Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 9
SERIES: AMT22 | DESCRIPTION: MODULAR ABSOLUTE ENCODER
FEATURES
• patented capacitive ASIC technology
• low power consumption
• full duplex Serial Peripheral Interface (SPI)
• 12 or 14-bit absolute position with multi-turn capability
• checksum bits for error detection
• configuration and firmware updates via AMT Viewpoint™ software
• digitally settable zero position (single-turn versions only)
• compact modular package with locking hub for ease of installation
• radial and axial cable connections
• -40 ~ 105°C operating temperature
ELECTRICAL
parameter
conditions/description
min
power supply
VDD
3.8
start-up time1
current consumption
with unloaded output
typ
max
5
5.5
ms
16
mA
2.0
output low level
output high level
Note:
V
200
input low level
input high level
units
0.8
V
5.5
V
0.8
V
3.3
V
1. Encoder must be stationary during start-up.
ABSOLUTE POSITION CHARACTERISTICS
parameter
resolution
12 or 14-bit
min
accuracy
absolute zero position
settable via AMT Viewpoint™ GUI or SPI (single-turn versions only)
multi-turn
multi-turn and single-turn versions available
turns counter
signed binary number
absolute position update rate
12-bit
14-bit
2
Notes:
typ
max
units
0.2
degrees
14
bits
25
100
µs
µs
2. Multi-turn encoders only.
MECHANICAL
parameter
min
motor shaft length
motor shaft tolerance
weight
axial play
rotational speed (at each resolution)
typ
max
9
12-bit position resolution
14-bit position resolution
cuidevices.com
units
mm
NOM +0/-0.015
mm
15.7
g
±0.3
mm
8,000
4,000
RPM
RPM
Product Page
3D Model
CUI DEVICES | SERIES: AMT22 | DESCRIPTION: MODULAR ABSOLUTE ENCODER
date 08/05/2022 | page 2 of 9
ENVIRONMENTAL
parameter
min
typ
-40
humidity
non-condensing
vibration
10~500 Hz, 5 minute sweep, 2 hours on each XYZ
shock
3 pulses, 6 ms, 3 on each XYZ
RoHS
yes
max
units
105
°C
85
5
G
200
G
max
units
2
MHz
SERIAL INTERFACE
parameter
protocol
Serial Peripheral Interface Mode 0
min
typ
frame size
8
bit
data rate
transceiver
SPI driven by PIC18F14K223
TCLK
data shifted to output buffer4
2.5
µs
TB
time between bytes
2.5
µs
TCS
time between reads
40
µs
3
µs
TR
Notes:
time before CS can be released
3. See Microchip documentation for more details.
4. This is the time it takes to load the most current position into the SPI buffer which prevents multiple read/response commands from being required.
Figure 1
Timing Waveform
CHIP SELECT
TCS
TB
TCLK
TR
2
1
3
4
5
6
7
8
1
2
6
5
4
3
7
8
SCLK
MISO
K1
K0
D14
D13
D12
D11
D10
D9
D8
D7
C7
C6
C5
C4
C3
C2
C1
C0
C7
C6
D6
C5
D5
D4
D3
D2
D1
C4
C3
C2
C1
C1
MOSI
First Command Char
Second Command Char
Values K1 and K0 in the response are checkbits. The checkbits are odd parity over the odd and even bits in the position response shown in
the equation below. The checkbits are not part of the position, but are used to verify its validity. The lower 14 bits are the encoder position.
Example:
Full response: 0x61AB
14-bit position: 0x21AB (8619 decimal)
Checkbit Formula
Odd: K1 = !(H5^H3^H1^L7^L5^L3^L1)
Even: K0 = !(H4^H2^H0^L6^L4^L2^L0)
From the above response 0x61AB:
Odd: 0 = !(1^0^0^1^1^1^1) = correct
Even: 1 = !(0^0^1^0^0^0^1) = correct
For 12-bit applications L0 and L1 are always 0. Because the low two bits are 0, 12-bit data will need right-shifted two bits. The checkbit
calculation remains the same and unaffected.
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 3 of 9
SERIAL INTERFACE (CONTINUED)
Commands:
Read Position
Hex command sequence: 0x00 0x00
The command to read position is 0x00, 0x00 because the encoder will always respond with the current position when SPI is accessed. The
encoder observes the second byte for extended commands.
Extended Commands:
Reset Encoder
Hex command sequence: 0x00 0x60
The encoder responds with the current position over the transmission then immediately resets. Observe the power on time when using this
command. Encoder must be stationary to power back on.
Set Zero Point (single-turn encoders only)
Hex command sequence: 0x00 0x70
The encoder responds with the current position over this transmission then saves the current position into memory and performs a reset.
Encoder must be stationary for this command. Observe the power on time when using this command.
Read Turns (multi-turn encoders only)
Hex command sequence: 0x00 0xA0 0x00 0x00
The encoder responds with position during the transfer of the first two bytes. The encoder responds with the current turn value in the
second two bytes. The resulting number is a signed 14 bit number.
Chip select must be held low for the entire four byte transfer, and TB should be observed between each byte.
AMT VIEWPOINT™ OPERATION
The AMT22 encoder operates in two modes: programming, and SPI mode. To enter programming mode for use with AMT Viewpoint™ the
slide on the bottom of the encoder must be moved to the programming position. Slide the switch to the left position before connecting
encoder to AMT Viewpoint™. Once configuration in AMT Viewpoint™ is completed, disconnect encoder and return switch to the standard run
mode position before connecting encoder to system. Switch must be in proper mode for programming or SPI before power is connected to
device.
