CU103602
CU103602
    ZF
    Box with Connector
CU103602 数据手册
Angle Position Sensors AN8 Sensors Programmable, non-contact magnetic position sensors capable of continuous rotation Description The AN8 Series sensors are non-contact, intrinsically linear contact angle position sensors. The sensors operate through the use of Hall Effect technology with magnetic fields generated by permanent magnets. They provide a linear change in voltage output (ratiometric to the input voltage) corresponding to an angular rotation of the input shaft. Features         Typical Applications Angular position sensor with high tolerance for misalignment Non-contact angular position sensing and full 360° rotation Custom programming available for: angle range, slope, PWM output, custom magnets – contact factory No mechanical interface means no parts to wear out or jam Available with Delphi connector or 12” (305 mm) wire leads RoHS compliant IP67 Maximum air gap of 5.5 mm (0.22”)*       Implement (fork lift, agricultural trailer hitch, etc.) position sensing Steer, throttle by wire Gear selection Zero-contact encoder alternative Replacement for smart bearings Outboard trim sensing Environmental Specifications Vibration Operating Temperature Storage Temperature Ingress Protection 6g sinusoidal, 8 g RMS axial; 40Hz – 2 kHz all 3 axes -40 °C to 125 °C (-40 °F to 257 °F) with Delphi connectors, -40 °C to 150 °C (-40 °F to 302 °F) with wire leads -40 °C to 150 °C (-40 °F to 302 °F) IP67 Electrical Specifications Input Voltage Output Voltage Input Current Output Current Output Accuarcy Output Linearity Maximum Overvoltage Absolute Max. Output Current Output Type 5.0 VDC ± 10% 10% to 90% of input (see graph for voltage vs. rotation angle characteristics) 14 mA typ., 16 mA max. -8 mA to 8 mA ±3.5% ±3.5% 16 VDC ±30 mA Analog (PWM available) Mechanical Specifications Housing Material Mechanical Travel Mating Connector Maximum Air Gap* *with AS500106 magnet carrier Maximum Center-To-Center Offset Glass Reinforced Plastic 0° to 360° (continuous) Delphi Metri-pak 150.2 12162185; Terminal 1214075 / 2047680 5.5 mm (0.22") 2 mm radial (magnet to center) www.cherryswitches.com Page 1 of 2, last update 2014-10-29, Specifications subject to change without notice. Products Part Number Sensor (incl. (Sensor) AS500106 magnet) AN820001 CU103601 AN820002 CU103602 AN820003* CU103603 AN820031 -------AN820032 -------AN820033* -------*Not commonly stocked Sensing Range 180° 360° 45° 180° 360° 45° Wires Connectors Terminals N/A N/A N/A 18 AWG x 305 mm (12") 18 AWG x 305 mm (12") 18 AWG x 305 mm (12") Packard Metri-pack Packard Metri-pack Packard Metri-pack N/A N/A N/A 1214075 / 2047680 1214075 / 2047680 1214075 / 2047680 N/A N/A N/A Sensor Output These charts show the output voltage as a percentage of the input voltage for a given angle of rotation. Example: 180⁰ sensing range, magnet rotated 135⁰, output voltage will be 70% of input voltage (see dashed lines in graph above). Dimensions mm (inches) www.cherryswitches.com Page 2 of 2, last update 2014-10-29, Specifications subject to change without notice.
CU103602 价格&库存
很抱歉,暂时无法提供与“CU103602”相匹配的价格&库存,您可以联系我们找货
