MBRB20100CT
MBRB20100CT
    SMCDIODESOLUTIONS(桑德斯)
    D²PAK
MBRB20100CT 数据手册
MBRB20100CT Technical Data Data Sheet N0791, Rev. B MBRB20100CT SCHOTTKY RECTIFIER Features 150℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request          D2PAK Circuit Diagram Applications     Switching power supply Converters Free-Wheeling diodes Reverse battery protection Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (Per Device) Peak One Cycle Non-Repetitive Surge Current(Per Leg) Symbol VRRM VRWM VR Condition Max. - IF (AV) 50% duty cycle @Tc=105°C, rectangular wave form IFSM 8.3ms, Half Sine pulse Units 100 V 10(Per Leg) 20(Per Device) A 150 A Electrical Characteristics: Characteristics Forward Voltage Drop (Per Leg) * Symbol VF1 Junction Capacitance(Per Leg) Typ. Max. Units IR1 0.74 0.80 0.60 0.67 0.0006 0.80 0.90 0.70 0.80 1.0 IR2 @VR = rated VR, TJ = 125 C 0.2 6.0 mA CT @VR = 5V, TC = 25 C, fSIG = 1MHz 253 300 pF VF2 Reverse Current (Per Leg) * Condition @ 5A, Pulse, TJ = 25 C @ 10A, Pulse, TJ = 25 C @ 5A, Pulse, TJ = 125 C @ 10A, Pulse, TJ = 125 C @VR = rated VR, TJ = 25 C * Pulse width < 300 µs, duty cycle < 2%  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  V V mA MBRB20100CT Technical Data Data Sheet N0791, Rev. B Thermal-Mechanical Specifications: Characteristics Junction Temperature Storage Temperature Typical Thermal Resistance Junction to Case(Per Leg) Approximate Weight Case Style Symbol TJ Tstg RJC wt Condition DC operation - Specification -55 to +150 -55 to +150 2.0 D2PAK Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1.85 Units C C C/W g MBRB20100CT Technical Data Data Sheet N0791, Rev. B Mechanical Dimensions D2PAK Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Ordering Information Device Dimensions in millimeters Min. 4.47 0 2.59 0.71 1.17 0.31 1.17 8.50 6.40 10.01 7.6 9.98 Typical Max. 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.31 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 14.6 2.00 1.12 1.30 0.25BSC 5° 4° 4° 0 4.85 0.25 2.89 0.96 1.37 0.61 1.37 8.90 15.6 2.74 1.42 2.20 8° Marking Diagram Package Shipping MBRB20100CT D2PAK 800pcs / reel MBRB20100CTTR D2PAK 800pcs / reel Where XXXXX is YYWWL MBR B 20 100 CT SSG YY WW L For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Device Type = Package type = Forward Current (20A) = Reverse Voltage(100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification D2PAK SYMBOL A B C d E F P0 P P1 W Millimeters Min. Max. 10.70 16.03 5.11 1.45 1.65 11.40 3.90 15.90 1.90 23.90  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  10.90 16.23 5.31 1.65 1.85 11.60 4.10 16.10 2.10 24.30 MBRB20100CT Technical Data Data Sheet N0791, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
MBRB20100CT 价格&库存
很抱歉,暂时无法提供与“MBRB20100CT”相匹配的价格&库存,您可以联系我们找货
