8.5000.095W.2000.P0004.0011
    KüBLER
    INCREMENTAL ENCODER 2000 PPR
8.5000.095W.2000.P0004.0011 数据手册
Incremental encoders Standard optical Sendix 5000 / 5020 (shaft / hollow shaft) Push-Pull / RS422 / Open collector Due to their sturdy bearing construction in Safety-Lock™ Design, the Sendix 5000 and 5020 offer high resistance against vibration and installation errors. The rugged housing, high protection level of up to IP67, as well as the wide temperature range of -40 °C up to +85 °C, make this product range the perfect encoder for all applications. 24one delivery promise. RoHS 2/22 Safety-LockTM High rotational speed -40°... +85°C IP Temperature range High protection level High shaft load capacity Shock / vibration resistant Magnetic field proof Short-circuit proof Reverse polarity protection Optical sensor Robust performance Many variants • Increased resistance against shock, vibrations and tolerance of installation errors, elimination of machine downtime and repairs thanks to sturdy bearing construction in “Safety-LockTM Design”. • Suitable connection variant for every specific case: cable connection with different standard lengths, M12 (5- or 8-pin), M23 (12-pin), MIL (7- or 10-pin) and Sub-D connector. • Ensures highest safety against field breakdowns and is thus suitable also for outside use thanks to its resistant die-cast housing and protection up to IP67. • Undetachable clamping ring on hollow shaft encoders. • Wide temperature range, -40 °C ... +85 °C. In addition: Variants with connector fitted in the cable – for error-free electrical connection to your control. • Reliable mounting in a wide variety of installation situations: comprehensive and proven fixing possibilities. • Compatible with all US and European standards. • Wide range of standard pulse ranges up to max. 5000 pulses per revolution. Technology in detail Robust Safety-Lock™ bearing structure Cables with fitted connector Undetachable clamping ring Tangential cable outlet Slotted clamping ring + slotted shaft © Fritz Kübler GmbH, subject to errors and changes. 11/2021 www.kuebler.com/usa 1 Incremental encoders Standard optical Order code Shaft version Sendix 5000 / 5020 (shaft / hollow shaft) 8.5000 . X X X X . XXXX . P XX X X Type a b c d e f g h Push-Pull / RS422 / Open collector We offer for all encoders configured with the underlined preferential options our free of charge 24one delivery promise. Orders placed on working days before 9AM CET are manufactured and ready for dispatch the same day and within 10 days in overseas. The 24one delivery promise is limited to 20 pieces per order. a Flange 5 = synchro flange, IP66/IP67 ø 50.8 mm [2“] 6 = synchro flange, IP65 ø 50.8 mm [2“] A = synchro flange, IP66/IP67 ø 58 mm [2.28“] B = synchro flange, IP65 ø 58 mm [2.28“] 7 = clamping flange, IP66/IP67 ø 58 mm [2.28“] 8 = clamping flange, IP65 ø 58 mm [2.28“] 3 = square flange, IP66/IP67 52.3 mm [2.06“] 4 = square flange, IP65 52.3 mm [2.06“] C = square flange, IP66/IP67 63.5 mm [2.5“] D = square flange, IP65 63.5 mm [2.5“] 1 = servo flange, IP66/IP67 ø 50.8 mm [2“] 2 = servo flange, IP65 ø 50.8 mm [2“] E = servo flange, IP66/IP67 ø 63.5 mm [2.5“] F = servo flange, IP65 ø 63.5 mm [2.5“] G = Euro flange, IP66/IP67 ø 115 mm [4.53“] 1) b Shaft (ø x L), with flat 1 = ø 6 x 10 mm [0.24 x 0.39“] 2 = ø 1/4 x 5/8“ (6.35 x 15.875 mm) 7 = ø 1/4 x 7/8“ 6 = ø 8 x 15 mm [0.32 x 0.59“] 3 = ø 10 x 20 mm [0.39 x 0.79“] 4 = ø 3/8 x 5/8“ (9.5 x 15.875 mm) 8 = ø 3/8 x 7/8“ B = ø 11 x 33 mm [0.43 x 1.30“], with feather key shaft slot 2) 5 = ø 12 x 20 mm [0.47 x 0.79“] c Output circuit (with inverted signal) / power supply 4 = RS422 / 5 V DC 1 = RS422 / 5 ... 30 V DC 2 = Push-Pull (7272 compatible) / 5 ... 30 V DC 5 = Push-Pull / 10 ... 30 V DC 8 = Push-Pull (7272 compatible), without capacitor / 5 ... 30 V DC 3) 3 = Open collector / 5 ... 30 V DC d Type of connection – cable 1 = axial cable, 1 m [3.28 ft] PVC A = axial cable, special length PVC *) 2 = radial cable, 1 m [3.28 ft] PVC B = radial cable, special length PVC *) Type of connection – connector P = axial M12 connector, 5-pin 4) R = radial M12 connector, 5-pin 4) 3 = axial M12 connector, 8-pin 4 = radial M12 connector, 8-pin 7 = axial M23 connector, 12-pin 8 = radial M23 connector, 12-pin Y = radial MIL connector, 10-pin W = radial MIL connector, 7-pin 4) 9 = radial MIL connector, 6-pin 4) Type of connection – connector with cable L = radial cable with M12 connector, 8-pin, special length PVC *) M = radial cable with M23 connector, 12-pin, special length PVC *) N = radial cable with Sub-D connector, 9-pin, special length PVC *) *) Available special lengths (connection types A, B, L, M, N: 0.3, 0.5, 1, 2, 3, 4, 5, 6, 8, 10, 12, 15, 20 m [0.98, 1.64, 3.28, 6.56, 9.84, 13.12, 16.40, 19.69, 26.25, 32.80, 39.37, 49.21, 65.62 ft] order code expansion .XXXX = length in dm ex.: 8.5000.814A.1024.0030.PXXXX (for cable length 3 m) e Pulse rate 1, 2, 4, 5, 10, 12, 14, 20, 25, 28, 30, 32, 36, 50, 60, 64, 80, 100, 120, 125, 150, 180, 200, 240, 250, 256, 300, 342, 360, 375, 400, 500, 512, 600, 625, 720, 800, 900, 1000, 1024, 1200, 1250, 1500, 1800, 2000, 2048, 2500, 3000, 3600, 4000, 4096, 5000 (e.g. 100 pulses => 0100) f Special output signal formats 00 = standard output other = see page 7 g Capacitor 0 = standard A = no bypass capacitor (vector motor) (only valide with output circuits 1, 3, 4, 5) h Special connector pin configuration 0 = standard wiring other = see page 6 Optional on request - other pulse rates - Ex 2/22 (not for type of connection L, M, N) 5) - surface protection salt spray Salt spray tested as standard type (deliverable as from 1 unit) 8.5000.73X4.XXXX-C 1) Only in conjunction with shaft type B. 2) Only in conjunction with flange type G. 3) Attention: no CE types! 