. 7 Use involving unclean solder or use of water or water-soluble cleaning agents for cleaning after soldering. 1 2 3 4 : 5 30 30% 70% 1 Avoid applying power exceeding normal rated power, exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 2 Be careful when pick up the products with tweezers. There may be a care that the overcoat and / or the body can be chipped. 3 Soldering tip shall not touch the product when install product manually. 4 Storage conditions: T 5 30 , RH 30% 70%. Recommended wave solder profile Recommended reflow profile Recommended solder alloy 96.5Sn/3.0Ag/0.5Cu 90
RC-01W4121FT
1. 物料型号:文档列出了电阻器的型号和编码规则,例如RS03K1003FT,其中包含额定功率、型号、电阻温度系数、电阻值、电阻值误差和包装方式等信息。
2. 器件简介:介绍了电阻器的特点,如体积小、重量轻、适应再流焊与波峰焊、电性能稳定、可靠性高、成本低、机械强度高、高频特性优越,并符合RoHS指令和无卤素要求。
3. 引脚分配:文档中没有明确提到引脚分配,但通常片式电阻器的引脚分配是对称的。
4. 参数特性:详细列出了电阻器的尺寸、额定功率、电阻值、公差、温度系数等参数,并提供了不同尺寸的电阻器的详细尺寸数据。
5. 功能详解:文档中没有直接的功能详解部分,但通过参数特性应用信息可以推断电阻器的功能。
6. 应用信息:虽然没有直接的应用案例,但根据电阻器的特性,可以推断它们适用于需要小型化、稳定性和可靠性的电子设备中。
7. 封装信息:提供了不同型号电阻器的封装尺寸和推荐焊盘尺寸。
RC-01W4121FT 价格&库存
很抱歉,暂时无法提供与“RC-01W4121FT”相匹配的价格&库存,您可以联系我们找货
RC-01W4121FT
    • 100+0.00279
    • 500+0.00232
    • 5000+0.00224
    • 15000+0.00201
    • 45000+0.00193
    • 90000+0.00186
    库存:14900
