7V
MHz Crystal
Features
Frequency range : 8MHz to 54MHz
Glass sealing, ceramic SMD package
External dimensions (mm)
L : 3.2 x W : 2.5 x H : 0.8
RoHS compliant
Contains Pb, exempted by RoHS directive
Applications
PC, TV, Game, Camera
Notebook, Hard disk
Computer peripherals
Home electronics
Consumer products
Electrical Characteristics
Item
7V
Frequency Range
F0
8MHz ~ 54MHz
Frequency Tolerance
Ftol
±30ppm, ±20ppm, ±10ppm
Frequency Stability over
Operating Temperature Range
(refer to 25°C)
Fstab
TOTR
±30 ppm
±20 ppm
±10 ppm
±10 ppm
±50 ppm
±30 ppm
±20 ppm
±60 ppm
-20°C ~ +70°C
-30°C ~ +85°C
-40°C ~ +85°C
-40°C ~ +125°C
Shunt Capacitance
C0
3pF Max.
Drive Level
DL
1 ~ 50μW (10μW Typ.)
Load Capacitance
CL
6pF, 7pF, 8pF, 9pF, 10pF
12pF, 16pF, 18pF, 20pF
Aging
Faging
±3 ppm Max.
Storage Temperature Range
TSTR
-55°C ~ +125°C
Conditions
at 25°C
-20°C ~ +70°C
-30°C ~ +85°C
-40°C ~ +85°C
-40°C ~ +125°C
at 25°C ± 3°C,first year
Motional Resistance (ESR)
Fundamental
8~9
9 ~ 10
10 ~ 12
12 ~ 16
16 ~ 54
Rev. 1.06
MHz
MHz
MHz
MHz
MHz
350Ω
200Ω
150Ω
100Ω
60Ω
Max.
Max.
Max.
Max.
Max.
Page 1
www.txccrystal.com
7V
MHz Crystal
Dimensions
THK Note [1]
Note:
[1] THK = 0.8 ± 0.1mm except F0 = 8MHz.
THK = 0.9 ± 0.1mm for F0 = 8MHz.
Ordering Information
7V
27.000M A H E
Frequency in Hz
T
Packaging Method
T
Please contact us for
available frequencies
Tape & Reel
Load Capacitance
Frequency Tolerance (at 25°C)
A
D
E
± 30 ppm
± 20 ppm
± 10 ppm
Frequency Stability (over Temp.)
A
D
E
T
G
H
I
K
Rev. 1.06
± 30 ppm
± 20 ppm
± 10 ppm
± 10 ppm
± 50 ppm
± 30 ppm
± 20 ppm
± 60 ppm
B
Y
V
C
Q
E
I
J
6 pF
7 pF
8 pF
9 pF
10 pF
12 pF
16 pF
18 pF
( -20°C ~ +70°C )
( -20°C ~ +70°C )
( -20°C ~ +70°C )
( -30°C ~ +85°C )
( -40°C ~ +85°C )
( -40°C ~ +85°C )
( -40°C ~ +85°C )
( -40°C ~ +125°C )
Page 2
www.txccrystal.com
7V
MHz Crystal
Packing
(Unit: mm)
(Unit: mm)
Reflow Profile
Solder melting point : 220°C ± 10°C, 60 sec. Min.
Peak temperature : 260°C ± 5°C, 10 sec. Min.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.06
60 sec
Page 3
Time (sec)
www.txccrystal.com
很抱歉,暂时无法提供与“7V-37.125MDHV-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+2.930533000+0.37915
- 国内价格 香港价格
- 1+4.770951+0.61725
- 10+4.1487010+0.53675
- 50+3.7619050+0.48671
- 100+3.60564100+0.46649
- 500+3.26865500+0.42289
- 1000+3.133421000+0.40539