4) Without inverted signal. 5) For the cable connection type, cable material PUR. 2 www.kuebler.com/usa © Fritz Kübler GmbH, subject to errors and changes. 11/2021 Incremental encoders Standard optical Order code Hollow shaft Sendix 5000 / 5020 (shaft / hollow shaft) 8.5020 . X X X X . XXXX . P XX X X Type a b c d e f g h Push-Pull / RS422 / Open collector We offer for all encoders configured with the underlined preferential options our free of charge 24one delivery promise. Orders placed on working days before 9AM CET are manufactured and ready for dispatch the same day and within 10 days in overseas. The 24one delivery promise is limited to 20 pieces per order. a Flange 1 = with spring element, long, IP66/IP67 2 = with spring element, long, IP65 3 = with torque stop, long, IP66/IP67 4 = with torque stop, long, IP65 7 = with stator coupling, IP66/IP67 ø 65 mm [2.56“] 8 = with stator coupling, IP65 ø 65 mm [2.56“] C = with stator coupling, IP66/IP67 ø 63 mm [2.48“] D = with stator coupling, IP65 ø 63 mm [2.48“] 5 = with stator coupling, IP66/IP67 ø 57.2 mm [2.25“] 6 = with stator coupling, IP65 ø 57.2 mm [2.25“] b Hollow shaft 1 = ø 6 mm [0.24“] 2 = ø 1/4“ 9 = ø 8 mm [0.32“] 4 = ø 3/8“ 3 = ø 10 mm [0.39“] 5 = ø 12 mm [0.47“] 6 = ø 1/2“ A = ø 14 mm [0.55“] 8 = ø 15 mm [0.59“] 7 = ø 5/8“ c Output circuit (with inverted signal) / power supply 4 = RS422 / 5 V DC 1 = RS422 / 5 ... 30 V DC 2 = push-pull (7272 compatible) / 5 ... 30 V DC 5 = push-pull / 10 ... 30 V DC 8 = Push-Pull (7272 compatible), without capacitor / 5 ... 30 V DC 1) 3 = open collector / 5 ... 30 V DC d Type of connection – cable 1 = radial cable, 1 m [3.28‘] PVC A = radial cable, special length PVC *) E = tangential cable, 1 m [3.28‘] PVC F = tangential cable, special length PVC *) Type of connection – connector R = radial M12 connector, 5-pin 2) 2 = radial M12 connector, 8-pin 4 = radial M23 connector, 12-pin 6 = radial MIL connector, 7-pin 2) 7 = radial MIL connector, 10-pin Type of connection – connector with cable H = tangential cable, 0.3 m [0.98 ft] PVC, incl. M12 connector, 8-pin for central fastening L = tangential cable with M12 connector, 8-pin, special length PVC *) M = tangential cable with M23 connector, 12-pin, special length PVC *) N = tangential cable with Sub-D connector, 9-pin, special length PVC *) *) Available special lengths (connection types A, F, L, M, N): 0.3, 0.5, 1, 2, 3, 4, 5, 6, 8, 10, 12, 15, 20 m [0.98, 1.64, 3.28, 6.56, 9.84, 13.12, 16.40, 19.69, 26.25, 32.80, 39.37, 49.21, 65.62 ft] order code expansion .XXXX = length in dm ex.: 8.5020.855A.1024.0030.PXXXX (for cable length 3 m) e Pulse rate 1, 2, 4, 5, 10, 12, 14, 20, 25, 28, 30, 32, 36, 50, 60, 64, 80, 100, 120, 125, 150, 180, 200, 240, 250, 256, 300, 342, 360, 375, 400, 500, 512, 600, 625, 720, 800, 900, 1000, 1024, 1200, 1250, 1500, 1800, 2000, 2048, 2500, 3000, 3600, 4000, 4096, 5000 (e.g. 100 pulses => 0100) f Special output signal formats 00 = standard output other = see page 7 g Capacitor 0 = standard A = no bypass capacitor (vector motor) (only valide with output circuits 1, 3, 4, 5) h Special connector pin configuration 0 = standard wiring other = see page 6 Optional on request - other pulse rates - Ex 2/22 (not for type of connection E, F, H, L, M, N) 3) - surface protection salt spray Salt spray tested as standard type (deliverable as from 1 unit) 8.5020.18X2.XXXX-C 8.5020.1AX2.XXXX-C 1) Attention: no CE types! 2) Without inverted signal. 3) For the cable connection type, cable material PUR. © Fritz Kübler GmbH, subject to errors and changes. 11/2021 www.kuebler.com/usa 3 Incremental encoders Standard optical Sendix 5000 / 5020 (shaft / hollow shaft) Push-Pull / RS422 / Open collector Mounting accessory for shaft encoders Coupling Order no. bellows coupling ø 19 mm [0.75“] for shaft 6 mm [0.24“] 8.0000.1102.0606 bellows coupling ø 19 mm [0.75“] for shaft 10 mm [0.39“] 8.0000.1102.1010 Mounting accessory for hollow shaft encoders Dimensions in mm [inch] Cylindrical pin, long Order no. 8.0010.4700.0000 with fixing thread for flange with spring element (flange type 1 + 2) SW7 [0,28] M4 0,16 5 0,2 R7 30 1,18 Isolation / adapter inserts for hollow shaft encoders order code 8.5020.X8XX.XXXX 4 m8 0,16 8 0,31 0 ,2 8 Thermal and electrical isolation of the encoders (Temperature range -40 °C ... +115 °C [-40 °F ... +239 °F] ) Isolation inserts prevent currents from passing through the encoder bearings. These currents can occur when using inverter controlled three-phase or AC vector motors and considerably shorten the service