MMP100FRF270R
MMP100FRF270R
    YAGEO(国巨)
    MELF_D2.2X5.9MM_SM
    贴片电阻 MELF_D2.2X5.9MM_SM 270Ω ±1% 1W ±100ppm/℃
MMP100FRF270R 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET MELF METAL FILM RESISTORS High Power MMP Series ±1%, ±2%, ±5% 1W AND 2W Product specification – August 13, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors Melf Metal Film Resistors Product Specification ORDERING INFORMATION Part number of the power MELF metal film resistor is identified by the series, power rating, tolerance, packing, temperature coefficient and resistance value. PART NUMBER APPLICATIONS  All general purpose applications  Power applications MMP 100 J R - 100R (1) (2) (3) (4) (5) (6) (1) SERIES MMP Series  Energy meter (2) POWER RATING 100 = 1W 200 = 2W (3) TOLERANCE FEATURES F = ±1% J = ±5%  AEC-Q200 qualified G = ±2% - = Based on spec.  MELF, SMD package  Excellent pulse withstanding capability  Ultra miniature size  Higher power rating  RoHS compliant and halogen free (4) PACKAGING R = Reel Pack (5) TEMPERATURE COEFFICIENT OF RESISTANCE E=±50ppm/°C - = Based on spec. F=±100ppm/°C (6) RESISTANCE VALUE E24 & E96 Series value Example: 1R = 1Ω, 10K = 10,000Ω, 1M = 1,000,000Ω www.yageo.com Aug. 13, 2021 V.0 2 8 MMP Through Hole Resistors Product Specification Melf Metal Film Resistors 8 MMP DIMENSIONS Unit: mm Ultra Miniature L D C Min. MMP100 5.90 ± 0.2 2.20 ± 0.1 0.5 MMP200 8.50 ± 0.2 3.20± 0.2 0.5 SUGGESTED PAD LAYOUT Unit: mm Ultra Miniature Soldering Mode L Min. P W Min. Reflow 2.0 3.0 ± 0.1 3.0 Wave 2.5 3.0 ± 0.1 3.0 Reflow 2.3 5.5 ± 0.2 4.0 Wave 2.8 5.5 ± 0.2 4.0 MMP100 MMP200 DERATING CURVE Rated Power (%) 100 80 60 40 20 20 40 70 100 155 Ambient Temperature (°C) www.yageo.com Aug. 13, 2021 V.0 3 Through Hole Resistors Melf Metal Film Resistors Product Specification 8 MMP ELECTRICAL CHARACTERISTICS CHARACTERISTICS MMP100 MMP200 Power Rating at 70 °C 1W 2W Maximum Working Voltage 350V 350V Maximum Overload Voltage 700V 700V Voltage Proof on Insulation 500V 500V Resistance Range 1Ω ~ 1MΩ & 0Ω for E24 & E96 series value Operating Temp. Range - 55°C to +155°C Temperature Coefficient ±50ppm/°C, ±100ppm/°C Note: For resistance value out of above range is by request. TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 PROCEDURE 2.5 times RCWV for 5 sec.(Not more than APPRAISE ±0.5%+0.05Ω maximum overload voltage) Voltage Proof on IEC 60115-1 4.7 Insulation In V-Block for 60 sec. test voltage as No Breakdown above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >10,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, ±1.0%+0.05Ω 25 Sec.off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±2.0%+0.05Ω with 0.1 times RCWV Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±2.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19  -55°C  Room Temp.  ±0.75%+0.05Ω +155°C Room Temp.(5 cycles) Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a ±0.5%+0.05Ω point 3±0.5mm from the body www.yageo.com Aug. 13, 2021 V.0 4 Through Hole Resistors Melf Metal Film Resistors Product Specification 8 MMP Note: RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) PACKING TYPE Unit: piece Ultra Miniature Packaging Quantity Per Reel MMP100 7” 2,000 MMP200 13” 2,500 www.yageo.com Aug. 13, 2021 V.0 5 Through Hole Resistors Melf Metal Film Resistors Product Specification 8 MMP MARKING 3-BAND-CODE ±2%, ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 3rd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100K 1MΩ 10MΩ 0.001Ω 0.0001Ω 0.1Ω 0.01Ω ±1% 5-BAND-CODE www.yageo.com Aug. 13, 2021 V.0 6 Through Hole Resistors Melf Metal Film Resistors Product Specification 8 MMP REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug.2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 13, 2021 V.0 7 Through Hole Resistors Melf Metal Film Resistors Product Specification 8 MMP LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 13, 2021 V.0 8
MMP100FRF270R
物料型号:MMP系列,包括1W和2W功率等级的电阻器。
器件简介:MMP系列是YAGEO公司生产的金属膜电阻器,具有高功率、高可靠性,适用于一般用途和能源计量等应用。
引脚分配:文档中未明确提供引脚分配信息,但通常金属膜电阻器为两端引脚。
参数特性: - 容差:±1%,±2%,±5% - 温度系数:±50ppm/°C,±100ppm/°C - 功率等级:1W和2W - 最大工作电压:350V - 最大过载电压:700V - 绝缘耐压:500V - 电阻范围:1Ω至1MΩ,E24和E96系列值
功能详解: - 电阻器符合AEC-Q200标准,具有优秀的脉冲承受能力。 - 超小型尺寸,适用于MELF和SMD封装。 - RoHS合规且无卤素。
应用信息:适用于一般用途、能源计量、功率应用等。
封装信息:提供卷装包装,MMP100每卷2000个,MMP200每卷2500个。
MMP100FRF270R 价格&库存
很抱歉,暂时无法提供与“MMP100FRF270R”相匹配的价格&库存,您可以联系我们找货
