Serial No. : 2017-0584
DATE : 2017/06/05
CRYSTAL OSCILLATOR
ITEM :
DSA321SDN
TYPE :
12.800MHz
NOMINAL FREQUENCY :
1XTV12800PDA
SPEC No. :
RECEIPT
DATE
RECEIVED
(signature)
(name)
General Manufacture of Quartz Devices
1389 Shinzaike, Hiraoka-cho, Kakogawa, Hyogo
675-0194 Japan
Phone (81)79-425-3141 Fax (81)79-425-1134
http://www.kds.info/index_en.htm
C.ENG.
ENG.
Serial No.2017-0584
1. Device Name
VC-TCXO
2. Model Name
DSA321SDN
3. Nominal Frequency
12.800 MHz
4. Mass
0.03g max.
5. Absolute Maximum Ratings
1
2
Item
Supply Voltage
Storage Temperature Range
Symbol
VCC
T_STG
Rating
-0.3~+4.6
-40~+85
unit
V
C
6. Recommended Operating Conditions
1
2
3
4
Item
Supply Voltage
Load Impedance (resistance part)
(parallel capacitance)
Control Voltage Range
Operating Temperature Range
Symbol
VCC
LOAD_R
LOAD_C
VCONT
T_OPR
min.
+2.85
9
9
+0.5
-40
typ.
+3.0
10
10
+1.5
max.
+3.15
11
11
+2.5
+85
unit
V
kΩ
pF
V
C
7. Electrical Characteristics
(TA=-40~+85C, LOAD_R//C=10kΩ//10pF, VCC=+3.0V, VCONT=+1.5V, unless otherwise noted)
Item
1
2
3
4
5
Current Consumption
Output Level
Symmetry
Harmonics
Frequency Stability
1.Tolerance
2.vs Temperature
6
7
8
Notes
3.vs Supply Voltage
4.vs Load Variation
5.vs Aging
Start Up Time
Frequency Control
1.Control Range
2.Input Resistance
SSB Phase Noise
Conditions
GND level (DC cut)
After 2 times reflow
Ref. to nominal frequency
TA=-40~+85C
Ref. to frequency (TA=+25C)
VCC=+3.0V±5%
LOAD_R//C=(10kΩ//10pF)±10%
TA=Room ambient
@90% of final Vout level
VCONT=+1.5V±1.0V
Relative to f0 level offset 1kHz
min.
0.8
40/60
Limits
typ
max.
+1.5
60/40
-5
mA
VP-P
dBc
±1.5
ppm
±2.5
ppm
±0.2
±0.2
±1.0
2.0
ppm
ppm
ppm/year
ms
±9
500
±15
-130
ppm
kΩ
dBc/Hz
unit
Notes
1
2,3
4
1. Clipped sine wave (DC-coupled)
2. TA=+25C
3. Please leave after reflow in 2h or more at room ambient.
4. Positive slope (Frequency becomes high in proportion to frequency control voltage.)
TITLE
Remark
DSA321SDN TYPE SPECIFICATION
Date
2017/06/05
Spec. No.
Rev.
1XTV12800PDA
DAISHINKU CORP.
Page
1/13
DM-Z0002: Style-010 Ver.1
Serial No.2017-0584
8. Outline, Pin Connections
Outline
Pin Connections
(1)
Pin No.
#1
#2
#3
#4
(2)
D
(3)
Connection
VCONT
GND
Output
VCC
Marking
(1) Frequency
#1 Index
12.80 (MHz, 4digits)
(2) Model code
AN
(3) Date code
Year (1digit) +Week (2digits)
e.g.2017/01/01
701
unit: mm
Dimensional Tolerance: ±0.15
(Unless otherwise noted)
9. Measurement Circuit
1000pF
T.P.
mA
#3
#4
10000pF
Power
Supply
Vcc
VC-TCXO
V
VCONT
Output
GND
VCONT
TITLE
LOAD_C
LOAD_R
#2
#1
LOAD_R=10kΩ
LOAD_C=10pF (Include Jig stray capacitance)
Remark
Date
2017/06/05
Spec. No.
Rev.
1XTV12800PDA
DAISHINKU CORP.
Page
2/13
Serial No.2017-0584
10. Mechanical Characteristics
All test is performed after 3times reflow (Clause.13) except 10.10 (Resistance to soldering heat)
Item
1
2
3
4
5
Drop
Vibration
Shock
PCB bend
strength
Adherence nature
6
Package strength
7
Gross leak
8
Fine leak
9
Solderability
10
Resistance to
soldering heat
Description
Requirements
Natural drop (On concrete)
Mounting on the set or test fixture.(Total weight 100g)
Height : 150cm
Direction : X,Y,Z, 6directions
Test cycle : 3cycles
Reference specification : EIAJ-ED-4702A Method5
Sweep range : 10~500Hz
Sweep speed : 11min/cycle
Amplitude : 1.5mm (10~55Hz)
2
Acceleration : 200m/s (55~500Hz)
Direction : X,Y,Z, 3directions
Test cycle : 10cycles
Reference specification : IEC 60068-2-6
2
Acceleration : 1000m/s
Duration : 6ms
Test cycle : 3cycles/each directions
Reference specification : IEC 60068-2-27
PWB : t=1.6mm
Pressure speed : 1.0mm/s
Bend width : 1 2 3mm
Duration : 10±1s
Reference specification : IEC 60068-2-21 Ue1
PWB : t=1.6mm
Direction : X,Y, 2directions
Pressure : 10N
Duration : 10±1s
Reference specification : IEC 60068-2-21 Ue3
Pressure : 10N
Duration : 10±1s
Reference specification : IEC 60068-2-77
It is immersed for 3min into +125±5C
Chlorofluorocarbon (CFCs) liquid.
Reference specification : IEC 60068-2-17
It shall be measured by the helium leak detector
after pressurization for 60min by the pressure
5
of (3.92±0.49) x10 Pa in a helium gas atmosphere.
Solder bath temperature : +245±5C
Duration : 3±0.3s
Reference specification : IEC 60068-2-58
1) Solder iron method
Bit size : B(φ3) Bit temperature : +350±10C
Duration : 3+1/-0s /each terminal
It shall be measured after 2h at room temperature,
humidity. Reference specification : IEC 60068-2-20
2) Reflow
In refer to temperature profile shown in clause13.
humidity. Reference specification : IEC 60068-2-58
TITLE
df/f=
很抱歉,暂时无法提供与“1XTV12800PDA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.21440
- 10+5.94000
- 30+5.24880
- 100+4.44960
- 500+4.10400
