YP0AH471K070DAMD0B
YP0AH471K070DAMD0B
    WALSIN(华新科)
    插件,P=10mm
    安规电容 径向
YP0AH471K070DAMD0B 数据手册
Product Specification CUSTOMER 客戶 CUSTOMER P/N 客戶料號 SPEC. DATE 日期 CAP. 電容量 D.F. 散逸因素 I.R. 絕緣電阻 產 品 規 格 圖 YP0AH471K070DAMD0B SAP PART NO.: REV. 修正 DRAWN BY APPROVAL YU ZHANG XJ XIAO 2018/10/19 經手人 核准 2018/10/19 2018/10/19 WORKING VOLTAGE X1: 400 VAC 470pF TOL.允差 ±10% 工作電壓 Y1: 250 VAC TEST VOLTAGE 2.5% MAX. at 1KHz±20% 4000 VAC 測試電壓 and 5V(rms.) or less 10000MΩMIN. Y5P T.C. at DC500±50V within 60±5sec of charging TOL.(允差) ±10% 溫度特性 MARKING Item Symbol Dimensions (mm) 25.4±2 12.7±0.3 10.0±1.0 12.7±1.5 7.7±1.5 8.0 max Deviation along tape, left or right P P0 F P2 P1 D △S Carrier tape width Position of sprocket hole W W1 18.0 +1/-0.5 9.0±0.5 Lead distance between the kink and center of sprocket hole H0 18.0 +2.0/-0 l 2.0min (Or the end of lead wire may be inside the hole-down tape.) D0 d t1 t2 4.0±0.2 0.55±0.05 0.6±0.3 1.5 max. Pitch of component Pitch of sprocket Lead spacing Length from hole center to component center Length from hole center to lead Body diameter Length from the terminal of the lead wire to the edge of carrier tape Diameter of sprocket hole Lead diameter Total tape thickness Total thickness, tape and lead wire Deviation across tape Portion to cut in case of defect Hole-down tape width Hole-down tape distortion Coating extension on leads Body thickness 0±2.0 △h1/△h2 2.0 max. L W0 W2 e T 11.0 max. 8.0 min. 1.5±1.5. Not exceed the kink 5.0 max
YP0AH471K070DAMD0B 价格&库存
很抱歉,暂时无法提供与“YP0AH471K070DAMD0B”相匹配的价格&库存,您可以联系我们找货
YP0AH471K070DAMD0B
    • 5+0.53882
    • 50+0.43352
    • 150+0.38081
    库存:5