life of the encoder bearings. In addition the encoder is thermally isolated as the plastic does not transfer the heat to the encoder. D1 Isolation insert 8.0010.4021.0000 8.0010.4020.0000 8.0010.4023.0000 8.0010.4025.0000 8.0010.4022.0000 8.0010.4024.0000 8.0010.4026.0000 6 mm 8 mm 10 mm 12 mm 1/4“ 15 [0.59] 15 [0.59] 15,5 [0.61] D1 H7 3/8“ 1/2“ 45,2 [1.78] 47,2 [1.86] Connection technology Order no. Cordset, pre-assembled M12 female connector with coupling nut,8-pin,A coded, straight single ended 2 m [6.56‘] PVC cable M23 female connector with coupling nut,12-pin,cw single ended 2 m [6.56‘] PVC cable Connector, self-assembly 05.00.6041.8211.002M 8.0000.6901.0002 05.CMB 8181-0 M12 female connector with coupling nut,8-pin,A coded, straight (metal) M23 female connector with coupling nut,12-pin,cw 8.0000.5012.0000 MIL female connector with coupling nut,10-pin 8.0000.5062.0000 Further Kübler accessories can be found at: kuebler.com/accessories Further Kübler cables and connectors can be found at: kuebler.com/connection-technology Technical data Mechanical characteristics IP65 12000 min-1 min-1 (continuous) IP66/IP67 6000 min-1 3000 min-1 (continuous) Weight approx. 0.4 kg [14.11 oz] Mass moment of inertia shaft version approx. 1.8 x 10-6 kgm2 hollow shaft version approx. 6 x 10-6 kgm2 Working temperature range -40 °C 1) ... +85 °C [-40 °F 1) ... +185 °F] Maximum speed 6000 Starting torque at 20 °C [68 °F] Shaft load capacity IP65 < 0.01 Nm IP66/IP67 < 0.05 Nm radial 100 N axial 50 N Protection acc. to EN 60529 without shaft seal IP65 with shaft seal IP66/IP67 Material shaft stainless steel Shock resistance acc. to EN 60068-2-27 3000 m/s2, 6 ms 2) Vibration resistance acc. to EN 60068-2-6 300 m/s2, 10 ... 2000 Hz 3) 1) With connector: -40 °C [-40 °F], cable fixed: -30 °C [-22 °F], cable moved: -20 °C [-4 °F]. 2) For MIL connectors: 2500 m/ s2 3) For MIL connectors: 100 m/ s2 4 www.kuebler.com/usa © Fritz Kübler GmbH, subject to errors and changes. 11/2021 Incremental encoders Standard optical Sendix 5000 / 5020 (shaft / hollow shaft) Push-Pull / RS422 / Open collector Electrical characteristics Output circuit RS422 RS422 Push-pull Push-pull Push-pull Open collector (TTL compatible) (TTL compatible) (HTL/TTL universal, (7272 compatible, (7273) 7272 compatible) without capacitor) Order code 1 4 5, 7 2 8 3 Power supply 5 ... 30 V DC 5 V DC (±5 %) 10 ... 30 V DC 5 ... 30 V DC 5 ... 30 V DC 5 ... 30 V DC Power consumption (no load) typ. 40 mA max. 90 mA typ. 40 mA  max. 90 mA typ. 50 mA  max. 100 mA typ. 50 mA  max. 100 mA typ. 50 mA  max. 100 mA 100 mA Permissible load / channel max. +/- 20 mA max. +/- 20 mA max. +/- 20 mA max. +/- 20 mA max. +/- 20 mA 20 mA sink at 30 V DC Pulse frequency max. 300 kHz max. 300 kHz max. 300 kHz max. 300 kHz 1) max. 300 kHz Signal level min. 2.5 V max. 0.5 V min +V - 1.0 V max. 0.5 V min. +V - 2.0 V max. 0.5 V min. +V - 2.0 V max. 0.5 V Rising edge time tr max. 200 ns max. 200 ns max. 1 μs max. 1 μs max. 1 μs Falling edge time tf max. 200 ns max. 200 ns max. 1 μs max. 1 μs max. 1 μs Short circuit proof outputs 2) yes 3) yes yes yes 3) yes no yes no no HIGH min. 2.5 V LOW max. 0.5 V yes 3) Reverse polarity protection yes of the power supply max. 300 kHz no UL approval file 224618 CE compliant acc. to EMC guideline 2014/30/EC RoHS guideline 2011/65/EU Terminal assignment – Standard wiring Output circuit Type of connection Cable (isolate unused wires individually before initial start-up) 5000: 1, 2, 3, 4, 5, 8 5020: Output circuit Output circuit Output circuit 0 V +V 0 Vsens +Vsens A WH BN GY PK RD BU Signal: R Pin: Signal: 2, H 2), L Pin: Output circuit Type of connection 5000: 1, 2, 3, 4, 5, 8 5020: Output circuit Output circuit Signal: 7 Pin: Signal: 6 Pin: Type of connection Output circuit Type of connection 5000: 1, 2, 3, 4, 5, 8 5020: 0 H BU RD shield 0 V +V A B 0 H 1 2 3 4 5 PH 1) 0 V +V A 1 2 3 B 4 5 6 H 0 H 7 8 PH 4) 0 V +V 0 Vsens +Vsens A B 0 10 12 11 2 5 6 8 1 3 4 PH 4) 0 V +V F D +Vsens A E A B G B H 0 H C I J MIL connector, 7-pin W 5000: 9 1, 3, 4, 5, 8 PK MIL connector, 10-pin Y Type of connection 5000: 1, 3, 4, 5, 8 5020: GY M23 connector, 12-pin 5000: 7, 8, M Signal: 1, 2, 3, 4, 5, 8 5020: 4, M Pin: YE M12 connector, 8-pin 3, 4, L Type of connection B GN M12 connector, 5-pin P, R Type of connection 5000: 1, 2, 3, 4, 5, 8 5020: Signal: Core colour: Type of connection 5000: 1, 2, 3, 4, 5, 8 5020: 1, 2, A, B 1, A, E, F B 0 H B C G B 0 H D C 0 V +V F D +Vsens A E A 0 V +V A A B E 0 V +V A 9 5 1 MIL connector, 6-pin Signal: Pin: Sub-D connector, 9-pin N Signal: N Pin: B 6 2 7 0 H 3 8 PH 4) 1) Max. recommended cable length 30 m [98.43 ft]. 2) If power supply correctly applied. 3) Only one channel allowed to be shorted-out: at +V= 5 V DC, short-circuit to channel, 0 V, or +V is permitted. at +V= 5 ... 30 V DC, short-circuit to channel or 0 V is permitted. 4) PH = shield is attached to connector housing. © Fritz Kübler GmbH, subject to errors and changes. 