SIEH-M12B-PS-S-L
SIEH-M12B-PS-S-L
    FESTO(费斯托)
    Module
    PROXIMITY SENSOR
SIEH-M12B-PS-S-L 数据手册
Proximity sensor SIEH-M12B-PS-S-L Part number: 150451 Data sheet Feature Value Conforms to standard EN 60947-5-2 Symbol 00991701 Certification C-Tick c UL us - Listed (OL) CE marking (see declaration of conformity) As per EU EMC directive Rated operating distance 4 mm Assured operating distance 3.24 mm Reduction factors Aluminum = 0.4 Stainless steel St 18/8 = 0.8 Copper = 0.4 Brass = 0.5 Steel St 37 = 1.0 Ambient temperature -25 °C ... 70 °C Repetition accuracy under constant conditions 0.2 mm Switching output PNP Switching element function N/O contact Hysteresis ≤0.36 mm Max. switching frequency 2500 Hz Max. output current 200 mA Voltage drop ≤2 V Inductive protective circuit Installed Short-circuit protection Pulsed DC operating voltage range 10 V ... 30 V Residual ripple ± 10% Idle current ≤10 mA Reverse polarity protection for all electrical connections Electrical connection 3-pin M12x1 Plug Size M12 Type of mounting With lock nut Mounting type Flush Product weight 30 g Housing material Brass PBTP Nickel-plated Switching status indication LED yellow Ambient temperature with flexible cable installation -5 °C ... 70 °C 10/21/22 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Degree of protection IP65 IP67 Corrosion resistance class (CRC) 2 - Moderate corrosion stress Selection of additional sensor information With increased switching distance Electrical output PNP Selection of sensor version Standard 10/21/22 - Subject to change - Festo SE & Co. KG 2/2
SIEH-M12B-PS-S-L 价格&库存
很抱歉,暂时无法提供与“SIEH-M12B-PS-S-L”相匹配的价格&库存,您可以联系我们找货
