SCM7B47J-02A
SCM7B47J-02A
    DATAFORTH(Dataforth)
    ISOL LINEARIZED THERMOCOUPLE MOD
SCM7B47J-02A 数据手册
Isolated Process Control Signal Conditioning Products S C M 7 B SCM7B47 Isolated Linearized Thermocouple Input Modules Description SCM7B47 modules accept a single channel of input from Type J, K, T, , R, S, B, or N thermocouples. The signal is filtered, isolated, amplified, linearized, and converted to a high-level analog voltage for output to the process control system (Figure 1). Features • Interfaces to Type J, K, T, E, R, S, B and N Thermocouples Lineari ation is achieved by creating a non linear transfer function through the module itself; refer to AN505. This non-linear transfer function is configured at the factory and is designed to be e ual and opposite to the thermocouple non-linearity. • Linearizes Thermocouple Signals • Provides High-Level Voltage Outputs • 1500Vrms Transformer Isolation Cold junction compensation (CJC) is performed using an NTC thermistor see Additional S B Part Numbers section for P N and AN for further information externally mounted under the field side terminal bloc on the bac panel Figure . Open thermocouple detection is upscale using a 30nA current source in the input circuitry. • Accuracy, ± 0.06% to ± 0.16% of Span Typical • ANSI/IEEE C37.90.1 Transient Protection • Input Protected to 120Vrms Continuous Noise, m p p These modules incorporate a five pole filtering approach to maximi e both time and fre uency response by ta ing advantage of both Thomson Bessel and Butterworth characteristics. One pole of the filter is on the field side of the isolation barrier four are on the process control system side. H , rms H • 160dB CMRR • 85dB NMR at 60Hz, 80dB at 50Hz • Easy DIN Rail Mounting After the initial field side filtering, the input signal is chopped by a proprietary chopper circuit and transferred across the transformer isolation barrier, suppressing transmission of common mode spi es and surges. The signal is then reconstructed and filtered for process control system output. SA S ertified • CE and ATEX Compliant Modules accept a wide 14 - 35VDC power supply range (+24VDC nominal). Their compact packages (2.13”x1.705”x0.605” max) save space and are ideal for high channel density applications. They are designed for easy DIN rail mounting using any of the DIN bac panels. 1500Vrms Isolation Barrier R e fe r to A N 7 0 1 fo r V O U T to t e m p e r a t u r e oc n ev r si o n i n f o r m a t i o n Shield** + – X Surge Suppression, Protection, 2 LPF (1 pole), Open Detection and CJC 0 1 Thermocouple R T* Iso-Chopper II™ Amplifier Pat. Pending LPF (4 pole) and Linearization 4 5 VOUT COM Backpanel Term Block Field-Side *RT is a backpanel mounted NTC thermistor used as a cold junction compensation (CJC) sense element. 3 +V –V DC Supply **Shield ground-tie shown for ungrounded thermocouple configuration. F i g u r e 1 : S C M 7 B 4 7 B l o ck D ia g r a m 8 6 ©1995-2017 Dataforth Corporation, All Rights Reserved Process Control System-Side For information call 800-444-7644 ISO9001:2008-Registered QMS DC Supply/ Oscillator VS (14-35VDC) 5 COM Isolated Process Control Signal Conditioning Products Typical❇ at and Module Input Signal Range Current Resistance Normal Power Off Overload Protection Continuous Transient Output Signal Range(2) ffective Available Power(2) Resistance Protection Voltage/Current Limit CMV (Input-to-Output) Continuous Transient CMRR (50 or 60Hz) Accuracy(3) Stability to Gain Input Offset Zero Suppression Output Offset Noise Peak at 5MHz B/W RMS at 10Hz to 100kHz B/W Peak at 0.1Hz to 10Hz B/W CJC Accuracy(6), to ambient Open Input Response Open Input Detection Time Frequency and Time Response Bandwidth, – 3dB NMR (50/60Hz) Step Response, 90% Span Supply Voltage Current(2) Sensitivity Mechanical Dimensions (h)(w)(d) Environmental Operating Temperature Range Storage Temperature Range Relative Humidity Emissions EN61000-6-4 Radiated, Conducted Immunity EN61000-6-2 RF ESD, EFT Ordering Information D SCM7B47 Model‡ Thermocouple(1) (See Ordering Information) – 30nA min min 120Vrms max ANSI/IEEE C37.90.1 † 40mW Continuous Short to Ground ± 12V, ± 14mA 1500Vrms ANSI/IEEE C37.90.1 160dB (See Ordering Information) ppm . ± 0.005%( Vz)(4) . Span 1mV . RTI(5) Typ, max Upscale
SCM7B47J-02A 价格&库存
很抱歉,暂时无法提供与“SCM7B47J-02A”相匹配的价格&库存,您可以联系我们找货
SCM7B47J-02A
库存:12
