EKHS451VSN391MQ45S
EKHS451VSN391MQ45S
    NCC(贵弥功)
    AEC_D25.4X45MM_TM
    贴片铝电解电容 AEC_D25.4X45MM_TM
EKHS451VSN391MQ45S 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS KHS Series Downsized snap-ins, 105℃ KHS ・For solar power generation ・Endurance with ripple current : 3,000 hours at 105℃ ・Rated voltage range:450 to 500V, Capacitance range:68 to 1,000μF ・Non solvent resistant type ・RoHS2 Compliant Downsizing KMS Downsizing KMM ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -25 to +105℃ 450 to 500Vdc ±20% (M) I≦3 CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 450 to 500V tanδ (Max.) 0.20 Rated voltage (Vdc) 450 to 500V Z(-25℃)/Z(+20℃) 8 Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 5 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 3,000 hours at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value (475, 500Vdc: ≦ 250%) Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±15% of the initial value D.F. (tanδ) ≦150% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] Sleeve (PET : Brown) ●Terminal PC board pin-out (View from Solder side) Negative mark φD+1max. 10 2-φ2 4.0±0.5 L±2.5 Vent Code : LI (φ35) Sleeve (PET : Brown) Negative mark Vent PC board pin-out (View from Solder side) 4.2±0.5 Code : VS (φ22 to φ35) : Standard 2-1.2×6 φD+1max. ●Terminal 5±0.5 L±2.5 4.5±1 14.2±1 The standard design has no plastic disc. ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KHS AAA VS N AAA M AAA S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 100µF:101, 1,000µF:102) Dummy terminal code Terminal code (VS, LI) Voltage code (ex. 450V:451, 475V:4H1) Series code Category Please refer to "Product code guide (snap-in type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Downsized snap-ins, 105℃ KHSSeries ◆STANDARD RATINGS WV (Vdc) 450 475 Cap (µF) 100 150 180 180 180 220 220 270 270 270 270 330 330 330 390 390 390 470 470 470 560 560 560 680 680 680 820 820 1,000 82 100 100 120 120 150 150 150 180 180 180 180 180 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 22 ×25 22 ×30 22× 35 22× 40 25.4× 25 22 × 45 25.4× 30 22 × 50 25.4× 35 30 ×25 35 ×25 22 ×60 25.4×40 30 ×30 25.4 ×45 30 ×35 35× 30 25.4× 50 30 × 40 35 × 35 25.4× 60 30 × 45 35 ×40 30 ×50 35 ×45 35 ×50 30× 60 35× 55 35× 60 22× 25 22× 30 25.4× 25 22× 35 25.4× 30 22× 40 22× 45 30× 25 22× 50 25.4× 35 25.4× 40 30× 30 35× 25 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.71 0.91 1.02 1.04 1.02 1.17 1.16 1.33 1.34 1.28 1.24 1.54 1.51 1.43 1.67 1.59 1.52 1.86 1.79 1.69 2.09 2.01 1.95 2.25 2.16 2.22 2.56 2.47 2.78 0.67 0.78 0.79 0.87 0.89 0.99 1.01 1.01 1.13 1.14 1.16 1.11 1.08 Part No. EKHS451VSN101MP25S EKHS451VSN151MP30S EKHS451VSN181MP35S EKHS451VSN181MP40S EKHS451VSN181MQ25S