PHE13003A,412
PHE13003A,412
    WEEN(瑞能)
    TO92-3
    TRANS NPN 400V 1A SOT54
PHE13003A,412 数据手册
IMPORTANT NOTICE 10 December 2015 1. Global joint venture starts operations as WeEn Semiconductors Dear customer, As from November 9th, 2015 NXP Semiconductors N.V. and Beijing JianGuang Asset Management Co. Ltd established Bipolar Power joint venture (JV), WeEn Semiconductors, which will be used in future Bipolar Power documents together with new contact details. In this document where the previous NXP references remain, please use the new links as shown below. WWW - For www.nxp.com use www.ween-semi.com Email - For salesaddresses@nxp.com use salesaddresses@ween-semi.com For the copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) “© NXP Semiconductors N.V. {year}. All rights reserved” becomes “© WeEn Semiconductors Co., Ltd. {year}. All rights reserved” If you have any questions related to this document, please contact our nearest sales office via email or phone (details via salesaddresses@ween-semi.com). Thank you for your cooperation and understanding, WeEn Semiconductors PHE13003A NPN power transistor 3 October 2016 Product data sheet 1. General description High voltage, high speed, planar passivated NPN power switching transistor in a SOT54 (TO-92) plastic package. 2. Features and benefits • • • Fast switching High voltage capability Very low switching and conduction losses 3. Applications • • • • Compact fluorescent lamps (CFL) Electronic lighting ballasts Inverters Off-line self-oscillating power supplies 4. Pinning information Table 1. Pinning information Pin Symbol Description 1 B base 2 C collector 3 E emitter Simplified outline Graphic symbol C B E 321 sym123 TO-92 (SOT54) 5. Ordering information Table 2. Ordering information Type number PHE13003A Package Name Description Version TO-92 plastic single-ended leaded (through hole) package; 3 leads SOT54 PHE13003A WeEn Semiconductors NPN power transistor 6. Limiting values Table 3. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCESM collector-emitter peak voltage VBE = 0 V - 700 V VCBO collector-base voltage IE = 0 A - 700 V VCEO collector-emitter voltage IB = 0 A - 400 V VEBO emitter-base voltage IC = 0 A; I(Emitter) = 10 mA - 9 V IC collector current DC; Fig. 1 - 1 A ICM peak collector current - 2 A IB base current - 0.5 A IBM peak base current - 1 A Ptot total power dissipation - 2.1 W Tstg storage temperature -65 150 °C Tj junction temperature - 150 °C DC Tlead ≤ 25 °C; Fig. 2 003aad545 102 IC (A) 10 IC(max) 1 10- 1 (1) 10- 2 DC 10- 3 1 102 10 VCL(CE) (V) 103 Fig. 1. Forward bias safe operating area PHE13003A Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2016 © WeEn Semiconductors Co., Ltd. 2016. All rights reserved 2 / 10 PHE13003A WeEn Semiconductors NPN power transistor 003aae644 120 Pder (%) 80 40 0 0 50 100 150 200 Tlead (°C) Fig. 2. Normalized total power dissipation as a function of lead temperature 7. Thermal characteristics Table 4. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-lead) thermal resistance from junction to lead Fig. 3 - - 60 K/W Rth(j-a) thermal resistance from junction to ambient free air printed circuit board mounted; lead length = 4 mm - 150 - K/W 001aab451 102 Zth(j-lead) (K/W) 10 1 P 10-1 tp 10-2 10-5 10-4 10-3 10-2 10-1 1 tp (s) t 10 Fig. 3. Transient thermal impedance from junction to lead as a function of pulse width PHE13003A Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2016 © WeEn Semiconductors Co., Ltd. 2016. All rights reserved 3 / 10 PHE13003A WeEn Semiconductors NPN power transistor 8. Characteristics Table 5. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics ICES collector-emitter cut-off VBE = 0 V; VCE = 700 V; Tj = 125 °C current (base shorted) - - 5 mA IEBO emitter-base cut-off VEB = 9 V; IC = 0 A; Tlead = 25 °C current (collector open) - - 1 mA VCEOsus collector-emitter sustaining voltage (base open) IB = 0 A; IC = 1 mA; LC = 25 mH; Tlead = 25 °C; Fig. 4; Fig. 5 400 - - V VCEsat collector-emitter saturation voltage IC = 0.25 A; IB = 50 mA; Tlead = 25 °C; Fig. 6 - 0.2 0.5 V IC = 0.5 A; IB = 125 mA; Tlead = 25 °C; Fig. 6 - 0.3 1 V IC = 0.75 A; IB = 250 mA; Tlead = 25 °C; Fig. 6 - 0.4 1.5 V base-emitter saturation IC = 0.25 A; IB = 50 mA; Tlead = 25 °C; Fig. 7 voltage - - 1 V IC = 0.5 A; IB = 125 mA; Tlead = 25 °C; Fig. 7 - - 1.2 V IC = 0.5 mA; VCE = 2 V; Tlead = 25 °C; Fig. 8; Fig. 9 12 - - IC = 0.4 A; VCE = 5 V; Tlead = 25 °C; Fig. 8; Fig. 9 10 - 30 IC = 0.8 A; VCE = 5 V; Tlead = 25 °C; Fig. 8; Fig. 9 5 7.5 20 IC = 1 A; IBon = 200 mA; VBB = -5 V; LB = 1 µH; Tlead = 25 °C; inductive load; Fig. 10; Fig. 11 - 80 - All information provided in this document is subject to legal disclaimers. © VBEsat hFE DC current gain Dynamic characteristics tf fall time PHE13003A Product data sheet 3 October 2016 ns WeEn Semiconductors Co., Ltd. 2016. All rights reserved 4 / 10 PHE13003A WeEn Semiconductors NPN power transistor IC (mA) 50 V 100 Ω to 200 Ω horizontal oscilloscope 250 vertical 6V 300 Ω 1Ω 100 30 Hz to 60 Hz 001aab987 10 0 Fig. 4. Test circuit for collector-emitter sustaining voltage min VCE (V) VCEOsus 001aab988 Fig. 5. Oscilloscope display for collector-emitter sustaining voltage test waveform 003aad548 2.0 VCEsat (V) 003aad549 1.6 VBEsat (V) 1.4 Tj = 125 °C 1.6 1.2 Tj = 25 °C 1.0 1.2 Tj = - 35 °C Tj = - 35 °C Tj = 25 °C 0.8 0.8 Tj = 125 °C 0.6 0.4 0.4 0.2 0 10- 2 10- 1 1 IC (A) 0 10- 2 10 Fig. 6. Collector-emitter saturation voltage as a function of collector current; typical values PHE13003A Product data sheet 10- 1 1 IC (A) 10 Fig. 7. Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 3 October 2016 © WeEn Semiconductors Co., Ltd. 2016. All rights reserved 5 / 10 PHE13003A WeEn Semiconductors NPN power transistor 003aad546 102 003aad547 102 Tj = 125 °C Tj = 125 °C hFE hFE Tj = 25 °C Tj = - 35 °C 10 10 VCE = 3 V Tj = 25 °C Tj = - 35 °C VCE = 5 V (1) (1) (2) (2) (3) 1 10- 3 10- 2 10- 1 1 IC (A) (3) 1 10- 3 10 Fig. 8. DC current gain as a function of collector current; typical values 10- 2 10- 1 1 IC (A) 10 Fig. 9. DC current gain as a function of collector current; typical values VCC IC ICon 90 % LC IBon VBB LB DUT 001aab991 10 % Fig. 10. Test circuit for inductive load switching IB tf ts toff t IBon t - IBoff 001aab992 Fig. 11. Switching times waveforms for inductive load PHE13003A Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2016 © WeEn Semiconductors Co., Ltd. 2016. All rights reserved 6 / 10 PHE13003A WeEn Semiconductors NPN power transistor 9. Package outline Fig. 12. Package outline TO-92 (SOT54) PHE13003A Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2016 © WeEn Semiconductors Co., Ltd. 2016. All rights reserved 7 / 10 PHE13003A WeEn Semiconductors NPN power transistor Right to make changes — WeEn Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 10. Legal information Suitability for use — WeEn Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an WeEn Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. WeEn Semiconductors and its suppliers accept no liability for inclusion and/or use of WeEn Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. WeEn Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ween-semi.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. WeEn Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local WeEn Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between WeEn Semiconductors and its customer, unless WeEn Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the WeEn Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, WeEn Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. WeEn Semiconductors takes no responsibility for the content in this document if provided by an information source outside of WeEn Semiconductors. In no event shall WeEn Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, WeEn Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of WeEn Semiconductors. PHE13003A Product data sheet Customers are responsible for the design and operation of their applications and products using WeEn Semiconductors products, and WeEn Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the WeEn Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. WeEn Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using WeEn Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). WeEn does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific WeEn Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without WeEn Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond WeEn Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies WeEn Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond WeEn Semiconductors’ standard warranty and WeEn Semiconductors’ product specifications. All information provided in this document is subject to legal disclaimers. 3 October 2016 © WeEn Semiconductors Co., Ltd. 2016. All rights reserved 8 / 10 PHE13003A WeEn Semiconductors NPN power transistor Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PHE13003A Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2016 © WeEn Semiconductors Co., Ltd. 2016. All rights reserved 9 / 10 PHE13003A WeEn Semiconductors NPN power transistor 11. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Pinning information......................................................1 5. Ordering information....................................................1 6. Limiting values............................................................. 2 7. Thermal characteristics............................................... 3 8. Characteristics..............................................................4 9. Package outline............................................................ 7 10. Legal information....................................................... 8 © WeEn Semiconductors Co., Ltd. 2016. All rights reserved For more information, please visit: http://www.ween-semi.com For sales office addresses, please send an email to: salesaddresses@ween-semi.com Date of release: 3 October 2016 PHE13003A Product data sheet All information provided in this document is subject to legal disclaimers. 3 October 2016 © WeEn Semiconductors Co., Ltd. 2016. All rights reserved 10 / 10
PHE13003A,412 价格&库存
很抱歉,暂时无法提供与“PHE13003A,412”相匹配的价格&库存,您可以联系我们找货