11/2021 www.kuebler.com/usa 5 Incremental encoders Standard optical Sendix 5000 / 5020 (shaft / hollow shaft) Push-Pull / RS422 / Open collector Terminal assignment – Special connector pin configuration Output circuit Order code h 7 1, 2, 3, 4, 5, 8 Order code h Output circuit 1 1, 3, 4, 8 Order code h Output circuit 4 1, 3, 4, 8 Order code h Output circuit 6 1, 2, 3, 4, 5, 8 Order code h Output circuit 9 1, 2, 3, 4, 5, 8 Type of connection M12 connector, 8-pin 5000: 3, 4, L Signal: 5020: 2, H2), L Pin: Type of connection 0V +V A 7 2 1 3 0 Signal: 0V +V A Pin: A, F B D 0V +V A F D A 0V +V A F D A H B 0V +V A B 0 H 3 1 4 2 5 PH 1) 4 5 B 0 H E C H 6 PH 1) 8 MIL connector, 6-pin 5000: 9 Type of connection MIL connector, 7-pin 5000: W Signal: 5020: 6 Pin: Type of connection MIL connector, 10-pin 5000: Y Signal: 5020: 7 Pin: Type of connection M12 connector, 5-pin 5000: B Signal: P, R 5020: R Pin: +V: Encoder power supply +V DC 0 V: Encoder power supply ground GND (0 V) 0 Vsens / +Vsens: Using the sensor outputs of the encoder, the voltage present can be measured and if necessary increased accordingly. A, : B, : 0, : PH H: B C B H E G I C B 0 H J G Incremental output channel A Incremental output channel B Reference signal Plug connector housing (shield) Top view of mating side, male contact base 9 1 2 3 5 3 4 1 M12 connector, 5-pin H H HA A A G GIG I IB B B J J J F FF C CC E EDE D D MIL connector, 10-pin 2 8 5 4 6 1 7 M12 connector, 8-pin F E F FA A A G GB G B B E E D 8 2 DC D C C MIL connector, 7-pin 3 10 4 7 12 11 6 5 M23 connector, 12-pin F E A A A F FB B B E EC C C D D D MIL connector, 6-pin (1) (2) (6) (3) (7) (4) (8) (5) (9) Sub-D connector, 9-pin 1) PH = shield is attached to connector housing. 2) With type of connection H shield is not attached to connector housing. 6 www.kuebler.com/usa © Fritz Kübler GmbH, subject to errors and changes. 11/2021 Incremental encoders Standard optical Sendix 5000 / 5020 (shaft / hollow shaft) Push-Pull / RS422 / Open collector Special output signal formats All Kübler encoders come standard with six channels where A leads B in the clockwise direction and the standard index is gated with A & B. The tolerance of the wave form affects the control and, in some cases, may affect the smoothness of system operation. Wave form tolerances tr = rise time tf = fall time A leads B B leads A when the shaft is rotated in the clockwise direction viewing the shaft or collet end. when the shaft is rotated in the clockwise direction viewing the shaft or collet end. This is the Kübler standard. This format applies to the pin key codes listed below. This format applies to the pin key codes listed below. Order code f Order code f Z gated with A & B. This is the Kübler standard. Z is 90° wide. 04 Z gated with A & B. Z is 90° wide. 01 Z gated with B. Z is 180° wide. 05 Z gated with B. Z is 180° wide. 02 Z gated with A. Z is 180° wide. 06 Z gated with A. Z is 180° wide. 03 Z ungated. Z is 330° to 360° wide. 07 Z ungated. Z is 330° to 360° wide. 08 Z is 180° wide 09 Z gated with . Z is 180° wide. 11 Z is a minimum with of 270° (electrical degrees). 10 Z is a negative marker gated with B. Z is 180° wide. 13 Z gated with . Z is 180° wide. 12 Z has a minimum width of 270°. © Fritz Kübler GmbH, subject to errors and changes. 11/2021 www.kuebler.com/usa 7 Incremental encoders Standard optical 1 Sendix 5000 / 5020 (shaft / hollow shaft) 3 4 5 2 Push-pull / RS422 7/ Open collector 6 8 Dimensions shaft version Ausführung mit MIL-Stecker DimensionsAin mm [inch] Synchro flange, ø 50.8 [2] Flange type 5 and 6 A 35,2 1,39 46,7 1,84 1 3 x M3, 6 [0.24] deep 30,45 1,2 B B 3 0,12 1 40 1,57 3,3 0,13 L D 71,4 2,81 71,4 2,81 57,4 2,26 D 50,8 2 0° 12 C 47 1,85 30 h7[1,18] 3x 90,4 3,56 3 0,12 C 53,2 2,09 D 43,7 1,72 47 1,85 64 2,52 Passung L h7 10[0,39] h7 15[0,59] 1 1 f7 20[0,79] h7 20[0,79] h7 5/8" h7 5/8" h8 7/8" h8 7/8" 2 3 3 3 4 4 4 = Check item Prüfmaß This document is property of Fritz Kübler GmbH, use of this document without written permission is prohibited. Das Urheberrecht an dieser Zeichnung verbleibt uns. Sie darf ohne unsere vorherige Zustimmung weder 4 Scale: Maßstab: Format: Date 2 1 0 2810 2480 Rev. St. Revision 20.06.16 los 01.08.13 al 23.07.09 da Rev. No./Änd. Nr. Date Name Drawn by Bearb. Approv. by Gepr. hl Z1036 L 75 2,95 48 1,89 L 48 1,89 48 1,89 L D F E Fit h7 h7 h7 h7 F h7 h7 h8 h8 1 D 1 www.kuebler.com/usa A B B B C C C D D D E E E Sheet: Sheet: Sheet: 1 /1 1 /1 1 /1 1 50 1,97 50 1,97 50 1,97 1 D 36 f8[1,42] 58 D2,28 D 36 f8[1,42] C 2,28 3658 f8[1,42] 58 2,28 8 E A 1 / 1 Ausführung Ausführung Ausführung mit MIL-Stecker mit MIL-Stecker mit MIL-Stecker 10 0,39 10 0,39 10 0,39 37 1,46 37 1,46 37 1,46 E A Sheet/ Blatt Drawingnumber:/Zeichnungsnummer: Fritz Kübler GmbH Zähl- und Sensortechnik 78054 VS-Schwenningen 10 0,39 10 0,39 10 0,39 21 0,83 21 0,83 21 0,83 D 6 [0.24] 8 [0.32] 10 [0.39] 12 [0.47] 1/4“ F 3/8“ 1/4“ 3/8“ 8 0° 12 3x 0° 12 3x 0° 12 3x D 8 13,313,3 0,520,52 13,3 0,52 1 D 8 8.5000.5XX3/Y 8.5000.6XX4/Y 38,538,5 1,521,52 38,5 1,52 B B 1 3 x M3,B 6 [0.24] deep C Type: A3 Name 10.09.04 Clamping flange, ø 58 [2.28] Flange type 7 and 8 C Material: Werkstoff: 1:1 7 Typ: 7 5000 7 Size: Title:/Benennung: Surface: Oberfläche: +0,2 Ra 1,6 3 General tolerances Allgemeintol. DIN ISO 6 2768-m-H 5vervielfältigt 5 noch Dritten 5 zugänglich gemacht6oder 6 