A
Run Mode
Program Mode
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 4 of 9
PART NUMBER KEY
For customers that prefer a specific AMT22 configuration, please reference the custom configuration key below.
AMT22 X X - XXXX - X
Base Number
Orientation:
2 = Radial
3 = Axial
Mounting Base:
S = Standard
W= Wide
Absolute Resolution:
A = 12-bit single-turn
B = 14-bit single-turn
C = 12-bit multi-turn
D = 14-bit multi-turn
Bore Diameter:
2000 = 2 mm
3000 = 3 mm
3175 = 3.175 mm (1/8”)
4000 = 4 mm
4760 = 4.76 mm (3/16”)
5000 = 5 mm
6000 = 6 mm
6350 = 6.35 mm (1/4”)
8000 = 8 mm
AMT22-V KITS
In order to provide maximum flexibility for our customers, the AMT22 series is provided in kit form standard. This allows the user to implement the encoder into a range of
applications using one sku#, reducing engineering and inventory costs.
SLEEVES
ORDERING GUIDE
AMT22XX-V
Orientation:
2 = Radial
3 = Axial
2mm
3mm
1/8 inch
(3.175mm)
4mm
3/16 inch
(4.76mm)
5mm
6mm
1/4 inch
(6.35mm)
8mm
Light Sky
Blue
Orange
Purple
Gray
Yellow
Green
Red
Snow
Blue
BASE
WIDE
BASE
cuidevices.com
TOP
COVER
SHAFT
ADAPTER
TOOL A
TOOL C
Product Page
3D Model
date 08/05/2022 | page 5 of 9
ENCODER INTERFACE
PINOUT CONNECTOR
AMT222
AMT223
Function
1
+5 V
2
SCLK
3
MOSI
4
GND
5
MISO
6
CHIP SELECT
Mating Connector1:
Molex 502578-0600
Notes:
1. Compatible with prototype cable AMT-06C-1-036 and programming cable AMT-06C-1-036-USB.
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 6 of 9
MECHANICAL DRAWING
AMT222
units: mm
tolerance: ±0.1
10.30 0.406
R15.49 0.610
15.30 0.602
15.33 0.604
39.94 1.573
28.58 1.125
11.70 0.461
AMT223
units: mm
tolerance: ±0.1
10.30 0.406
R15.49 0.610
15.30 0.602
15.33 0.604
39.06 1.538
28.58 1.125
12.60 0.496
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 7 of 9
MECHANICAL DRAWING (CONTINUED)
MOUNTING HOLE PATTERNS
STANDARD BASE
units: mm[inch]
tolerance: ±0.1
22.00 0.866
21.55 0.848
20.90 0.823
12.60[0.496]
R1.05 0.041
DETAIL A
SCALE 4 : 1
2.00 0.079
(4 PLCS)
2.95 0.116
(2 PLCS)
16.00 0.630
0.275 0.011
A (3 PLCS)
1.70 0.067
(2 PLCS)
19.05 0.750
25.40 1.000
WIDE BASE
units: mm[inch]
tolerance: ±0.1
32.44 1.277
3.00 0.118
(2 PLCS)
2.96
2.87 X 2.96
(2 PLCS)
A
2.87
0.09
DETAIL A
SCALE 4 : 1
46.02 1.812
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 8 of 9
ASSEMBLY PROCEDURE
STEP 1
STEP 2
STEP 3
Align Tool C with
flange on Base
1. Insert Tool A as a spacer that defines the distance to
the mounting surface.
2. Slide appropriate sized Sleeve over shaft all the way down to Tool A.
3. Slide Shaft Adaptor over Sleeve.
4. Use Tool C to press Shaft Adaptor over Sleeve (ensure Shaft Adapter
and Tool C spline alignment) until flush with Tool A.
STEP 4
1. Remove Tools A and C.
2. Place Base on motor, with Tool C used as a centering tool.
STEP 5
1. Snap the Top Cover onto the Base, carefully observing that the
teeth of the Shaft Adaptor align with the grooves in the hub. *
1. Fasten the Base on the motor (Tool C may need to be
rotated to allow for some mounting configurations).
2. Remove Tool C.
* We recommend no more than three cycles of mounting and
removal of the AMT top cover base. Multiple cycles of mounting
and removing the top cover can cause base fatigue over time and
affect encoder performance.
cuidevices.com
1. Align Tool C with flange on Base.
2. Slide Base and Tool C onto motor, centering onto
the Shaft Adapter.
STEP 6
1. Make sure the snaps are fully engaged by pressing
on the Hub with the reverse side of Tool C.
2. When assembly is finished, the Shaft Adaptor, Sleeve
and Rotor Hub should all be flush with the Motor
Shaft rotating freely.
Product Page
3D Model
date 08/05/2022 | page 9 of 9
REVISION HISTORY
rev.
description
date
1.0
initial release
12/14/2018
1.01
updated TCLK and TCS values
06/26/2019
1.02
updated current consumption value
07/17/2019
1.03
added start-up time details
08/12/2019
1.04
brand update
11/21/2019
1.05
added multi-turn versions, updated start-up details
08/05/2021
1.06
updated datasheet
02/22/2022
1.07
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“AMT223B-V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+934.298481+120.86578
- 5+566.683115+73.30911
- 10+513.5002110+66.42909
- 25+448.1424825+57.97407
