1XTV26000PEA
1XTV26000PEA
    KDS(大真空)
    SMD3225_4P
    有源晶振 SMD3225_4P
1XTV26000PEA 数据手册
1. Device Name VC-TCXO 2. Model Name DSA321SDN 3. Nominal Frequency 26.000 MHz 4. Mass 0.03g max. 5. Absolute Maximum Ratings 1 2 Item Supply Voltage Storage Temperature Range Symbol VCC T_STG Rating -0.3~+4.6 -40~+85 unit V °C 6. Recommended Operating Conditions 1 2 3 4 Item Supply Voltage Load Impedance (resistance part) (parallel capacitance) Control Voltage Range Operating Temperature Range Symbol VCC LOAD_R LOAD_C VCONT T_OPR min. +3.135 9 9 +0.5 -30 typ. +3.3 10 10 +1.5 - max. +3.465 11 11 +2.5 +85 unit V kΩ pF V °C 7. Electrical Characteristics (TA=-30~+85°C, LOAD_R//C=10kΩ//10pF, VCC=+3.3V, VCONT=+1.5V, unless otherwise noted) Item 1 2 3 4 Current Consumption Output Level Symmetry Frequency Stability 1.Tolerance 2.vs Temperature 5 6 7 3.vs Supply Voltage 4.vs Load Variation 5.vs Aging Start Up Time Frequency Control 1.Control Range 2.Input Resistance SSB Phase Noise Conditions GND level (DC cut) After 2 times reflow Ref. to Nominal Frequency TA=-30~+85°C Ref. to Frequency (TA=+25°C) VCC=+3.3V±5% LOAD_R//C=(10kΩ//10pF)±10% TA=Room ambient @90% of final Vout level VCONT=+1.5V±1.0V Relative to f0 level offset 1kHz min. 0.8 40/60 Limits typ. - max. +1.5 60/40 unit Notes mA VP-P % 1 - - ±1.5 ppm 2,3 - - ±2.5 ppm - - ±0.2 ±0.2 ±1.0 2.0 ppm ppm ppm/year ms ±28 500 - - -135 ppm kΩ dBc/Hz 4 Notes 1. Clipped sine wave (DC-coupled) 2. TA=+25°C 3. Please leave after reflow in 2h or more at room ambient. 4. Positive slope (Frequency becomes high in proportion to frequency control voltage.) TITLE Remark DSA321SDN TYPE SPECIFICATION Date 2016/05/26 Spec. No. ZZ05682 DAISHINKU CORP. Rev. Page - 1/2 DM-Z0002: Style-010 8. Outline, Pin Connections Outline (1) Pin Connections Pin No. #1 #2 #3 #4 (2) D (3) Marking (1) Frequency (2) Model code (3) Date code #1 Index Connection VCONT GND Output VCC 26.00 (MHz, 4digits) AN Year (1digit) +Week (2digits) e.g.2016/01/01 601 unit: mm Dimensional Tolerance: ±0.15 (Unless otherwise noted) 9. Measurement Circuit 1000pF T.P. mA #3 #4 + 10000pF Power Supply Vcc VC-TCXO V VCONT - Output GND #1 VCONT LOAD_C LOAD_R #2 LOAD_R=10kΩ LOAD_C=10pF (Include Jig stray capacitance) TITLE Remark DSA321SDN TYPE SPECIFICATION Date 2016/05/26 Spec. No. ZZ05682 DAISHINKU CORP. Rev. Page - 2/2 DM-Z0002: Style-010
1XTV26000PEA 价格&库存
很抱歉,暂时无法提供与“1XTV26000PEA”相匹配的价格&库存,您可以联系我们找货
