8B38-08
8B38-08
    DATAFORTH(Dataforth)
    STRAIN GAGE MOD NARROW&WIDE BW
8B38-08 数据手册
SensorLex® 8BIsolated IsolatedAnalog AnalogSignal SignalConditioning ConditioningProducts Products S C 8MB 5 B 8B38 Strain Gage Input Modules, Wide and Narrow Bandwidth Description 8B modules are an optimal solution for monitoring real-world process signals and providing high-level signals to a data acquisition system. ach B module isolates, filters, and amplifies a full bridge strain gage input signal and provides an analog voltage output (Figure 1). Features The B can interface to transducers with a nominal resistance of to . Bridge excitation is provided from the module with a stable . or 3.33V source. Full scale sensitivities of 2mV/V and 3mV/V are offered as standard. • High-Level Voltage Outputs Signal filtering is accomplished with a pole filter optimi ed for time and frequency response which provides 100dB per decade of normal-mode re ection above the filter cutoff fre uency. One pole of this filter is on the field side of the isolation barrier for anti aliasing, and the other four are on the system side. • Input Protection to 240VAC Continuous A special input circuit on the 8B38 module provides protection against accidental connection of power-line voltages up to 240VAC. Clamp circuits on the I/O and power terminals protect against harmful transients. • ± 0.02% Linearity Interfaces to Strain Gages through Full Bridge • 1500Vrms Isolation • ANSI/IEEE C37.90.1 Transient Protection • 100dB CMR • 3Hz or 8kHz Signal Bandwidth • ± 0.05% Accuracy Low Drift with Ambient Temperature • C-UL-US Listed Isolation is provided by transformer coupling to suppress transmission of common mode spikes or surges. The module is powered from +5VDC, ± 5%. • CE Compliant • ATEX Compliance Pending The modules are designed for installation in Class I, Division 2 hazardous locations and have a high level of immunity to environmental noise. • Mix and Match Module Types on Backpanel Isolation Barrier –EXC 1 4 CJCn Jn (1) – +EXC 2 3 Excitation Source LPF Surge Suppression and Protection Iso-Chopper™ Amplifier Pat. Pending 6 LPF 7 +V + VOUT COM –V Computer-Side Power Backpanel Terminal Block (1) CJC Enable Jumper. Remove for 8B38. F i g u r e 1 : 8 B 3 8 B l o ck +V´ –V´ 5 Isolated Field-Side Power D ia g r a m 1 1 8 ©1995-2017 Dataforth Corporation, All Rights Reserved For information call 800-444-7644 ISO9001:2008-Registered QMS Power Oscillator 7 +5VDC COM 8 B SensorLex® 8B Isolated Analog Signal Conditioning Products Typical❇ at TA and Ordering Information D power Module Input Range Input Bias Current Input Resistance Normal Power Off Overload Input Protection Continuous(1) Transient Excitation Output (-x1) Load Resistance Excitation Output (-x2,-x5) Load Resistance Excitation Load Regulation xcitation Stability Excitation Protection CMV, Input to Output Transient, Input to Output CMR (50Hz or 60Hz) NMR Accuracy(2) Linearity Stability Offset Gain Noise Output, 100kHz Bandwidth, – 3dB Response Time, 90% Span Output Range Output Protection Transient * ± 10mV to ± 30mV ± 0.5nA * * * * * 240VAC ANSI/IEEE C37.90.1 * * +3.333V ± 2mV to +10V ± 5mV to 15ppm/mA ppm 120VAC 1500Vrms max ANSI/IEEE C37.90.1 100dB dB per Decade above H * * * * – 10mV to +10mV +3.333V 3mV/V – 5V to +5V – 30mV to +30mV +10.0V 3mV/V – 5V to +5V – 20mV to +20mV +10.0V 2mV/V – 5V to +5V – 10mV to +10mV +3.333V 3mV/V 0V to +5V – 30mV to +30mV +10.0V 3mV/V 0V to +5V – 20mV to +20mV +10.0V 2mV/V 0V to +5V 8B38-31 8B38-32 8B38-35 8B38-36 8B38-37 8B38-38 3Hz 3Hz 3Hz 3Hz 3Hz 3Hz – 10mV to +10mV +3.333V 3mV/V – 5V to +5V – 30mV to +30mV +10.0V 3mV/V – 5V to +5V – 20mV to +20mV +10.0V 2mV/V – 5V to +5V – 10mV to +10mV +3.333V 3mV/V 0V to +5V – 30mV to +30mV +10.0V 3mV/V 0V to +5V – 20mV to +20mV +10.0V 2mV/V 0V to +5V Sens. Output Range * * 70dB at 60Hz ppm ppm * ppm * rms 3Hz 160ms ± 5V Continuous Short to Ground ANSI/IEEE C37.90.1 * * Power Supply Sensitivity Mechanical Dimensions (h)(w)(d) 1.11” x 1.65” x 0.40” (28.1mm x 41.9mm x 10.2mm) * * +5VDC ± 5% 110mA No Exc. Load 150mA Full Exc. Load ± 75ppm/% NOTES: ❇ ontact factory or your local Dataforth sales office for maximum values. Same specification as B x. A between Input terminal and Input, , or terminals. A between Input and or terminals. A between and terminals. Includes linearity, hysteresis and repeatability. 8kHz 8kHz 8kHz 8kHz 8kHz 8kHz c * * Environmental to Operating Temperature Range to Storage Temperature Range 0 to 95% Noncondensing Relative Humidity ISM, Group 1 Emissions EN61000-6-4 Class A Radiated, Conducted ISM, Group 1 Immunity EN61000-6-2 Performance A ± 0.5% Span Error RF Performance B ESD, EFT 8B38-01 8B38-02 8B38-05 8B38-06 8B38-07 8B38-08 Input Range * * Power Supply Voltage Power Supply Current Bandwidth * ± 0.05% Span ± 0.02% Span rms 8kHz s Model * * * * * * * * * * * Installation Notes: . This uipment is Suitable for se in lass I, Division , Groups A, B, , D, or Non-Hazardous Locations Only. . ARNING xplosion Ha ard Substitution of Any omponents ay Impair Suitability for lass I, Division . 3.) WARNING - Explosion Hazard - Do Not Disconnect Equipment Unless Power Has Been Switched Off or The Area is nown to be Non Ha ardous. Visit our website www.dataforth.com ©1995-2017 Dataforth Corporation, All Rights Reserved 1 1 9 ISO9001:2008-Registered QMS 8 B Specifications
8B38-08 价格&库存
很抱歉,暂时无法提供与“8B38-08”相匹配的价格&库存,您可以联系我们找货
8B38-08
库存:5