auf andere Weise mißbraucht werden. Zuwiederhandlungen verpflichten zu Schadenersatz. -0,2 2 E 1 M3, 6 [0,24] tief 1 46,546,5 46,5 1,83 1,831,83 D Passung DPassung Passung L L L 6[0,24]6[0,24] 6[0,24] h7 h7 8[0,32] 8[0,32] 8[0,32] h7 h7 10 [0.39] 10[0,39] 10[0,39]10[0,39] f7 f7 15 [0.59] 12[0,47] 12[0,47]12[0,47] h7 h7 20 [0.79]1/4" 1/4" h7 1/4" h7 3/8" h7 20 [0.79]3/8" 3/8" h7 1/4" 1/4" h8 1/4" h8 5/8“ 3/8" 3/8" h8 3/8" h8 5/8“ 7/8“ 7/8“ 2 2 2 94 3,7 1 D 6[0,24] L 8[0,32] 10 [0.39] 10[0,39] 15 [0.59] 12[0,47] 1/4" 20 [0.79] 3/8" 20 [0.79] 1/4" 2 2 3/8" 5/8“ 5/8“ 7/8“ 7/8“ 94 3,7 75 2,95 A Fit h7 h7 h7 h7 1 h7 h7 h8 A h8 75 2,95 94 3,7 E D 6 [0.24] 8 [0.32] 10 [0.39] 12 [0.47] 1/4“F 3/8“ 1/4“ A 3/8“ MIL-connector version MIL-connector version L 10[0,39] h7 10[0,39]10[0,39] 1 M3, 1 6 M3, [0,24] 1 6 M3, [0,24] tief6 [0,24] tief tief 15[0,59] h7 15[0,59]15[0,59] 20[0,79] f7 20[0,79]20[0,79] 20[0,79] h7 20[0,79]20[0,79] 5/8" h7 5/8" 5/8" 5/8" h7 5/8" 5/8" 7/8" h8 7/8" 7/8" 7/8" h8 7/8" 7/8" Approv. by: Approv. by:Date: Approv.Date: by: Material: Material: Date: Material: This document This document is property This isdocument property of Fritz Kübler of is property Fritz GmbH Kübler ofGmbH Fritz Kübler GmbH The reproduction, The reproduction, distribution The reproduction, distribution and utilization and distribution utilization of this and document ofutilization this document as well of this asas document the well as the as well as the communication communication of itscommunication contents of its contents to others of its to without contents othersexpress without to others authorization express without authorization express is prohibited. authorization is prohibited.is prohibited. OffendersOffenders will be held will Offenders liable be held for will liable thebe payment for held theliable payment of damages. for the ofpayment damages. of damages. Size: Size: Scale: Size: Scale: Scale: family: Product family: Product Product family: All rights reserved All rights reserved in the All rights event in the reserved of event the grant inofthe the ofevent a grant patent, of ofthe autility patent, grant model of utility a patent, ormodel design. utility or design. model or design. A3 General General tolerances tolerances DIN ISO DIN ISO 2768-m-H 2768-m-H General tolerances DIN ISO 2768-m-H Title: 3 3 3 2810 2810 2+0,2 -0,2 2 +0,2 2480 2 2480 1 1 1 0 Ra1404 0 1404 0 1,6 = Check item = Check item = Check item Prüfmaß Prüfmaß Prüfmaß -0,2 3 3 3 4 4 4 Ra 1,6 +0,2 -0,2 Ra 1,6 Rev.Nr. Rev.Nr. Rev.Nr. ECN Title: A3 1:1 A31:15000 1:1 5000 8.5000.8XX1/Y 8.5000.8XX1/Y 8.5000.8XX1/Y 20.06.1620.06.16 los 20.06.16 los al 01.08.13 al01.08.1301.08.13 Drawing Drawing number: number: Drawing number: 23.07.0923.07.09 da 23.07.09 da 16.07.0916.07.09 da 16.07.09 da 1404 los al da da ECN Drawn ECN by Drawn by Date Drawn Date by www.kuebler.com Date www.kuebler.com www.kuebler.com 2810 2480 5000 Title: 8.5000.7XX2/Y 8.5000.7XX2/Y 8.5000.7XX2/Y Z1129 Z1129Z1129 Fritz Kübler FritzGmbH Kübler Fritz GmbH Kübler GmbH © Fritz Kübler GmbH, subject to errors and changes. 11/2021 Incremental encoders Standard optical 1 2 3 4 5 6 Sendix 5000 / 5020 (shaft / hollow shaft) 7 8 Push-pull / RS422 / Open collector Dimensions shaft version A Ausführung mit MIL-Stecker A Dimensions in mm [inch] Synchro flange, ø 58 [2.28] Flange type A and B 38,5 1,52 33,75 1,33 1 3 x M4,B 6 [0.24] deep max.50 1,97 42 1,65 C 0° 12 3x L 94 3,7 75 2,95 1 D 58 2,28 50 h7 [1,97] C B D max.21 0,83 3 0,12 D 56,5 2,22 3 0,12 4 0,16 47 1,85 E D 6 [0.24] 8 [0.32] 10 [0.39] 12 [0.47] F 1/4“ 3/8“ 1/4“ 3/8“ Fit h7 h7 h7 h7 h7 1 h7 h8 1 h8 L 10 [0.39] 15 [0.59] 20 [0.79] 20 [0.79] 5/8“ 5/8“ 7/8“ 7/8“ MIL-connector version E D Passung L 6[0,24] h7 10[0,39] 8[0,32] h7 15[0,59] 10[0,39] f7 20[0,79] 12[0,47] h7 20[0,79] 1/4" h7 5/8" 3/8" h7 5/8" 1/4" h8 7/8" 3/8" h8 7/8" 2 1 3xM4, 6 [0,24] tief = Check item Prüfmaß -0,2 3 4 3 4 General tolerances Allgemeintol. DIN ISO 2768-m-H Surface: Oberfläche: +0,2 5 Ra 1,6 2 This document is property of Fritz Kübler GmbH, use of this document without written permission is prohibited. Das Urheberrecht an dieser Zeichnung verbleibt uns. Sie darf ohne unsere vorherige Zustimmung weder vervielfältigt noch Dritten zugänglich gemacht oder auf andere Weise mißbraucht werden. Zuwiederhandlungen verpflichten zu Schadenersatz. 3 2 1 0 Rev. St. Revision 2810 2480 Rev. No./Änd. Nr. 20.06.16 01.08.13 23.07.09 16.07.09 Date los 6al da da Date Drawn by Bearb. Approv. by Gepr. 12.10.05 1:1 A3 Name hl Material: Werkstoff: Type: 5000 Typ: Title:/Benennung: 8.5000.AXX2/Y 7 8.5000.BXX1/Y 8 Drawingnumber:/Zeichnungsnummer: Fritz Kübler GmbH Zähl- und Sensortechnik 78054 VS-Schwenningen Sheet/ Blatt Z1130 Name 1 / 1 Ausführung mit MIL-Stecker A Square flange, 63.5 [2.5] Flange type C and D Scale: Maßstab: Size: Format: A 31 1,22 26,25 1,03 B L 7,5 0,3 D 21 0,83 96,75 3,81 77,75 3,06 52,4 2,06 max.50 1,97 D 31,75 h7 [1,25] 50,8 2 C 63,5 2,5 5, 5 0, 22 B C 7,5 0,3 7,1 0,28 D 49 1,93 39,5 1,56 MIL-connector version D 6 [0.24]E 8 [0.32] 10 [0.39] 12 [0.47] 1/4“ 3/8“ F 1/4“ 3/8“ Fit h7 h7 h7 h7 h7 h7 h8 h8 1 L 10 [0.39] 15 [0.59] 20 [0.79] 20 [0.79] 5/8“ 5/8“ 7/8“ 7/8“ D Passung L 6[0,24] h7 10[0,39] 8[0,32] h7 15[0,59] 10[0,39] f7 20[0,79] 12[0,47] h7 20[0,79] 1/4" h7 5/8" 3/8" h7 5/8" 1/4" h8 7/8" 3/8" h8 E = Check item Prüfmaß 7/8" -0,2 Ra 1,6 2 © Fritz Kübler GmbH, subject to errors and changes. 