AN920036
AN920036
    ZF
    Box with Wire Leads
AN920036 数据手册
Angle Position Sensors AN9 Sensors Thin, programmable, non-contact magnetic position sensors capable of continuous rotation with dual outputs Description The AN9 Series sensors are non-contact, intrinsically linear angle position sensors with two independent outputs. The sensors operate through the use of Hall Effect technology with magnetic fields generated by permanent magnets. They provide a linear change in voltage output (ratiometric to the input voltage) corresponding to an angular rotation of the input shaft. Features Typical Applications           Angular position sensor with high tolerance for misalignment Non-contact angular position sensing and full 360° rotation Dual independent (fully redundant) outputs assure high reliability Custom programming available for: angle range, slope, PWM output, custom magnets – contact factory No mechanical interface means no parts to wear out or jam Comes with 18 AWG 305 mm (12”) wire leads RoHS Compliant IP68* Maximum air gap of 5.5 mm (0.22”)**      Implement (fork lift, agricultural trailer hitch, etc.) position sensing Steer, throttle by wire Gear selection Zero-contact encoder alternative Replacement for smart bearings Outboard trim sensing Environmental Specifications Vibration 15g sinusoidal, 9.26g RMS axial; 40 Hz – 2 kHz all 3 axes Operating Temperature -40 °C to 125 °C (-40 °F to 257 °F) Storage Temperature -40 °C to 150 °C (-40 °F to 302 °F) Ingress Protection IP68* *submerged in 22±3 °C water for 1 hour at 2 m depth Electrical Specifications Input Voltage Output Voltage Input Current Output Current Output Accuracy Output Linearity Maximum Overvoltage Absolute Max. Output Current Output Type 5.0 VDC ± 10% 10% to 90% of input (see graph for voltage vs. rotation angle characteristics) 14 mA typ., 16 mA max. -8 mA to 8 mA ±3.5% ±3.5% 16 VDC ±30 mA Analog (PWM available) Mechanical Specifications Housing Material Mechanical Travel Maximum Air Gap** **with AS500106 magnet carrier Maximum Center-To Center Offset Glass Reinforced Plastic 0° to 360° (continuous) 5.5 mm (0.22") 2 mm radial (magnet to center) Note: When used with AS500106 Magnet Carrier; user is responsible for determining characteristics when using other magnets. Products Sensing Range Wires www.switches-sensors.zf.com Page 1 of 2, last update 2017-01-05, Specifications subject to change without notice. #NP#_ TY9vb4IwEM a/CumrLZ PZFlDwHZ 2dY Q7E P5vD NCGV 4mxGqKHVLDF+ 95Xt zS655 O65 3+XuuYKqApMr 6A6JABOAI ILgNr Bi3 7HhlJv6 DvmhF+ARRgGE8MEmvG dDMA BC9 pvcgt8 2rLDv 61RWndLqYJyt6kS PJVMrkyLYZ XHw Qe cLCItiNQtf3ndpE WbYIoe TJYoJY1 /ae L49 wJhs hbxI ceY NY+StTGg 5a9SeN+Wa N7 Uuk1a ctelkL6jmb KRqNWN5v nJeN5kTr4ijj7yr GbM OuD7 WtbHj dd1 q1 dmCtp+ N1M d/0zLOopJmj0JVvZPT3 9PPGU7jfI bHI zyaL3 O4 2KKlV+B0E1rG /CI heYr INCKuhyh2fRqN3Z hQ6BLohcj HEbYJ brcf_# NP# Part Number (Sensor) AN920031 AN920032 AN920035 AN920036 180° 360° 45° 90° 18 AWG x 305 mm (12") 18 AWG x 305 mm (12") 18 AWG x 305 mm (12") 18 AWG x 305 mm (12") Sensor Output Dimensions mm (inches) www.switches-sensors.zf.com Page 2 of 2, last update 2017-01-05, Specifications subject to change without notice. #NP#_ TY9vb4IwEM a/CumrLZ PZFlDwHZ 2dY Q7E P5vD NCGV 4mxGqKHVLDF+ 95Xt zS655 O65 3+XuuYKqApMr 6A6JABOAI ILgNr Bi3 7HhlJv6 DvmhF+ARRgGE8MEmvG dDMA BC9 pvcgt8 2rLDv 61RWndLqYJyt6kS PJVMrkyLYZ XHw Qe cLCItiNQtf3ndpE WbYIoe TJYoJY1 /ae L49 wJhs hbxI ceY NY+StTGg 5a9SeN+Wa N7 Uuk1a ctelkL6jmb KRqNWN5v nJeN5kTr4ijj7yr GbM OuD7 WtbHj dd1 q1 dmCtp+ N1M d/0zLOopJmj0JVvZPT3 9PPGU7jfI bHI zyaL3 O4 2KKlV+B0E1rG /CI heYr INCKuhyh2fRqN3Z hQ6BLohcj HEbYJ brcf_# NP#
AN920036 价格&库存
很抱歉,暂时无法提供与“AN920036”相匹配的价格&库存,您可以联系我们找货