EKHS451VSN221MP45S EKHS451VSN221MQ30S EKHS451VSN271MP50S EKHS451VSN271MQ35S EKHS451VSN271MR25S EKHS451VSN271MA25S EKHS451VSN331MP60S EKHS451VSN331MQ40S EKHS451VSN331MR30S EKHS451VSN391MQ45S EKHS451VSN391MR35S EKHS451VSN391MA30S EKHS451VSN471MQ50S EKHS451VSN471MR40S EKHS451VSN471MA35S EKHS451VSN561MQ60S EKHS451VSN561MR45S EKHS451VSN561MA40S EKHS451VSN681MR50S EKHS451VSN681MA45S EKHS451VSN681MA50S EKHS451VSN821MR60S EKHS451VSN821MA55S EKHS451VSN102MA60S EKHS4H1VSN820MP25S EKHS4H1VSN101MP30S EKHS4H1VSN101MQ25S EKHS4H1VSN121MP35S EKHS4H1VSN121MQ30S EKHS4H1VSN151MP40S EKHS4H1VSN151MP45S EKHS4H1VSN151MR25S EKHS4H1VSN181MP50S EKHS4H1VSN181MQ35S EKHS4H1VSN181MQ40S EKHS4H1VSN181MR30S EKHS4H1VSN181MA25S WV (Vdc) 475 500 Cap (µF) 220 220 220 270 270 270 330 330 330 390 390 470 470 560 680 68 82 82 100 120 120 120 150 150 180 180 180 180 180 220 220 220 220 270 270 270 270 330 330 390 390 470 560 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 22 × 60 25.4 × 45 30 × 35 25.4 × 50 30 × 40 35 × 30 25.4 × 60 30 × 45 35 × 35 30 × 50 35 × 40 30 × 60 35 × 45 35 × 50 35 × 60 22 × 25 22 × 30 25.4 × 25 22 × 35 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4× 35 22 × 50 25.4 × 40 25.4 × 45 30 × 30 35 × 25 22 × 60 25.4 × 50 30 × 35 35 × 30 25.4 × 60 30 × 40 30 × 45 35 × 35 30 × 50 35 × 40 30 × 60 35 × 45 35 × 50 35 × 60 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 1.31 1.31 1.26 1.47 1.44 1.35 1.67 1.63 1.51 1.80 1.70 2.05 1.91 2.13 2.44 0.61 0.70 0.72 0.79 0.89 0.89 0.90 1.01 1.04 1.13 1.16 1.18 1.11 1.08 1.31 1.33 1.26 1.22 1.51 1.44 1.47 1.37 1.66 1.57 1.87 1.74 1.95 2.22 Part No. EKHS4H1VSN221MP60S EKHS4H1VSN221MQ45S EKHS4H1VSN221MR35S EKHS4H1VSN271MQ50S EKHS4H1VSN271MR40S EKHS4H1VSN271MA30S EKHS4H1VSN331MQ60S EKHS4H1VSN331MR45S EKHS4H1VSN331MA35S EKHS4H1VSN391MR50S EKHS4H1VSN391MA40S EKHS4H1VSN471MR60S EKHS4H1VSN471MA45S EKHS4H1VSN561MA50S EKHS4H1VSN681MA60S EKHS501VSN680MP25S EKHS501VSN820MP30S EKHS501VSN820MQ25S EKHS501VSN101MP35S EKHS501VSN121MP40S EKHS501VSN121MQ30S EKHS501VSN121MR25S EKHS501VSN151MP45S EKHS501VSN151MQ35S EKHS501VSN181MP50S EKHS501VSN181MQ40S EKHS501VSN181MQ45S EKHS501VSN181MR30S EKHS501VSN181MA25S EKHS501VSN221MP60S EKHS501VSN221MQ50S EKHS501VSN221MR35S EKHS501VSN221MA30S EKHS501VSN271MQ60S EKHS501VSN271MR40S EKHS501VSN271MR45S EKHS501VSN271MA35S EKHS501VSN331MR50S EKHS501VSN331MA40S EKHS501VSN391MR60S EKHS501VSN391MA45S EKHS501VSN471MA50S EKHS501VSN561MA60S ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) 450Vdc 475, 500Vdc 50 0.77 0.70 120 1.00 1.00 300 1.16 1.16 1k 1.30 1.30 10k 1.41 1.41 50k 1.43 1.43 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T
EKHS451VSN391MQ45S 价格&库存
很抱歉,暂时无法提供与“EKHS451VSN391MQ45S”相匹配的价格&库存,您可以联系我们找货
