KDS U-M124AM124A-T2100-015
    LEUZE(劳易测)
    INTERCONNECTION CABLE
KDS U-M124AM124A-T2100-015 数据手册
Technical data sheet Interconnection cable Part no.: 50140410 KDS U-M124AM124A-T2100-015 Contents - Technical data - Electrical connection - Circuit diagrams Figure can vary Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 1/3 Interconnection cable • Part no.: 50140410 • KDS U-M124AM124A-T2100-015 Technical data Connection Mechanical data Connection 1 Type of connection Connector Thread size M12 Type Female No. of pins 4 -pin Encoding A-coded Version Lock Width across flats 14.5 mm Bending cycles 1,000,000 Piece(s) Environmental data Ambient temperature, operation, flexible use -15 ... 90 °C Ambient temperature, operation, stationary use -35 ... 105 °C Axial Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Certifications IP 65 Degree of protection Connection 2 IP 67 Type of connection Connector Thread size M12 Type Male Handle body material TPU No. of pins 4 -pin Customs tariff number 85444290 Encoding A-coded eCl@ss 5.1.4 27279201 Version Axial eCl@ss 8.0 27279218 Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking eCl@ss 9.0 27060311 eCl@ss 10.0 27060311 eCl@ss 11.0 27060311 ETIM 5.0 EC001855 Lock NEMA 6P Classification Cable properties Number of conductors 4 Piece(s) ETIM 6.0 EC001855 Wire cross section 0.34 mm² ETIM 7.0 EC001855 AWG 22 Sheathing color Yellow Shielded No Silicone-free Yes Cable design Interconnection cable Cable length 1,500 mm Sheathing material TPE Wire insulation PVC Suitability for drag chains Yes Traverse rate Max. 3.3 m/s with horiz. traverse path of 5m and and max. acceleration of 5m/s² Electrical connection Connection 1 Type of connection Connector Thread size M12 Type Female No. of pins 4 -pin Encoding A-coded Version Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 2/3 Interconnection cable • Part no.: 50140410 • KDS U-M124AM124A-T2100-015 Electrical connection Connection 2 Type of connection Connector Thread size M12 Type Male Handle body material TPU No. of pins 4 -pin Encoding A-coded Version Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Circuit diagrams Wiring schematic 1 D 2 E 4 F 4 3 G 3 1 2 a Brown wire b White wire c Black wire d Blue wire Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 3/3
1. 物料型号:50140410 KDS U-M124AM124A-T2100-015 2. 器件简介:文档描述了一种连接电缆,适用于工业自动化和传感器连接。 3. 引脚分配:电缆两端都有M12的4针A编码连接器,具有自锁功能,推荐扭矩为0.5Nm。 4. 参数特性: - 导线数量:4根 - 导线截面积:0.34mm² - AWG:22 - 护套颜色:黄色 - 无屏蔽 - 无硅 - 电缆设计:适用于拖链 - 电缆长度:1.5米 - 护套材料:TPE - 导线绝缘:PVC - 最大横向移动速度:3.3米/秒 5. 功能详解:文档提供了电气连接的详细描述,包括连接器类型、尺寸和编码。 6. 应用信息:电缆适用于拖链,具有很高的弯曲周期(1,000,000次)。 7. 封装信息:电缆的防护等级为IP65、IP67和NEMA 6P,适用于灵活和固定的使用环境。
KDS U-M124AM124A-T2100-015 价格&库存
很抱歉,暂时无法提供与“KDS U-M124AM124A-T2100-015”相匹配的价格&库存,您可以联系我们找货
