MKP474K275A33
MKP474K275A33
    JIMSON(智新)
    插件,P=15mm
    安规电容 径向
MKP474K275A33 数据手册
智新电子(厦门)有限公司 JIMSON ELECTRONICS (XIAMEN) CO.,LTD. File NO (文件编号) : JS-S191014199 规 格 书 SPECIFICATION ☆客户名称 CUSTOMER: 立创 ☆产品名称 PROD NAME: 电容器/Capacitor ☆类别 TYPE: MKP X2 ☆规格 DESCRIPTION: 0.022uF~4.7uF K 275VAC ☆日期 DATE: 2019-10-14 编 制: 徐玉倩 审 核: 梁亚苗 会 日 签: 期: 注意事项: 1、本规格书双方签字后正式生效,本规格书共 8 页; 2、本规格书一式两份,任何对内容的改动必须经双方同意,并以书面文件的形式发布。 ·编号: MKP 系列规格书 ■秘密 □机密 □绝密 1.SPECIFIC REFERENCE DATA DESCRIPTION Capacit Rated Capacitance ance 标称值 容量 Capacitance olerance 容量误差 VALUE 0.022uF~4.7uF TEST CONDITIONS Measuring frequency: 1kHz±10% Measuring voltage: 1Vms.max. K=±10% Voltage Rated voltage(额定电压)275VAC 电压 Voltage proof(耐电压) 无永久性击穿及飞弧 Dissipation factor (tangent of loss) DF≤0.1% 散逸因素(损耗角正切) 4.3*UR VDC (1 minute at 20℃) frequency: 1kHz±10% (at 20℃,1KHz) Measuring Measuring voltage: 1Vms.max. measured at rated voltage or less than 100VDC 1 minute at 20℃ and RH≤65% 1000 hours with 125% of rated voltage at 85℃. Insulation resistance 绝缘电阻 C≤0.33uF IR≥15000MΩ C >0.33uF IR*C≥5000S Endurance 耐久性 ΔC/C≤10%; ΔDF≤0.8% (C≤1uF) ΔDF≤0.5%;(C>1uF) IR ≥ 50% of the specified value(标称值) Climatic catalogue 气候类别 40/100/21 Solder ability 可焊性 Solder should cover at least 75% of the circumference of the lead 浸没部分引脚需有 75%以上 面积挂上锡 solder bath : 235±5℃ bath time: 2.0±0.5 sec speed: 25±6 mm/sec depth: 1.5+0.5/-0mm from the bottom of the body Heat shock 耐焊接热 ΔC/C≤±5%, DF≤1.2*规定值。 试验后电容器外观应无可见 损伤, Lead tensile strength: 引脚拉伸强度 外观无损伤 solder bath : 260±5℃ bath time: 5.0±0.5 sec speed: 25±6 mm/sec depth: 1.5+0.5/-0mm from the bottom of the body Pull:2.2 LBS time: 5 sec Lead bending strength 引脚弯曲强度 引脚无损伤 Vibration 震动 外观无可见损伤 Reference standard 引用标准 IEC 60384-14,UL60384-14 版权所有,侵权必究 Load of lead:1.1 LBS The body of capacitor is bent 90 degrees and returned to its original position Frequency cycle: from 10Hz to 55Hz and then 10Hz Amplitude: 1.5mm in three directions Time: 2 hours each directions with a total of 6 hours 第 2页 共 9页 MKP 系列规格书 ·编号: ■秘密 □机密 □绝密 2.CONSTRUCTION: 2.1 Dielectric 介质 polypropylene film 聚丙烯薄膜 2.2 Electrodes 电极 vacuum evaporated metal 真空蒸镀金属 Encapsulated in reinforced flame retardant plastic case sealed with epoxy resin meeting the requirement of-UL94V-0 (阻燃盒子并以环氧树脂灌封) Radial leads of tinned wire/insulation flexible wire 径向镀锡导线或软导线 electrically welded; 电弧点焊 2.3 coating 包封 2.4 LEADS 导线 2.5 Terminal contact 引线连接方式 3.SAFETY APPROVALS SAFETY APPROVAL COUNTRY FILE NUMBER UL60384—14 Canada / America E152288 VDE (EN60384-14) Germany 40000463 VDE(EN60384-14) EN/EC Europe 40000463 CQC (IEC60384-14 ed.4) China CQC03001002847 CB(IEC60384-14) IEC US-25278-UL KC(K60384-14) KOREA SUO3035-7001-3A 4.FEATURE: ■ ■ ■ ■ 宽温度、频率范围内,容量和 DF 具有高稳定性 High stability of capacitance and DF versus wide temperature and frequency range ; 高电流承受及高绝缘强度 High transient endurance and high dielectric strength ; 长时间工作稳定性 Real long-term stability; 能承受高压冲击 Withstanding over-voltage stressing. ■额定电压符号(单位 V): 版权所有,侵权必究 第 3页 共 9页 MKP 系列规格书 ·编号: ■秘密 □机密 □绝密 5.APPLICATION: ■ ■ ■ ■ ■ 线间旁路 Line-by -pass; 天线耦合 Antenna coupling; 线间跨接,抑制电源电磁干扰 Across- the-line, Spark killer; 频率调制滤波 FMI filter; 开关电源 Switching power supply. 