11/2021 3 4 This document is property of Fritz Kübler GmbH, use of this document without written permission is prohibited. Das Urheberrecht an dieser Zeichnung verbleibt uns. Sie darf ohne unsere vorherige Zustimmung weder vervielfältigt noch Dritten zugänglich gemacht oder auf andere Weise mißbraucht werden. Zuwiederhandlungen verpflichten zu Schadenersatz. General tolerances Allgemeintol. DIN ISO 2768-m-H Surface: Oberfläche: +0,2 Date 2 1 0 Rev. St. Revision 2810 2480 Rev. No./Änd. Nr. 20.06.16 los 01.08.13 al 23.07.09 da Date Name Drawn by Bearb. Approv. by Gepr. 12.10.05 Scale: Maßstab: 1:1 Size: Format: A3 Name hl Material: Werkstoff: Type: 5000 Typ: Title:/Benennung: 8.5000.CXX1/Y 8.5000.DXX2/Y Drawingnumber:/Zeichnungsnummer: Fritz Kübler GmbH Zähl- und Sensortechnik 78054 VS-Schwenningen Sheet/ Blatt Z1131 www.kuebler.com/usa 1 / 1 9 Incremental encoders Standard optical Sendix 5000 / 5020 (shaft / hollow shaft) 1 2 Dimensions shaft version 3 4 Push-pull / RS422 / Open collector 5 6 7 8 Dimensions in mm [inch] Euro A flange, ø 115 [4.53] Flange type G A 61,6 2,43 6 0,24 115 4,53 11 0,43 100 ±0,1 [3,94] B 31 1,22 4 0,16 C 6,6 0,26 50,8 2 33 1,3 58 2,28 11 k6 [0,43] 85 h5 [3,35] B C 36 1,42 6,4 0,25 1 Feather key attached 7 0,28 16 0,63 D ° 3 0,12 60 54,6 2,15 6x D 13,25 0,52 8 0,31 E E 1 2 3 4 5 F Tabelle Servo flange, øKeine 50.8 [2] Flange type 1 and 2 A 1 215342Set beigelegt -0,2 13,25 0,52 2 3 General Scale: Material: tolerances 7 Maßstab: Werkstoff: 8 Type: Allgemeintol. 5000 1:1 Typ: DIN ISO Size: A3 Title:/Benennung: 2768-m-H Ausführung mit MIL-Stecker Format: Surface: Oberfläche: +0,2 Date 2 1 0 Ra 1,6 1 4-40 UNC x 6 [0.24] deep 1 2 6-32 UNC x 5 [0.2] deep This document is property of Fritz Kübler GmbH, use of this document without written permission is prohibited. Das Urheberrecht an dieser Zeichnung verbleibt uns. Sie darf ohne unsere vorherige Zustimmung weder vervielfältigt noch Dritten zugänglich gemacht oder auf andere Weise mißbraucht werden. Zuwiederhandlungen verpflichten zu Schadenersatz. 6 = Check item Prüfmaß 4 2480 2436 Rev. St. Revision 28.5.13 10.1.13 12.7.10 Rev. No./Änd. Nr. Date Drawn by Bearb. Approv. by Gepr. al ih da 35,2 12.7.10 1,39 Name da 8.5000.GBX7.XXXX A Incremental Encoder Drawingnumber:/Zeichnungsnummer: Fritz Kübler GmbH Zähl- und Sensortechnik 78054 VS-Schwenningen Z1469 Name 71,4 2,81 50,8 2 D L B 45° 31,75 h7 [1,25] 0° 47 1,85 2 4x90° 50,8 2 2 3x1 46 1,81 1 B 90,4 3,56 1 C C 38,1 1,5 41,3 1,63 3,3 0,13 2,54 0,1 3,3 0,13 53,2 2,09 2,54 0,1 43,7 1,72 D D 60,7 2,39 MIL-connector version D 6 [0.24] 8 [0.32] E 10 [0.39] 12 [0.47] 1/4“ 3/8“ 1/4“ 3/8“ F Fit h7 h7 h7 h7 h7 h7 h8 h8 L 10 [0.39] D 15 [0.59]6[0,24] 8[0,32] 20 [0.79]10[0,39] 20 [0.79]12[0,47] 5/8“ 1/4" 3/8" 5/8“ 1/4" 7/8“ 3/8" 7/8“ Passung L h7 10[0,39] h7 15[0,59] f7 20[0,79] h7 20[0,79] h7 5/8" h7 5/8" h8 7/8" h8 7/8" E 1 4-40 UNC x 0,24" deep 2 6-32 UNC x 0,21"deep = Check item Prüfmaß -0,2 Ra 1,6 10 www.kuebler.com/usa 1 2 3 4 This document is property of Fritz Kübler GmbH, use of this document without written permission is prohibited. Das Urheberrecht an dieser Zeichnung verbleibt uns. Sie darf ohne unsere vorherige Zustimmung weder vervielfältigt noch Dritten zugänglich gemacht oder auf andere Weise mißbraucht werden. Zuwiederhandlungen verpflichten zu Schadenersatz. General tolerances Allgemeintol. DIN ISO 2768-m-H Surface: Oberfläche: +0,2 Date 1 0 Rev. St. Revision 2810 2480 Rev. No./Änd. Nr. 20.06.16 los 01.08.13 al Date Drawn by Bearb. Approv. by Gepr. 20.06.13 Scale: Maßstab: 1:1 Size: Format: A3 Name al Fritz Kübler GmbH Zähl- und Sensortechnik Material: Werkstoff: Type: 5000 Typ: Title:/Benennung: 8.5000.1XX3/4/Y 8.5000.2XX3/4/Y Drawingnumber:/Zeichnungsnummer: © Fritz Kübler78054 GmbH, subject toZ1541 errors and changes. 11/2021 VS-Schwenningen Name Sheet/ Blatt 1 / 1 Sheet/ Blatt 1 / 1 Incremental encoders Standard optical 1 4 5 Sendix35000 / 5020 (shaft / hollow shaft) 2 6 8 Push-pull / RS4227 / Open collector Dimensions shaft version A Dimensions in mm [inch] A Ausführung mit MIL-Stecker Square flange, 52.3 [2.06] Flange type 3 and 4 35,2 1,39 13,25 0,52 max.50 1,97 B L 3,3 0,13 D max.21 0,83 7,7 0,3 E D 6 [0.24] 8 [0.32] 10 [0.39] 12 [0.47] F 1/4“ 3/8“ 1/4“ 3/8“ 1 1 Fit h7 h7 h7 h7 h7 h7 h8 h8 L 10 [0.39] 15 [0.59] 20 [0.79] 20 [0.79] 5/8“ 5/8“ 2 7/8“ 7/8“ 2 D Passung L h7 10[0,39] 8[0,32] h7 15[0,59] C 3,3 0,13 50,8 2 D 53,2 2,09 43,7 1,72 6[0,24] 91,15 3,59 52,3 2,06 44,45 1,75 2 72,15 2,84 1 D C 31,75 h7 [1,25] 1 ø 4 [0.16] B 2 6-32 UNC x 5 [0.2] deep MIL-connector version E 10[0,39] f7 20[0,79] 12[0,47] h7 20[0,79] 1 1/4" h7 5/8" 3/8" h7 5/8" 2 1/4" h8 7/8" 3/8" h8 7/8" 4 [0,16] 6-32 UNC x 0,21"deep = Check item Prüfmaß -0,2 3 4 3 4 This document is property of Fritz Kübler GmbH, use of this document without written permission is prohibited. Das Urheberrecht an dieser Zeichnung verbleibt