8B32-01
8B32-01
    DATAFORTH(Dataforth)
    CURRENT INPUT MODULE
8B32-01 数据手册
SensorLex® 8BIsolated IsolatedAnalog AnalogSignal SignalConditioning ConditioningProducts Products S C 8MB 5 B 8B32 Current Input Modules Description 8B modules are an optimal solution for monitoring real-world process signals and providing high-level signals to a data acquisition system. ach B module isolates, filters, and amplifies a process current input signal and provides an analog voltage output (Figure 1). Features • Accepts Milliamp Level Signals • High-Level Voltage Outputs Current to voltage conversion is accomplished internal to the module to ensure high accuracy. • 1500Vrms Isolation • ANSI/IEEE C37.90.1 Transient Protection Signal filtering is accomplished with a pole filter optimi ed for time and frequency response which provides 70dB of normal-mode rejection at H . One pole of this filter is on the field side of the isolation barrier for anti-aliasing, and the other two are on the system side. • Input Protection to 40VAC Continuous • 120dB CMR • 70dB NMR at 60Hz A special input circuit on the 8B32 module provides protection against accidental connection of power-line voltages up to 40VAC. Clamp circuits on the I/O and power terminals protect against harmful transients. • ± 0.05% Accuracy • ± 0.02% Linearity Isolation is provided by transformer coupling to suppress transmission of common mode spikes or surges. The module is powered from +5VDC, ± 5% . • C-UL-US Listed The modules are designed for installation in Class I, Division 2 hazardous locations and have a high level of immunity to environmental noise. • ATEX Compliance Pending Low Drift with Ambient Temperature • CE Compliant • Mix and Match Module Types on Backpanel Isolation Barrier –EXC 4 1 NC CJCn * Jn (1) – +EXC 2 3 Iso-Chopper™ Amplifier Pat. Pending LPF RCONV Surge Suppression and Protection LPF 6 7 VOUT COM NC +V IIN –V + Computer-Side Power Backpanel Terminal Block *Optional plug-in conversion resistor. (1) CJC Enable Jumper. Remains Installed for 8B32. F i g u r e 1 : 8 B 3 2 B l o ck +V´ –V´ 5 Isolated Field-Side Power D ia g r a m 1 0 6 ©1995-2017 Dataforth Corporation, All Rights Reserved For information call 800-444-7644 ISO9001:2008-Registered QMS Power Oscillator 7 +5VDC COM SensorLex® 8B Isolated Analog Signal Conditioning Products Typical❇ at TA and D power Module Input Range Input Resistance Normal Power Off Input Protection Continuous Transient CMV, Input to Output Transient, Input to Output CMR (50Hz or 60Hz) NMR Accuracy(1) Linearity Stability Offset Gain Noise Output, 100kHz Bandwidth, – 3dB Response Time, 90% Span Output Range Output Protection Transient Power Supply Voltage Power Supply Current Power Supply Sensitivity Mechanical Dimensions (h)(w)(d) Environmental Operating Temperature Range Storage Temperature Range Relative Humidity Emissions EN61000-6-4 Radiated, Conducted Immunity EN61000-6-2 RF ESD, EFT Ordering Information 8B32 0mA to 20mA or 4mA to 20mA Model Input Range Output Range 8B32-01 8B32-02 4mA to 20mA 0mA to 20mA 0V to +5V 0V to +5V 40VAC ANSI/IEEE C37.90.1 8 B Specifications 8 B 1500Vrms max ANSI/IEEE C37.90.1 120dB 70dB at 60Hz ± 0.05% Span ± 0.02% Span ppm ppm rms 3Hz 150ms 0V to +5V Continuous Short to Ground ANSI/IEEE C37.90.1 +5VDC ± 5% 30mA ± 75ppm/% 1.11” x 1.65” x 0.40” (28.1mm x 41.9mm x 10.2mm) to to 0 to 95% Noncondensing ISM, Group 1 Class A ISM, Group 1 Performance A ± 0.5% Span Error Performance B NOTES: ❇ ontact factory or your local Dataforth sales office for maximum values. Includes linearity, hysteresis and repeatability. Installation Notes: . This uipment is Suitable for se in lass I, Division , Groups A, B, , D, or Non-Hazardous Locations Only. . ARNING xplosion Ha ard Substitution of Any omponents ay Impair Suitability for lass I, Division . 3.) WARNING - Explosion Hazard - Do Not Disconnect Equipment Unless Power Has Been Switched Off or The Area is nown to be Non Ha ardous. Visit our website www.dataforth.com ©1995-2017 Dataforth Corporation, All Rights Reserved 1 0 7 ISO9001:2008-Registered QMS
8B32-01 价格&库存
很抱歉,暂时无法提供与“8B32-01”相匹配的价格&库存,您可以联系我们找货
8B32-01
库存:39
