PSBD2FD30V01
PSBD2FD30V01
    PRISEMI(上海芯导电子)
    DFN1006-2L
    肖特基二极管 独立式 VR=30V Io=100mA IR=10μA DFN1006-2L
PSBD2FD30V01 数据手册
PSBD2FD30V01 Schottky Barrier Diode Feature  Ultra Small mold type. DFN1006-2L  Low IR  High reliability. Top view Construction Applications   Low current rectification Silicon epitaxial planar Mechanical Characteristics  Lead finish:100% matte Sn(Tin)  Mounting position: Any  Qualified max reflow temperature:260℃  Pure tin plating: 7 ~ 17 um  Pin flatness:≤3mil Electrical characteristics per line@25℃ Parameter Symbol Min. Typ. Max. Unit Conditions Forward voltage VF - - 0.35 V IF=10mA Reverse current IR - - 10 µA VR=10V Absolute maximum rating@25℃ Parameter Symbol limits Unit Reverse voltage (DC) VRM 30 V Average rectified forward current Io 100 mA Forward current surge peak (60Hz 1cyc) IFSM 500 mA Operating Junction temperature Range Tj -55 to 125 ℃ Storage temperature Tstg -40 to +125 ℃ Rev.06.2 1 www.prisemi.com Schottky Barrier Diode PSBD2FD30V01 Typical Characteristics 100 IR –Leakage Current (µA) 1000 IF –Forward Current (mA) 100 10 1.0 25℃ 0.1 0.01 0.001 0.0 0.1 0.2 0.3 0.4 0.5 125℃ 10 0℃ 0.1 0.6 25℃ 1 0 10 20 30 VF – Forward Voltage (V) VR – Reverse Voltage (V) Fig 1.Forward Voltage Fig 2.Leakage Current 40 22 CT –Total Capacitance (pF) 20 18 16 14 12 10 8 6 4 2 0 0 5 10 15 20 VR – Reverse Voltage (V) 25 30 Fig 3.Total Capacitance Rev.06.2 2 www.prisemi.com Schottky Barrier Diode PSBD2FD30V01 Solder Reflow Recommendation Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec 280 240 200 160 120 80 40 0 0 60 30 90 120 150 180 240 210 270 300 330 360 390 420 450 480 Time (sec) Product dimension (DFN1006-2L) Inches A B C R D E MIN MAX MIN MAX A 0.013 0.020 0.34 0.50 B 0.000 0.002 0.00 0.05 C 0.037 0.042 0.95 1.075 D 0.021 0.026 0.55 0.675 E 0.017 0.021 0.45 0.55 F 0.007 0.011 0.20 0.30 H R F Rev.06.2 Millimeters Dim 0.015Typ. 0.001 0.005 0.40Typ. 0.05 0.15 H 3 www.prisemi.com Schottky Barrier Diode PSBD2FD30V01 1.10 0.60 0.40 Unit:mm Ordering information Device Package Shipping PSBD2FD30V01 DFN1006-2L (Pb-Free) 10000 / Tape & Reel Rev.06.2 4 www.prisemi.com Schottky Barrier Diode PSBD2FD30V01 IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.2 5 www.prisemi.com
PSBD2FD30V01 价格&库存
很抱歉,暂时无法提供与“PSBD2FD30V01”相匹配的价格&库存,您可以联系我们找货
PSBD2FD30V01
  • 1+0.09100
  • 30+0.08775
  • 100+0.08450
  • 500+0.07800
  • 1000+0.07475
  • 2000+0.07280
