Proximity sensor
SIEN-M18B-PS-S-L
Part number: 150419
Data sheet
Feature
Value
Conforms to standard
EN 60947-5-2
Symbol
00991701
Certification
RCM compliance mark
c UL us - Listed (OL)
CE marking (see declaration of conformity)
As per EU EMC directive
Note on materials
RoHS-compliant
Rated operating distance
5 mm
Assured operating distance
4.05 mm
Reduction factors
Aluminum = 0.4
Stainless steel St 18/8 = 0.8
Copper = 0.4
Brass = 0.5
Steel St 37 = 1.0
Ambient temperature
-25 °C ... 70 °C
Repetition accuracy
0.25 mm
Switching output
PNP
Switching element function
N/O contact
Hysteresis
≤0.55 mm
Max. switching frequency
2000 Hz
Max. output current
200 mA
Voltage drop
2V
Short-circuit protection
Pulsed
DC operating voltage range
10 V ... 30 V
Residual ripple
+/- 20 %
Idle current
≤10 mA
Reverse polarity protection
for all electrical connections
Electrical connection
3-pin
M12x1
Plug
Size
M18x1
Type of mounting
With lock nut
Tightening torque
20 Nm
Mounting type
Flush
Product weight
43 g
Housing material
Brass
PBTP
Nickel-plated
Switching status indication
LED yellow
10/21/22 - Subject to change - Festo SE & Co. KG
1/2
Feature
Value
Ambient temperature with flexible cable installation
-5 °C ... 70 °C
Degree of protection
IP67
Contamination level
3
Selection of additional sensor information
With standard switching distance
Electrical output
PNP
Selection of sensor version
Standard
2/2
很抱歉,暂时无法提供与“SIEN-M18B-PS-S-L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+921.516951+119.56607
