GP2D006A065A
GP2D006A065A
    SEMIQ
    TO-220-2
    DIODE SCHOTTKY 650V 6A TO220-2
GP2D006A065A 数据手册
GP2D006A065A VDC QC IF 650V SiC Schottky Diode Amp+ TM Features Amp+ TM Benefits • High surge current capable • Zero reverse recovery current • High bandwidth • Fast, temperature-independent switching Maximum Rating IF Surge non-repetitive forward current sine halfwave IF,SM Non-repetitive peak forward current IF,max i 2t value i 2dt • Motor drives • Zero switching loss • Higher efficiency • Smaller heat sink • Parallel devices with thermal stability • Switch mode power supplies • Power factor correction Part # Package Marking GP2D006A065A TO-220-2L 2D006A065 Conditions 18 TC=125 °C, Tj=175 °C 10 TC=150 °C, Tj=175 °C 6 48 TC=25 °C, tp=8.3 ms 30 120 TC=25 °C, tp=8.3 ms 10 TC=150 °C, tp=8.3 ms 4 650 V 50 V/ns VRRM Tj=25 °C Turn-on slew rate, repetitive Ptot Soldering temperature Tsolder Mounting torque A TC=25 °C, tp=10 ms dv/dt TJ, Tstorage Unit TC=150 °C, tp=8.3 ms Diode dv/dt ruggedness Operating & storage temperature Value TC=25 °C, Tj=175 °C Repetitive peak reverse voltage Power dissipation Amp+ TM Applications • Unipolar rectifier Symbol Continuous forward current 650 V 14 nC 6 A TC=25 °C Continuous Wave soldering leads M3 Screw A2s 65 W -55…175 °C 260 °C 1 N-m Electrical Characteristics, at Tj=25 °C, unless otherwise specified Static Characteristics Symbol DC blocking voltage VDC Diode forward voltage VF Reverse current IR 8/27/2015 Rev 2 Conditions IR=0.1mA min. 650 Values typ. - max. - IF=6A, Tj=25 oC - 1.45 1.65 IF=6A, Tj=175 oC - 1.65 2.00 VR=650V, Tj=25 oC - 6.0 60 VR=650V, Tj=175 oC - 100 600 www.gptechgroup.com Unit V mA p.1 Amp +TM 650V SiC Schottky Diode Parameter Symbol Conditions GP2D006A065A Values typ. min. Unit max. AC Characteristics QC VR=650V, Tj=25 oC - 14 - nC Switching time tC diF/dt=200 A/ms Tj=150 °C - -
GP2D006A065A 价格&库存
很抱歉,暂时无法提供与“GP2D006A065A”相匹配的价格&库存,您可以联系我们找货
