QT325G-11.0592MAHE-T
    QST(矽睿)
    SMD3225_4P
    无源晶振 10MHz ±30ppm 12pF 150Ω -40℃~+85℃
QT325G-11.0592MAHE-T 数据手册
QT325G MHz Crystal Fuel The Digital World Features ● ● ● ● Applications Frequency range : 8MHz to 54MHz Glass sealing, ceramic SMD package External dimensions (mm) L : 3.2 x W : 2.5 x H : 0.8 RoHS compliant Contains Pb, exempted by RoHS directive ● ● ● ● ● PC, TV, Game, Camera Notebook, Hard disk Computer peripherals Home electronics Consumer products Electrical Characteristics Item QT325G Frequency Range F0 8MHz ~ 54MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Operating Temperature Range Fstab TOTR ±30 ppm ±20 ppm ±10 ppm ±10 ppm ±50 ppm ±30 ppm ±20 ppm ±60 ppm -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C Shunt Capacitance C0 3pF Max. Drive Level DL 1 ~ 50μW (10μW Typ.) Load Capacitance CL 6pF, 7pF, 8pF, 9pF, 10pF 12pF, 16pF, 18pF, 20pF Aging Faging ±3 ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C at 25°C ± 3°C,first year Motional Resistance (ESR) Fundamental 8~9 9 ~ 10 10 ~ 12 12 ~ 16 16 ~ 54 Rev. 1.06 MHz MHz MHz MHz MHz 350Ω 200Ω 150Ω 100Ω 60Ω Max. Max. Max. Max. Max. Page 1 www.qstproducts.com QT325G MHz Crystal Fuel The Digital World Dimensions THK Note [1] Note: [1] THK = 0.8 ± 0.1mm except F0 = 8MHz. THK = 0.9 ± 0.1mm for F0 = 8MHz. Ordering Information QT325G - 27.000M A H E Frequency in Hz - T Packaging Method T Please contact us for available frequencies Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D E ± 30 ppm ± 20 ppm ± 10 ppm Frequency Stability (over Temp.) A D E T G H I K Rev. 1.06 ± 30 ppm ± 20 ppm ± 10 ppm ± 10 ppm ± 50 ppm ± 30 ppm ± 20 ppm ± 60 ppm B Y V C Q E I J 6 pF 7 pF 8 pF 9 pF 10 pF 12 pF 16 pF 18 pF ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -30°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +125°C ) Page 2 www.qstproducts.com QT325G MHz Crystal Fuel The Digital World Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 5°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.06 60 sec Page 3 Time (sec) www.qstproducts.com
QT325G-11.0592MAHE-T 价格&库存
很抱歉,暂时无法提供与“QT325G-11.0592MAHE-T”相匹配的价格&库存,您可以联系我们找货
  • 1+3.349081+0.43537
  • 10+2.9373810+0.38185
  • 25+2.7799525+0.36139
  • 50+2.6654050+0.34650
  • 100+2.55522100+0.33217
  • 250+2.41671250+0.31417
  • 500+2.31671500+0.30117
  • 1000+2.220821000+0.28870
库存:2500
  • 3000+2.076973000+0.27000
  • 6000+1.991086000+0.25884
  • 9000+1.942509000+0.25252
  • 15000+1.8830215000+0.24479
  • 21000+1.8448421000+0.23983
  • 30000+1.8052330000+0.23468
库存:2500
