SCM5B38-01D
SCM5B38-01D
    DATAFORTH(Dataforth)
    STRAIN GAGE MODULE WIDE WB
SCM5B38-01D 数据手册
Isolated Analog Signal Conditioning Products S C M 5 B SCM5B38 Strain Gage Input Modules, Wide Bandwidth Description Each SCM5B38 Strain Gage input module provides a single channel of strain gage input which is filtered, isolated, amplified, and converted to a high-level analog voltage output (Figure 1). This voltage output is logic switch controlled, which allows these modules to share a common analog bus without the re uirement of external multiplexers. The SCM5B modules are designed with a completely isolated computer side circuit which can be oated to from Power ommon, pin . This complete isolation means that no connection is re uired between I O Common and Power Common for proper operation of the output switch. If desired, the output switch can be turned on continuously by simply connecting pin , the Read nable pin, to I O ommon, pin . The S B can interface to full bridge or half bridge transducers with a nominal resistance of to . A matched pair of bridge completion resistors to m at excitation allows use of low cost half bridge or uarter bridge transducers Figures , , . The H bandwidth allows measurement of high speed processes such as vibration analysis. Strain gage excitation is provided from the module by a very stable or 3.333V source. The excitation supply is fully isolated, allowing the amplifier inputs to operate over the full range of the excitation voltage. This feature offers significant exibility in real world applications. Full scale sensitivities of 2mV/V, 3mV/V or 10mV/V are offered as standard. With 10V excitation, this results in ± 20mV, ± 30mV or ± 100mV full scale input range producing ± 5V full scale output. The input signal is processed through a wide bandwidth pre amplifier on the field side of the isolation barrier. After amplification, the input signal is chopped by a proprietary chopper circuit. Isolation is provided by transformer coupling, again using a proprietary technique to suppress F i g u r e 1 : S C M 5 B 3 8 B l o ck Features Interfaces to Thru , Full Bridge, Half-Bridge, or Quarter-Bridge Strain Gages • High-Level Voltage Output • 1500Vrms Transformer Isolation • ANSI/IEEE C37.90.1 Transient Protection • Input Protected to 240VAC Continuous • Fully Isolated Excitation Supply • 100dB CMR • 10kHz Signal Bandwidth • ± 0.03% Accuracy • ± 0.01% Linearity Drift SA S ertified • CE and ATEX Compliant • Mix and Match SCM5B Types on Backpanel transmission of common mode spikes or surges. The module is powered from +5VDC, ± 5%. Special input circuits on the SCM5B38 module provide protection of the signal inputs and the isolated excitation supply up to 240VAC. D ia g r a m 2 2 ©1995-2017 Dataforth Corporation, All Rights Reserved For information call 800-444-7644 ISO9001:2008-Registered QMS Specifications Typical❇ at TA Module Input Range Input Bias Current Input Resistance Normal Power Off Overload Signal Input Protection Continuous Transient Excitation Output (-02, -04, -05, -07) Load Resistance Excitation Output (-01, -03, -06) Load Resistance Excitation Load Regulation xcitation Stability Half Bridge Voltage Level (-04) Half Bridge Voltage Level (-03) Isolated Excitation Protection Continuous Transient CMV, Input to Output Continuous Transient CMR (50 or 60Hz) NMR (– 3dB at 10kHz) Accuracy(2) Linearity Stability Input Offset Output Offset Gain Noise Input, 0.1 to 10Hz Output, 100kHz Bandwidth, – 3dB Rise Time, 10 to 90% Span Settling Time, to 0.1% Output Range Output Resistance Output Protection Output Selection Time (to ± 1mV of VOUT) Output Current Limit Output nable ontrol Max Logic “0” Min Logic “1” Max Logic “1” Input Current “0,1” Power Supply Voltage Power Supply Current Power Supply Sensitivity Mechanical Dimensions (h)(w)(d) Environmental Operating Temperature Range Storage Temperature Range Relative Humidity Emissions EN61000-6-4 Radiated, Conducted Immunity EN61000-6-2 RF ESD, EFT and Ordering Information D power Full Bridge SCM5B38-01,-02,-05,-06,-07 ± 10mV to ± 100mV ± 0.3nA Half Bridge SCM5B38-03,-04 * * Model (10kHz) SCM5B38-01 SCM5B38-02 SCM5B38-03 SCM5B38-04 SCM5B38-05 SCM5B38-06 SCM5B38-07 * * * 240Vrms max ANSI/IEEE C37.90.1 +10V ± 3mV to +3.333V ± 2mV to ± 5ppm/mA ppm NA NA S C M 5 B S C M 5 B Isolated Analog Signal Conditioning Products * * * * Type Bridge Input Full Full Half Half Full Full Full Output citation Sens. Range† Input Range – 10mV to +10mV +3.333V 3mV/V – 30mV to +30mV +10.0V 3mV/V – 10mV to +10mV +3.333V 3mV/V – 30mV to +30mV +10.0V 3mV/V – 20mV to +20mV +10.0V 2mV/V – 33.3mV to +33.3mV +3.333V 10mV/V – 100mV to +100mV +10.0V 10mV/V 1, 2 1, 2 1, 2 1, 2 1, 2 1, 2 1, 2 Output Ranges Available † * * Output Range Part o u fi * * +5V ± 1mV +1.667V ± 1mV 240Vrms max ANSI/IEEE C37.90.1 1. – 5V to +5V 2. – 10V to +10V NONE D am e SCM5B38-01 SCM5B38-01D * * 1500Vrms max ANSI/IEEE C37.90.1 100dB dB per Decade above H ± 0.03% Span ± 0.01% Span * * * * * * * * ppm of Reading * . rms 10mVp-p 10kHz s s See Ordering Information rms * * F i g u r e 2 : F u l l B r i d g e C o n n e ct i o n * * * * Continuous Short to Ground s at load = 0 to 2000pF * * ± 8mA +0.8V +2.4V +36V . A +5VDC ± 5% 170mA Full Exc. Load, 70mA No Exc. Load RTI(3) 2.28” x 2.26” x 0.60” (58mm x 57mm x 15mm) to to 0 to 95% Noncondensing ISM, Group 1 Class A ISM, Group 1 Performance A ± 0.5% Span Error Performance B ontact factory or your local Dataforth sales office for maximum values. NOTES: * Same as – 01, – 02, – 05, – 06, – 07 modules. Strain element. Includes linearity, hysteresis and repeatability. RTI Referenced to input. * * * * * * * F i g u r e 3 : H a l f B r i d g e C o n n e ct i o n * * * * * * * * * * ❇ F i g u r e 4 : Q u a r t e r B r i d g e C o n n e ct i o n Visit our website www.dataforth.com ©1995-2017 Dataforth Corporation, All Rights Reserved 2 3 ISO9001:2008-Registered QMS
SCM5B38-01D 价格&库存
很抱歉,暂时无法提供与“SCM5B38-01D”相匹配的价格&库存,您可以联系我们找货
SCM5B38-01D
库存:5
