SDE5-D10-O-Q6E-P-K
SDE5-D10-O-Q6E-P-K
    FESTO(费斯托)
    Module
    SDE5-D10-O-Q6E-P-K
SDE5-D10-O-Q6E-P-K 数据手册
Pressure sensor SDE5-D10-O-Q6E-P-K Part number: 542890 Data sheet Feature Value Symbol 00991887 Certification RCM compliance mark c UL us - Recognized (OL) CE marking (see declaration of conformity) As per EU EMC directive As per EU RoHS directive UKCA marking (see declaration of conformity) To UK instructions for EMC To UK RoHS instructions Note on materials RoHS-compliant Measured variable Relative pressure Method of measurement Piezoresistive pressure sensor Pressure measuring range initial value 0 bar Pressure measuring range end value 10 bar Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible Temperature of medium 0 °C ... 50 °C Ambient temperature 0 °C ... 50 °C Repetition accuracy in ± %FS 0.3 %FS Temperature co-efficient in ± %FS/K 0.05 %FS/K Switching output PNP Switching function Threshold value with fixed hysteresis Switching element function N/O contact Max. output current 100 mA Short-circuit protection yes DC operating voltage range 15 V ... 30 V Reverse polarity protection for all electrical connections Electrical connection 3-wire Cable as per EN 60947-5-2 Cable length 2.5 m Type of mounting With accessories Mounting position Any Pneumatic connection QS-6 Product weight 47 g Housing material PA POM Switching status indication LED yellow Setting range threshold value 0 % ... 100 % 10/21/22 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Degree of protection IP40 Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L 10/21/22 - Subject to change - Festo SE & Co. KG 2/2
SDE5-D10-O-Q6E-P-K 价格&库存
很抱歉,暂时无法提供与“SDE5-D10-O-Q6E-P-K”相匹配的价格&库存,您可以联系我们找货
