KDS U-M124WM124A-T2100-003
    LEUZE(劳易测)
    INTERCONNECTION CABLE
KDS U-M124WM124A-T2100-003 数据手册
Technical data sheet Interconnection cable Part no.: 50140429 KDS U-M124WM124A-T2100-003 Contents - Technical data - Electrical connection - Circuit diagrams Figure can vary Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 1/3 Interconnection cable • Part no.: 50140429 • KDS U-M124WM124A-T2100-003 Technical data Connection Mechanical data Connection 1 Type of connection Connector Thread size M12 Type Female No. of pins 4 -pin Encoding A-coded Version Lock Width across flats 14.5 mm Bending cycles 1,000,000 Piece(s) Environmental data Ambient temperature, operation, flexible use -15 ... 90 °C Ambient temperature, operation, stationary use -35 ... 105 °C Angled Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Certifications IP 65 Degree of protection Connection 2 IP 67 Type of connection Connector Thread size M12 Type Male Handle body material TPU No. of pins 4 -pin Customs tariff number 85444290 Encoding A-coded eCl@ss 5.1.4 27279201 Version Axial eCl@ss 8.0 27279218 Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking eCl@ss 9.0 27060311 eCl@ss 10.0 27060311 eCl@ss 11.0 27060311 ETIM 5.0 EC001855 Lock NEMA 6P Classification Cable properties Number of conductors 4 Piece(s) ETIM 6.0 EC001855 Wire cross section 0.34 mm² ETIM 7.0 EC001855 AWG 22 Sheathing color Yellow Shielded No Silicone-free Yes Cable design Interconnection cable Cable length 300 mm Sheathing material TPE Wire insulation PVC Suitability for drag chains Yes Traverse rate Max. 3.3 m/s with horiz. traverse path of 5m and and max. acceleration of 5m/s² Electrical connection Connection 1 Type of connection Connector Thread size M12 Type Female No. of pins 4 -pin Encoding A-coded Version Angled Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 2/3 Interconnection cable • Part no.: 50140429 • KDS U-M124WM124A-T2100-003 Electrical connection Connection 2 Type of connection Connector Thread size M12 Type Male Handle body material TPU No. of pins 4 -pin Encoding A-coded Version Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Circuit diagrams Wiring schematic 1 D 2 E 4 F 4 3 G 3 1 2 a Brown wire b White wire c Black wire d Blue wire Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 3/3
KDS U-M124WM124A-T2100-003 价格&库存
很抱歉,暂时无法提供与“KDS U-M124WM124A-T2100-003”相匹配的价格&库存,您可以联系我们找货
