LRLI-27-450-R-00-20-A 数据手册
For use in:
Packaging Machinery
Chute/Gate Position
Factory Automation
Automotive Testing
LRL-27 Series
Linear Position Sensor for Extended Ranges
Long Lasting, Contactless, Inductive Sensors
Alliance Sensor Group’s LRL-27 series LVIT (Linear Variable Inductance Transducers) contactless position
sensors complement the LR series with extended ranges up to 18 inches (450 mm) in a compact package.
These sensors are designed for use in factory automation systems and a wide variety of industrial and
commercial applications. Cost effective with high-end performance and excellent stroke-to-length ratios
make these sensors ideal choices for many industrial application.
LRL-27 sensors are offered in 6 nominal ranges from 8 to 18 inches (200 to 450 mm). Operated from a
variety of DC voltages. These sensors offer the end-user a choice of four analog outputs along with ASG’s
proprietary SenSet™ field adjustable range scaling feature. LRL-27 sensors are available with an axial cable
or connector terminations, or with a radial exiting cable and two swivel rod eye ends for easy installation.
Besides the LRL-27 series sensors, ASG also offers the LR-27 series for shorter stroke applications and the
smaller size LR-19 series for lighter duty applications.
Features:
LVIT Technology™ (Linear Variable Inductance Transducer)
Contactless operation
Excellent stroke-to-length ratio
Proprietary SenSet™ field adjustable range scaling
Specifications:
Analog I/Os: 0-5 V or 0.5—4.5 V output with 8-30 V input, 35 mA max.
0-10 V output with 12-30 V input, 35 mA max.
4-20 mA (3-wire) output with 18-30 V input, 60 mA max (75 C max).
Measuring Ranges: 200 mm to 450 mm (8 to 18 inches) full scale (nominal)
Linearity Error:
LRLI-27-450-R-00-20-A 价格&库存
很抱歉,暂时无法提供与“LRLI-27-450-R-00-20-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8877.838141+1147.30167