6.THE MARKING:(打印方式:UV 油墨或激光雕刻) 旧版印字格式 Old print 新版印字格式 New print 内容 Those marking include: ■ 生产商 Manufacturer: JIMSON ■ 产品型号 Manufacturer’s type designation: MKP ■ 额定容量 Rated capacitance in uF, such as1.0uF ■ 容量偏差 Tolerance on rated capacitance: K=±10% ■ 额定电压 Rated voltage (AC), such as 275VAC ■ 气候类别 Climatic catalogue GMF ■ 产品等级 Sub-class, such as X2 ■ 安规标志 Safety approvals: Products will be marked with all approvals which have been achieve.(show in 2.) ■ 引用标准 Reference standard:IEC384-14。 ENEC Approved Country 、Certification Bodies and ENEC Codes No Country 01 02 03 04 05 06 07 08 09 10 11 12 Certification Body Spain AENOR Belgium CEBEC Italy IMQ Portugal CERTIF Holland KEMA Ireland NSAI Luxembour SEE France LCIE Greece ELOT Germany VDE Austria OVE England BSI 版权所有,侵权必究 No Country 13 14 15 16 17 18 19 20 21 22 24 Switzerland Sweden Denmark Finland Norway Hungary England England Czech epublic Slovenia Germany Certification Body SEV SEMKO DEMKO FIMKO NEMKO MEEI BEAB ASTA EZU SIQ TUV Rheinland 第 4页 共 9页 MKP 系列规格书 ·编号: ■秘密 □机密 □绝密 7.HOW TO DESCRIBE JIMSON CAPACITOR MKP 105 K 275VAC W type capacitance tolerance rated voltage pitch ■型号 TYPE: MKP ■容量 CAPACITANCE: 产品的电容量用三位数字来表示,其中前两位数代表电容量的标称值,后一位表示电 容量的指数值,亦即标称值后零的个数,单位为 PF。 The rated capacitance value of the product is indicated with three digits. The first two digits indicate the two most significant digits of capacitance value, and the third digit gives the number of following zeroes. This gives the capacitance value expressed in Pico farad. For example: 10 2=10×102pF=1000pF=1nF=0.001uF 15 3=15×103pF=15000pF=15nF=0.015uF 22 4=22×104pF=220000pF=220nF=0.22uF 33 5=33×105pF=3300000pF=3300nF=3.3uF ■容量单位 CAPACITANCE UNIT: 1F=1,000mF=1,000,000uF=1,000,000,000nF=1,000,000,000,000pF ■ 容量偏差符号 SYMBOL OF CAPACITOR TOLERANCE SYMBOL B C D F G H I J K M TOLERANCE PERCENTAG % N V Z ± ± ± ± ± ± ± ± ± ± ± 20 +80 0.1 0.2 0.5 1.0 2.0 2.5 3.0 5.0 10 20 30 -10 -20 ■额定电压符号 SYMBOL OF RATED VOLTAGE A B C D E F G 1 H J K 50 63 80 2 100 125 160 200 250 315 400 500 630 800 3 1000 1250 1600 2000 2500 3150 4000 5000 6300 8000 For example: 1J=63V;2E=250V;3D=2000V ■ 脚距 PITCH E J 5.0 7.5 N R S T V W X 10.0 15.0 17.5 20.0 22.5 27.5 Others ■引脚类型 LEAD R F C Rigid Flexible 版权所有,侵权必究 Cut B O Crimped Others 第 5页 共 9页 ·编号: MKP 系列规格书 ■秘密 □机密 □绝密 8. PROPERTIES OF CAPACITOR AND THE DIELECTRICS: 版权所有,侵权必究 第 6页 共 9页 MKP 系列规格书 ·编号: 9.OUTLINE ■秘密 □机密 □绝密 DRAWING: 10. DIMENSION: