SCMD-MOAC5C
SCMD-MOAC5C
    DATAFORTH(Dataforth)
    MINIATURE DIGITAL OUTPUT MODULE
SCMD-MOAC5C 数据手册
Isolated Digital I/O Products S C M D SCMD-MOAC/MODC Miniature Digital Output Modules Description The SCMD digital output modules are used for switching AC and DC loads such as relays, solenoids, motor starters, or indicator lamps. All models provide up to rms of optical isolation between the field device and the control logic. The AC output modules incorporate zero voltage switching and an R snubber circuit which allows switching heavy inductive loads. Functionality is denoted by case color A modules are blac , and D modules are red. Six bac panels are available for mounting S modules. See “Accessories” section. D digital output Features • AC Modules have High Current Thyristor with Amp Surge apability ero or Random Turn On Available in A Modules • Plug into Backpanels for Miniature or Full-Sized Modules rms Optical Isolation except L suffix rms Optical Isolation with L suffix • Industry Standard Pinout and Footprint • 3.5 Amp AC Modules Provide Extra Switching apability . Amp D odules Available Operating Temperature to L Listed, SA ertified, ompliant Ordering Information F ig u r e 1 : S C M D - M O A C /M O D C P h ysi ca l D i m e n si o n s i ita ut ut o u es o e o u fi es enti in tiona eatures u fi Feature A High voltage versions (280VAC for AC modules, 200VDC for DC modules). B High voltage version (280VAC for AC modules) with low leakage output current. ML FET output version of DC module, 5.0A, 50VDC. F ig u r e 2 : S C M D - M O A C /M O D C C i r cu Model Output Range Supply Voltage SCMD-MOAC5 SCMD-MOAC5A SCMD-MOAC5B SCMD-MOAC24 SCMD-MOAC24A SCMD-MODC5 SCMD-MODC5A SCMD-MODC5ML SCMD-MODC24 12 to 140VAC 24 to 280VAC 24 to 280VAC 12 to 140VAC 24 to 280VAC 3.0 to 60VDC 5.0 to 200VDC 0 to 50VDC 3.0 to 60VDC 5V 5V 5V 24V 24V 5V 5V 5V 24V it D ia g r a m s 1 9 8 ©1995-2017 Dataforth Corporation, All Rights Reserved For information call 800-444-7644 ISO9001:2008-Registered QMS
SCMD-MOAC5C
物料型号:SCMD系列,包括SCMD-MOAC/MODC微型数字输出模块。
器件简介:这些模块提供高达4000Vrms的光隔离,用于现场设备开关和RC吸收电路之间。功能由外壳颜色表示,交流模块为黑色,直流模块为红色。
引脚分配:文档中提到了行业标准的引脚排列和尺寸。
参数特性:包括高电流可控硅、零电压或随机开启选项、3.5A的交流模块提供额外的开关能力、5.0A直流模块可用、工作温度范围为-30°C至+80°C。
功能详解:文档提供了电路图,展示了模块的内部结构和连接方式。
应用信息:这些模块用于切换交流和直流负载,如继电器、电磁铁、电机启动器或指示灯。
封装信息:提供了六种背板选项,用于安装SCMD-M数字输出模块。
SCMD-MOAC5C 价格&库存
很抱歉,暂时无法提供与“SCMD-MOAC5C”相匹配的价格&库存,您可以联系我们找货
