SMT-8M-A-PO-24V-E-7,5-OE
    FESTO(费斯托)
    Module
SMT-8M-A-PO-24V-E-7,5-OE 数据手册
Proximity sensor SMT-8M-A-PO-24V-E-7,5-OE Part number: 574340 Data sheet Feature Value Design for T-slot Based on norm EN 60947-5-2 Symbol 00991151 Certification RCM compliance mark c UL us - Listed (OL) CE marking (see declaration of conformity) As per EU EMC directive As per EU RoHS directive UKCA marking (see declaration of conformity) To UK instructions for EMC To UK RoHS instructions KC characters KC EMC Certificate issuing authority UL E232949 Special features Oil-resistant Note on materials RoHS-compliant Halogen-free Application note Support / actuator-sensor overview "The right sensor for the actuator" Measured variable Position Measuring principle Magneto-resistive Ambient temperature -40 °C ... 85 °C Repetition accuracy 0.2 mm Switching output PNP Switching element function N/C contact On time ≤1.3 ms Switch-off time ≤1.4 ms Max. switching frequency 180 Hz Max. output current 100 mA Max. output current in mounting kits 100 mA Max. switching capacity DC 2.8 W Max. switching capacity DC in mounting kits 2.8 W Voltage drop 300 000 cycles, ±270°/0.1 m Cable length 7.5 m Cable characteristic Suitability for energy chains/robot applications Color cable sheath Gray Material of cable sheath TPE-U(PUR) Type of mounting Screwed tightly Can be inserted in slot from above Max. tightening torque 0.6 Nm Mounting position Any Product weight 85.1 g Housing colour Black Housing material PA-reinforced High-alloy stainless steel Switching status indication LED yellow Function reserve indication LED orange Ambient temperature with flexible cable installation -20 °C ... 85 °C Degree of protection IP65 IP68 IP69K LABS (PWIS) conformity VDMA24364-B2-L Suitability for the production of Li-ion batteries Metals with more than 1% copper, zinc or nickel by mass are excluded from use. Exceptions are nickel in steel, chemically nickel-plated surfaces, printed circuit boards, cables, electrical plug connectors and coils Cleanroom class Class 4 according to ISO 14644-1 10/21/22 - Subject to change - Festo SE & Co. KG 2/2
SMT-8M-A-PO-24V-E-7,5-OE 价格&库存
很抱歉,暂时无法提供与“SMT-8M-A-PO-24V-E-7,5-OE”相匹配的价格&库存,您可以联系我们找货
