Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 9
SERIES: AMT11 | DESCRIPTION: MODULAR INCREMENTAL ENCODER
FEATURES
• patented capacitive ASIC technology
• low power consumption
• incremental resolutions up to 4096 PPR
• resolutions programmable with AMT Viewpoint™ PC software
• differential line driver versions
• digitally set zero position
• compact modular package with locking hub for ease of installation
• radial and axial cable connections
• 7 different mounting hole options
• -40~125°C operating temperature
ELECTRICAL
parameter
conditions/description
min
power supply
VDD
4.5
start-up time1
current consumption
with unloaded output
VDD-0.1
single ended channels
output high level
output low level
output current (per channel)
rise/fall time
output high level
output low level
rise/fall time
3
differential RS-422 channels
Note:
typ
max
5
5.5
units
V
200
ms
16
mA
8
0.1
15
7
11
0.1
25
min
typ
max
V
V
mA
ns
V
V
mA
ns
units
1. Encoder must be stationary during start-up.
INCREMENTAL CHARACTERISTICS
parameter
channels
CMOS Voltage (S)
Quadrature Line Driver (Q)
waveform
CMOS voltage square wave
phase difference
A leads B for CCW rotation (viewed from front)
quadrature resolutions2
48, 96, 100, 125, 192, 200, 250, 256, 360, 384, 400, 500,
512, 768, 800, 1000, 1024, 1600, 2000, 2048, 2500, 4096
index3
one pulse per 360 degree rotation
A, B, Z
¯ B, B,
¯ Z, ¯
A, A,
Z
PPR
accuracy
0.2
quadrature duty cycle (at each
resolution)
Notes:
48, 96, 100, 125, 192, 256, 384
200, 250, 360, 400, 768, 800
500, 1000, 1600
512, 1024 , 2048, 4096
2000
2500
49
48
46
50
44
43
50
50
50
50
50
50
degrees
51
52
54
50
56
57
2. Resolution programmed with AMT Viewpoint™ PC software. Default resolution set to 2048 PPR. All resolutions are listed as pre-quadrature, meaning the final number of
counts is PPR x 4.
3. Zero position alignment set with AMT One Touch Zero™ module, AMT Viewpoint™ PC software, or serial commands
cuidevices.com
Product Page
3D Model
CUI DEVICES | SERIES: AMT11 | DESCRIPTION: MODULAR INCREMENTAL ENCODER
date 08/05/2022 | page 2 of 9
MECHANICAL
parameter
min
motor shaft length
typ
max
9
motor shaft tolerance
mm
NOM +0/-0.015
weight
weight varies by configuration
mm
15.7
axial play
rotational speed (at each
resolution)
units
g
±0.3
mm
48, 96, 100, 125, 192, 200, 250, 256, 384, 400, 500, 512,
800, 1000, 1024, 2048
8000
RPM
360, 768, 1600, 2000, 4096
4000
RPM
2500
2500
RPM
max
units
125
°C
85
ENVIRONMENTAL
parameter
min
typ
-40
humidity
non-condensing
vibration
10~500 Hz, 5 minute sweep, 2 hours on each XYZ
shock
3 pulses, 6 ms, 3 on each XYZ
RoHS
yes
5
G
200
G
max
units
SERIAL INTERFACE
parameter
protocol
serial UART
min
controller
driven by onboard Microchip PIC18F25K80. See Microchip documentation for additional details.
data rate
8 data bits, no parity, 1 stop bit, least significant bit first
typ
115200
WAVEFORMS
Figure 1
Quadrature signals with index showing
counter-clockwise rotation
I
Z
A
T
B
P
S
S
S
S
The following parameters are defined by the resolution selected for each encoder. The encoders resolution is listed as Pulses Per
Revolution (PPR), which is the number of periods (or high pulses) over the encoders revolution.
Parameter
Description
PPR
resolution
CPR
counts
Note:
Expression
Units
Notes
Pulses Per Revolution
This is the user selected value and the format
all resolutions are listed in
PPR x 4
Counts Per Revolution
This is the number of quadrature counts the
encoder has
T
period
360/R
mechanical degrees
P
pulse width
T/2
mechanical degrees
S
A/B state width
T/4
mechanical degrees
This is the width of a quadrature state
I
index width
T/4
mechanical degrees
The width of a once per turn index is the state
width for A & B lines
For more information regarding PPR, CPR, or LPR (Lines Per Revolution) view https://www.cuidevices.com/blog/what-is-encoder-ppr-cpr-and-lpr
cuidevices.com
baud
Product Page
3D Model
date 08/05/2022 | page 3 of 9
PART NUMBER KEY
For customers that prefer a specific AMT11 configuration, please reference the custom configuration key below.