uns. Sie darf ohne unsere vorherige Zustimmung weder vervielfältigt noch Dritten zugänglich gemacht oder auf andere Weise mißbraucht werden. Zuwiederhandlungen verpflichten zu Schadenersatz. General tolerances Allgemeintol. DIN ISO 2768-m-H Surface: Oberfläche: +0,2 Date 5 Ra 1,6 6 1 0 Rev. St. Revision 2810 2480 20.06.16 los 01.08.13 al Rev. No./Änd. Nr. Date Drawn by Bearb. Approv. by Gepr. Scale: Maßstab: 1:1 Size: Format: A3 Name 19.06.13 al Material: Werkstoff: Type: 5000 Typ: Title:/Benennung: 8.5000.3XX1/2/Y 7 8.5000.4XX1/2/Y8 Drawingnumber:/Zeichnungsnummer: Fritz Kübler GmbH Zähl- und Sensortechnik 78054 VS-Schwenningen Sheet/ Blatt Z1540 Name 1 / 1 Ausführung mit MIL-Stecker A A Servo flange, ø 63.5 [2.5] Flange type E and F 31 1,22 1 6-32 UNC x 5 [0.2] deep 13,25 0,52 3x 12 0° C 7,5 0,3 49 1,93 2,65 0,1 D 96,75 3,81 L 7,5 0,3 77,75 3,06 47,63 1,88 46 1,81 1 D 31,75 h7 [1,25] 58,87 2,32 C B 63,5 2,5 B D 2,65 0,1 39,5 1,56 56,5 2,22 DE 6 [0.24] 8 [0.32] 10 [0.39] 12 [0.47] 1/4“ F 3/8“ 1/4“ 3/8“ Fit h7 h7 h7 h7 h7 h7 h8 h8 1 LD 6[0,24] 10 [0.39] 8[0,32] 15 [0.59] 10[0,39] 12[0,47] 20 [0.79] 1/4" 20 [0.79] 3/8" 5/8“ 1/4" 3/8" 5/8“ 7/8“ 7/8“ MIL-connector version Passung L h7 10[0,39] h7 15[0,59] f7 20[0,79] h7 20[0,79] h7 5/8" h7 5/8" h8 7/8" h8 2 © Fritz Kübler GmbH, subject to errors and changes. 11/2021 E 1 6-32 UNC = Check item Prüfmaß 7/8" -0,2 Ra 1,6 3 4 This document is property of Fritz Kübler GmbH, use of this document without written permission is prohibited. Das Urheberrecht an dieser Zeichnung verbleibt uns. Sie darf ohne unsere vorherige Zustimmung weder vervielfältigt noch Dritten zugänglich gemacht oder auf andere Weise mißbraucht werden. Zuwiederhandlungen verpflichten zu Schadenersatz. General tolerances Allgemeintol. DIN ISO 2768-m-H Surface: Oberfläche: +0,2 Date 1 0 Rev. St. Revision 2810 2480 Rev. No./Änd. Nr. 20.06.16 los 01.08.13 al Date Name Drawn by Bearb. Approv. by Gepr. 20.06.13 Scale: Maßstab: 1:1 Size: Format: A3 Name al Material: Werkstoff: Type: 5000 Typ: Title:/Benennung: 8.5000.EXX3/4/Y 8.5000.FXX3/4/Y Drawingnumber:/Zeichnungsnummer: Fritz Kübler GmbH Zähl- und Sensortechnik 78054 VS-Schwenningen Z1542 www.kuebler.com/usa Sheet/ Blatt 1 / 1 11 Incremental encoders Standard optical Sendix 5000 / 5020 (shaft / hollow shaft) Push-pull / RS422 / Open collector Dimensions hollow shaft version Dimensions in mm [inch] Flange with spring element, long Flange type 1 and 2 1 2 3 4 5 6 7 1 3 x M3, 6 [0.24] deep 2 Slot spring element, A recommendation: cylindrical pin DIN 7, ø 4 [0.16] 8 Ausführung MIL-Stecker A 36,2 1,43 3 Recommended torque for the clamping ring 0.6 Nm 37,9 1,49 21 0,82 33,7 1,33 34,2 1,35 Fit H7 D Passung H7 H7 6[0,24] 8[0,32] H7 H7 10[0,39] H7 H7 12[0,47] H7 H7 14[0,55] H7 15[0,59] H7 H7 1/4" H7 H7 3/8" H7 H7 1/2" H7 H7 H7 5/8" H7 Recommended fit for shaft on customer side is g6. E www.kuebler.com/usa This document is property of Fritz Kübler GmbH The reproduction, distribution and utilization of this document as well as the communication of its contents to others without express authorization is prohibited. Offenders will be held liable for the payment of damages. All rights reserved in the event of the grant of a patent, utility model or design. General tolerances DIN ISO 2768-m-H = Check item Prüfmaß -0,2 2 für 8.5020 Passung H7 8[0,32] H7 10[0,39] H7 12[0,47] H7 14[0,55] H7 15[0,59] H7 1/4" H7 3/8" H7 1/2" H7 5/8" H7 A3 4 3 2 1 los al da da 2810 2480 4 1404 Rev.Nr. ECN Drawn by 28.06.16 17.06.13 22.07.09 5 07.12.07 Date 1:1 90,4 3,56 5020 8.5020.23X2/7 Incremental Encoder Drawing number: Fritz Kübler GmbH www.kuebler.com 6 Z1022 7 Sheet: 1 /1 40 1,57 75 2,95 86 3,39 für 8.KIH50 D Product family: 22 0,87 D 6[0,24] 4 Ra 1,6 Material: Scale: 11,4 0,45 3 3 Date: Size: Title: 46 1,81 1 +0,2 Approv. by: 49,6 1,95 Fit C H7 H7 H7 H7 H7 H7 D H7 H7 H7 H7 E 4,9 0,19 B 4mm 3 empfohlenes Drehmoment für Klemmring 0,6Nm D 1 Recommended torque for the clamping ring 0.6 Nm D 6 [0.24] 8 [0.32] 10 [0.39] 12 [0.47] 14 [0.55] 15 [0.59] 1/4“ 3/8“ 1/2“ 5/8“ 2 Nur Drehmomentstütze Empfehlung: Zylinderstift nach DIN7, 2 A D MIL-connector version 34,2 1,35 Flange with torque stop, long Flange type 3 and 4 54,2 2,13 1 M3, 6 [0,24] tief 44,7 1,76 1 43,7 1,72 2 42 1,65 44,7 1,76 Recommended fit for shaft on customer side is g6. 12 D 1 37,5 1,48 D 6 [0.24] 8 [0.32] 10 [0.39] E 12 [0.47] 14 [0.55] 15 [0.59] 1/4“ 3/8“ 1/2“ F 5/8“ C 2,4 0,09 3 D 71,4 2,81 0° 12 3x 46 1,81 32 1,26 33 1,3 max. 50,8 2 31,75 1,25 C 14 0,55 B 3,99 -0,02 [0,16] B 30 1,18 Passung 8[0,32] H7 10[0,39] H7 12[0,47] H7 14[0,55] H7 15[0,59] H7 50,8 2 1 1 GmbH, Empfohlenes Drehmoment für11/2021 Klemmring 0,6Nm © Fritz Kübler subject to errors and changes. This document is property of Fritz Kübler GmbH, use Material: Incremental encoders Standard optical Sendix 5000 / 5020 (shaft / hollow shaft) Push-pull / RS422 / Open collector Dimensions hollow shaft version Dimensions in mm [inch] 74 2,91 Flange with stator coupling, ø 65 [2.56] Flange type 7 and 8 13,3 0,52 7 0,28 37 1,46 46 1,81 1 Fit H7 H7 H7 H7 H7 H7 H7 H7 H7 H7 3x 12 0° 30 ° D 6 [0.24] 8 [0.32] 10 [0.39] 12 [0.47] 14 [0.55] 15 [0.59] 1/4“ 3/8“ 1/2“ 5/8“ 46 1,81 1 Recommended torque for the clamping ring 0.6 Nm 50,8 2 65 2,56 34,2 1,35 50,2 1,98 4,3 0,1 7 D Recommended fit for shaft on customer side is g6. 