Unit: mm SYMBOL CAP COLOR W ±0.5 333K275A06 0.033uF Yellow 18.0 10.0 5.0 15.0 0.8 25.0 473K275A03 0.047uF Yellow 18.0 10.0 5.0 15.0 0.8 25.0 104K275A07 0.1uF Yellow 18.0 12.0 6.0 15.0 0.6 25.0 154K275A15 0.15uF Yellow 18.0 12.0 6.0 15.0 0.8 25.0 474K275A33 0.47uF Yellow 18.0 16.0 10.0 15.0 0.8 25.0 564K275A04 0.56uF Yellow 18.0 18.0 10.0 15.0 0.8 25.0 104K275A17 0.1uF Yellow 13.0 12.0 6.0 10.0 0.6 25.0 154K275A21 0.15uF Yellow 13.0 12.0 6.0 10.0 0.6 25.0 版权所有,侵权必究 H ±0.5 T ±0.5 P ±1.0 D ±0.05 L +5/-10 第 7页 共 9页 MKP 系列规格书 ·编号: ■秘密 □机密 □绝密 223K275A01 0.022uF Yellow 13.0 11.0 5.0 10.0 0.6 25.0 394K275A01 0.39uF Yellow 26.5 18.5 10.0 22.5 0.8 25.0 474K275A15 0.47uF Yellow 26.5 18.5 10.0 22.5 0.8 25.0 824K275A02 0.82uF Yellow 26.5 18.5 10.0 22.5 0.8 25.0 105K275A05 1.0uF Yellow 26.0 22.0 12.0 22.5 0.8 25.0 125K275A02 1.2uF Yellow 26.0 22.0 12.0 22.5 0.8 25.0 155K275A10 1.5uF Yellow 26.0 22.0 12.0 22.5 0.8 25.0 205K275A03 2.0uF Yellow 26.0 22.0 12.0 22.5 0.8 25.0 225K275A12 2.2uF Yellow 31.0 25.0 14.0 27.5 0.8 25.0 275K275A01 2.7uF Yellow 32.0 28.0 18.0 27.5 0.8 25.0 475K275A02 4.7uF Yellow 32.0 28.0 18.0 27.5 0.8 25.0 SYMBOL CAP COLOR W ±0.5 H ±0.5 T ±0.5 P ±1.0 D ±0.05 L ≥ 334K275A02 0.33uF Yellow 18.0 16.0 10.0 15.0 0.8 30.0 SYMBOL CAP COLOR W ±0.5 824K275A06 0.82uF Yellow 26.5 版权所有,侵权必究 H T ±0.5 ±0.5 P D ±1.0 ±0.05 L ±2.0 18.5 22.5 15.0 10.0 0.8 第 8页 共 9页 MKP 系列规格书 ·编号: ■秘密 □机密 □绝密 11.使用注意事项 Caution 11.1 焊接建议 Soldering Suggestion 为了达到更好的可焊性,建议按照下列的标准; In order to achieve a better solderability, recommended in accordance with the following criteria 最大的焊接温度 Maximum Soldering Temperature 预热 Pre-heating 焊接 Soldering T max 105℃ 270℃ Time 1min 4S 11.2 盐雾试验条件 Salt fog test 本产品引线为镀锡铜包钢产品,请过完波峰焊后再进行盐雾试验; The lead wire of this product is tin-plated copper-coated steel. Please test the salt mist after the wave peak welding. 12.存储环境及条件 Storage Environment and Conditions 12.1 存储环境 Storage Environment 储存在温度≤30℃,湿度≤70%的情况下,MBB(Moisture Barrier Bag) 未打开能够保证 24 个月的储存期。 In the storage temperature are less than 30, humidity less than 70% conditions, MBB(Moisture Barrier Bag)is not open to ensure that the storage period of 24 months. 12.2 存储条件 Storage Condition 由于大气中存在氢氯化物、氢硫化物、硫酸物质等,因此产品储存在空气中, 引出端的可焊性会变差。 产品不能暴露在高温高湿状态,必须在 12 的存储环境条件下保存 Due to the presence of hydrogen chloride, hydrogen sulfide, sulfuric acid, etc. in the atmosphere,So the product is stored in the air, solderability of terminations will be poor. Products can not be exposed to high temperature and high humidity condition, must be stored under 12 of the storage environment. 13.绿色产品 Green Products 符合 RoHS 标准 In compliance with RoHS 智新电子公司提供的产品均符合 RoHS 2.0 环保指令的要求 JIMSON ELECTRONICS CO., LTD Products are RoHS Compliant. THE 版权所有,侵权必究 END 第 9页 共 9页
MKP474K275A33 价格&库存
很抱歉,暂时无法提供与“MKP474K275A33”相匹配的价格&库存,您可以联系我们找货