AMT11XX - XXXX - XXXX - X
Mounting Base:
S = Standard
W= Wide
Base Number
Orientation:
2 = Radial
3 = Axial
Output Signals:
S = CMOS Voltage
Q = Quadrature Line Driver
Sleeve Bore Diameter:
2000 = 2 mm
3000 = 3 mm
3175 = 3.175 mm (1/8”)
4000 = 4 mm
4760 = 4.76 mm (3/16”)
5000 = 5 mm
6000 = 6 mm
6350 = 6.35 mm (1/4”)
8000 = 8 mm
Quadrature
Resolution (PPR):
0048
0500
0096
0512
0100
0768
0125
0800
0192
1000
0200
1024
0250
1600
0256
2000
0360
2048
0384
2500
0400
4096
AMT11-V KITS
In order to provide maximum flexibility for our customers, the AMT11 series is provided in kit form standard. This allows the user to implement the encoder into a range of applications using one sku#, reducing engineering and inventory costs.
SLEEVES
ORDERING GUIDE
AMT11XX-V
Orientation:
2 = Radial
3 = Axial
Output Signals:
S = CMOS Voltage
2mm
3mm
1/8 inch
(3.175mm)
4mm
3/16 inch
(4.76mm)
5mm
6mm
1/4 inch
(6.35mm)
8mm
Light Sky
Blue
Orange
Purple
Gray
Yellow
Green
Red
Snow
Blue
BASE
WIDE
BASE
cuidevices.com
TOP
COVER
SHAFT
ADAPTER
TOOL A
TOOL C
Product Page
3D Model
date 08/05/2022 | page 4 of 9
ENCODER INTERFACE
PINOUT CONNECTOR
Function
AMT112S
AMT112Q
AMT113S
AMT113Q
1
TX_ENC+
TX_ENC+
RX_ENC+
RX_ENC+
2
RX_ENC+
RX_ENC+
TX_ENC+
TX_ENC+
3
N/A
N/A
N/A
N/A
4
GND
GND
GND
GND1
5
N/A
N/A
N/A
N/A
6
+5 V
+5 V
+5 V
+5 V
7
N/A
N/A
N/A
N/A
8
B+
B+
B+
B+
9
N/A
B-
N/A
B-
10
A+
A+
A+
A+
11
N/A
A-
N/A
A-
12
Z+
Z+
Z+
Z+
1
1
1
13
N/A
Z-
N/A
Z-
14
MCLRB
MCLRB
MCLRB
MCLRB
15
N/A
N/A
N/A
N/A
16
N/A
N/A
N/A
N/A
17
N/A
N/A
N/A
N/A
Note:
1. Connect encoder GND to motor chassis as closely as possible. For additional grounding
techniques contact CUI Devices Application Support.
AMT112S & AMT112Q
AMT113S & AMT113Q
A
A
B
17 15 13 11 9
7
16 14 12 10 8
5
6
3
4
13 11 9
1
2
7
5
3
1
14 12 10 8
6
4
2
SECTION A-A
DETAIL B
SCALE 4 : 1
SCALE 4 : 1
Mating Connector:
JAE FI-W17S
Mating Connector:
Samtec ISDF-07-D-L
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 5 of 9
MECHANICAL DRAWING
AMT112S & AMT112Q
units: mm[inch]
tolerance: ±0.1
10.34 0.407
R15.49 0.610
15.30 0.602
15.33 0.604
37.25 1.467
28.58 1.125
10.34 0.407
AMT113S & AMT113Q
units: mm[inch]
tolerance: ±0.1
10.34 0.407
R15.49 0.610
15.30 0.602
15.33 0.604
37.39 1.472
10.93 0.430
28.58 1.125
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 6 of 9
MECHANICAL DRAWING (CONTINUED)
MOUNTING HOLE PATTERNS
STANDARD BASE
units: mm[inch]
tolerance: ±0.1
22.00 0.866
21.55 0.848
20.90 0.823
12.60[0.496]
R1.05 0.041
DETAIL A
SCALE 4 : 1
2.00 0.079
(4 PLCS)
2.95 0.116
(2 PLCS)
16.00 0.630
0.275 0.011
A (3 PLCS)
1.70 0.067
(2 PLCS)
19.05 0.750
25.40 1.000
WIDE BASE
units: mm[inch]
tolerance: ±0.1
32.44 1.277
3.00 0.118
(2 PLCS)
2.96
2.87 X 2.96
(2 PLCS)
A
2.87
0.09
DETAIL A
SCALE 4 : 1
46.02 1.812
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 7 of 9
ASSEMBLY PROCEDURE
STEP 1
STEP 2
STEP 3
Align Tool C with
flange on Base
1. Insert Tool A as a spacer that defines the distance to
the mounting surface.