1 2 3 4 5 6 7 Klemmringø0,6Nm 1 empfohlenes FlangeDrehmoment with statorfürcoupling, 63 [2.48] Flange type C and D 40° H7 D [0.24] H7 8 [0.32] H710 [0.39] 12 [0.47] 14 [0.55] 15 [0.59] 1/4“ 3/8“ 1/2“ 5/8“ H7 6 1/2" 5/8" 12 0, 1 3, B Fit H7 H7 H7 H7 H7 H7 C H7 H7 H7 H7 This document is property of Fritz Kübler GmbH The reproduction, distribution and utilization of this document as well as the communication of its contents to others without express authorization is prohibited. Offenders will be held liable for the payment of damages. All rights reserved in the event of the grant of a patent, utility model or design. General tolerances DIN ISO 2768-m-H Approv. by: Date: Material: Size: Scale: Product family: A3 Title: 1:1 8.5020.83X2 = Check item Prüfmaß 34,2 1,35 0,5 0,02 37,5 1,48 1 -0,2 +0,2 1 0 Ra 1,6 45,2 1,78 2 5020 68 H7 3/8" 2, H7 1/4" Rev.Nr. ECN Fritz Kübler GmbH www.kuebler.com Date Drawn by 3 Drawing number: 28.06.16 18.06.13 los al 2810 2480 68 H7 15[0,59] D H7 14[0,55] 63 2,48 12[0,47] 25 ° 1 73,5 2,89 H7 30 1,18 10[0,39] 55 2,17 4 Z1537 Sheet: 1 /1 5 6 Recommended fit for shaft on customer side is g6. A 1 Recommended torque for the clamping ring 0.6 Nm E C 13,25 0,52 D Passung D Passung 6[0,24] H7 10[0,39] 8[0,32] H7 7 0,2812[0,47] H7 10[0,39] H7 15[0,59] H7 1/4" H7 D H7 12[0,47] H7 1 14[0,55] H7 3/8" H7 15[0,59] H7 1/2" H7 1/4" H7 3/8" H7 1/2" H7 5/8" H7 65 2,56 H7 10[0,39] H7 12[0,47] H7 14[0,55] H7 15[0,59] H7 This document is property of Fritz Kübler GmbH The reproduction, distribution and utilization of this document as well as the communication of its contents to others without express authorization is prohibited. Offenders will be held liable for the payment of damages. All rights reserved in the event of the grant of a patent, utility model or design. General tolerances DIN ISO 2768-m-H 2 3 34,2 4 Ra 1,6 +0,2 Approv. by: Date: Materia Size: Scale: Produc A3 Title: 1 0 los al 2810 2480 Rev.Nr. ECN Drawn by 21.06.16 18.06.13 Date Drawi Fritz Kübler GmbH www.kuebler.com D 50,2 Recommended fit for shaft on customer side is g6. E D Passung 6[0,24] H7 8[0,32] H7 502 8.5020.C3X2 D © Fritz Kübler GmbH, subject to errors and changes. 11/2021 1:1 8.KIH50.DXX2 = Check item Prüfmaß -0,2 1 57,15 2,25 Passung 8[0,32] 3,2 0 ,13 Fit H7 H7 F H7 H7 H7 H7 H7 H7 H7 H7 für 8.KIH50 30 ° D 6 [0.24] 8 [0.32] 10 [0.39] 12 [0.47] 14 [0.55] 15 [0.59] 1/4“ 3/8“ 1/2“ 5/8“ B für 8.5026 3x 12 0° für 8.5020 31,5 1,24 1 Empfohlenes Drehmoment für Klemmring 0,6Nm 54,6 2,15 D Flange with stator coupling, ø 57.2 [2.25] Flange type 5 and 6 50,8 2 8[0,32] A 1 Passung Recommended torque for the H7 clamping ring 0.6 Nm 30 1,18 D 6[0,24] www.kuebler.com/usa 13 Z1 Incremental encoders Standard optical Sendix 5000 / 5020 (shaft / hollow shaft) Push-pull / RS422 / Open collector Dimensions hollow shaft version Dimensions in mm [inch] Flange with spring element, long and tangential cable outlet Type of connection E, F and H 1 3 x M3, 6 [0.24] deep 2 Slot spring element, recommendation: cylindrical pin DIN 7, ø 4 [0.16] 3 Recommended torque for the clamping ring 0.6 Nm 4 Shield is not applied on connector 46,3 1,82 33,7 [1.33] 0° 12 42 1,65 D 33 1,3 max. 50,8 2 31,75 1,25 3x 14 0,55 35,8 1,41 3,99 -0,02 [0,16] 37,9 [1.49] 39,1 1,54 2,4 0,09 3 2 1 0.24] tief Federelement lung: Zylinderstift nach DIN7 4 4 lenes Drehmoment für Klemmring 0,6Nm st nicht am Stecker aufgelegt D 6 [0.24] 8 [0.32] 10 [0.39] 12 [0.47] 14 [0.55] 15 [0.59] 1/4“ 3/8“ 1/2“ 5/8“ Passung H7 H7 H7 H7 H7 H7 H7 H7 H7 H7 Fit H7 H7 H7 H7 H7 H7 H7 H7 H7 H7 Recommended fit for shaft on customer side is g6. 14 www.kuebler.com/usa This document is property of Fritz Kübler GmbH The reproduction, distribution and utilization of this document as well as the communication of its contents to others without express authorization is prohibited. Offenders will be held liable for the payment of damages. All rights reserved in the event of the grant of a patent, utility model or design. General tolerances DIN ISO 2768-m-H = Check item Prüfmaß -0,2 Ra 1,6 +0,2 Approv. by: Date: Material: Size: Scale: Product family: A3 Title: 3 2 1 0 Rev.Nr. 2810 2480 los al da da ECN Drawn by 15.06.16 18.06.13 12.07.10 23.07.09 Date 1:1 5020 8.5020.25XE/H Drawing number: Fritz Kübler GmbH www.kuebler.com Z1341 Sheet: 1 /1 © Fritz Kübler GmbH, subject to errors and changes. 11/2021
物料型号: - Sendix 5000 / 5020,分别对应轴和空心轴版本。
器件简介: - Sendix 5000和5020增量式编码器,具有Safety-Lock™设计,提供高抗震动和安装误差能力。坚固的外壳,高达IP67的防护等级,以及-40°C至+85°C的宽温度范围,使这些编码器适用于所有应用场景。
引脚分配: - 提供多种连接选项,包括不同标准长度的电缆连接、M12 (5或8针)、M23 (12针)、MIL (7或10针) 和Sub-D连接器。还有带预装连接器的变体,以实现与控制设备的无误电气连接。
参数特性: - 高转速、宽温度范围、高防护等级、高轴负载、抗冲击/振动、抗磁场、防短路、防反极性、光学传感器保护。
功能详解: - 编码器具有多种变体,包括对冲击、振动的增强抵抗能力,以及对安装误差的容忍度,从而减少机器停机时间和维修需求。此外,编码器还具有多种标准脉冲范围,最高可达每转5000个脉冲。
应用信息: - 编码器适用于各种安装环境,具有广泛的安装选项。空心轴编码器上的不可拆卸夹紧环,以及与所有美国和欧洲标准兼容的特性。
封装信息: - 提供详细的电缆和连接器配置选项,包括轴的尺寸和长度,以及特殊长度的PVC电缆选项。
8.5000.095W.2000.P0004.0011 价格&库存
很抱歉,暂时无法提供与“8.5000.095W.2000.P0004.0011”相匹配的价格&库存,您可以联系我们找货