2. Slide appropriate sized Sleeve over shaft all the way down to Tool A.
3. Slide Shaft Adaptor over Sleeve.
4. Use Tool C to press Shaft Adaptor over Sleeve (ensure Shaft Adapter
and Tool C spline alignment) until flush with Tool A.
STEP 4
1. Remove Tools A and C.
2. Place Base on motor, with Tool C used as a centering tool.
STEP 5
1. Snap the Top Cover onto the Base, carefully observing that the
teeth of the Shaft Adaptor align with the grooves in the hub. *
1. Fasten the Base on the motor (Tool C may need to be
rotated to allow for some mounting configurations).
2. Remove Tool C.
* We recommend no more than three cycles of mounting and
removal of the AMT top cover base. Multiple cycles of mounting
and removing the top cover can cause base fatigue over time and
affect encoder performance.
cuidevices.com
1. Align Tool C with flange on Base.
2. Slide Base and Tool C onto motor, centering onto
the Shaft Adapter.
STEP 6
1. Make sure the snaps are fully engaged by pressing
on the Hub with the reverse side of Tool C.
2. When assembly is finished, the Shaft Adaptor, Sleeve
and Rotor Hub should all be flush with the Motor
Shaft rotating freely.
Product Page
3D Model
date 08/05/2022 | page 8 of 9
APPLICATION NOTES
SERIAL INTERFACE
The AMT11 series encoder is designed to operate with a serial UART interface. This interface allows the encoder to be configured and programmed by
the AMT Viewpoint™ application. Along with programming, the AMT Viewpoint™ application uses the serial interface for diagnostics and index alignment.
Below are instructions on how to use the serial interface for position zeroing.
Table 1
Serial Commands
Command
Action
Use
This command sends an ascii ‘0’ (hex value
0x30).
This zeros the encoder and sets the index at the current angular position. This
position is stored in non-volatile memory and will remain present until a zero
command is set again or encoder is reprogrammed via AMT Viewpoint™.
Q
This command sends an ascii ‘Q’ (hex value
0x51).
This command restarts the encoder as if it were power cycled.
Table 2
Serial Pins
Pin
Description
Connection
TX_ENC+
This is the pin that the encoder transmits
serial data on.
Connect this pin to the receiver input of your serial/UART interface.
RX_ENC+
This is the pin that the encoder receives
serial commands on.
Connect this pin to your serial/UART interface transmitter output.
MCLRB
This pin is used to force the encoder into
reset for reprogramming via the AMT
Connection of this pin is not required for the above serial commands.
The serial interface operates at 115200 baud with 8 data bits, no parity, and 1 stop bit, and 1 start bit. This is the standard UART protocol. Data lines
TX_ENC+ and RX_ENC+ are high when inactive.
Figure 2
Serial Timing Diagram
RX_ENC+
Start
2
3
4
5
6
7
Stop
Command: 0 (hex: 0x30, binary: 0b00001100)
TX_ENC+
Start
2
3
4
5
6
Response: \r (hex: 0x0d, binary: 0b10110000)
cuidevices.com
7
Stop
Product Page
3D Model
date 08/05/2022 | page 9 of 9
REVISION HISTORY
rev.
description
date
1.0
initial release
04/30/2014
1.01
updated datasheet
06/24/2014
1.02
updated datasheet
10/13/2015
1.03
added 360 & 2500 PPR resolutions, increased operating temperature to 125°C
12/18/2017
1.04
changed outer mounting holes to be oblong on wide base version
10/10/2018
1.05
brand update
11/21/2019
1.06
updated quadrature duty cycle details
10/08/2020
1.07
added motor shaft tolerance details, updated start-up details
09/10/2021
1.08
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
