AMWPH5030S330MT
AMWPH5030S330MT
    SUNLORD(顺络)
    功率电感 33µH ±20% 5030 5.00 x 5.00mm 2.90mm 0.75A
AMWPH5030S330MT 数据手册
Wire Wound SMD Power Inductors – AMWPH Series Operating Temp. : -40℃~+125℃ (Including self-heating) FEATURES  High saturation current, low DC resistance  Excellent temperature stability  High reliability,  AEC-Q200 verified APPLICATIONS  Infotainment system  LED lighting  Airbag  Power supply system except for power engineer chassis and safety system PRODUCT IDENTIFICATION AMWPH 6045 S 2R2 M T ① ② ③ ④ ⑤ ⑥ ① ③ Type AMWPH ② Feature Type Wire Wound SMD Power Inductor S External Dimensions (L×W×H) [mm] S Type ④ Nominal Inductance 3015 3.0×3.0×1.5 Example Nominal Value 4018 4.0×4.0×1.8 2R2 2.2μH 5030 5.0×5.0×2.9 100 10μH 6045 6.0×6.0×4.4 ⑤ ⑥ Packing T Tape & Reel Inductance Tolerance N ±30% M ±20% SHAPE AND DIMENSIONS B C E F A E D D Recommended PCB pattern Unit: mm Series A B AMWPH3015S 3.0±0.2 3.0±0.2 AMWPH4018S 4.0±0.2 4.0±0.2 AMWPH5030S 5.0±0.2 AMWPH6045S 6.0±0.3 Sunlord C D E F a b c 1.5±0.15 2.5±0.2 0.9±0.2 / 1.0Typ. 1.4Typ. 2.7Typ. 1.8±0.2 3.3±0.2 1.1±0.2 / 1.2Typ. 1.8Typ. 3.7Typ. 5.0±0.2 2.9±0.2 4.0±0.2 1.25±0.2 2.3 Typ. 1.8Typ. 2.0Typ. 4.2Typ 6.0±0.3 4.4±0.2 4.9±0.3 1.55±0.3 2.8 Typ. 2.5 Typ. 2.2Typ. 5.7Typ. Specifications subject to change without notice. Please check our website for latest information. Revised 2020/08/12 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS AMWPH3015S Series Inductance DC Resistance Saturation Current Heat Rating Current Typ. Typ. Parameters 0.1MHz,1V Max. Typ. Unit uH Ω A A Symbol L DCR Isat Irms AMWPH3015S1R0NT 1.0±30% 0.043 0.036 2.75 2.40 AMWPH3015S1R5NT 1.5±30% 0.052 0.043 2.20 2.22 AMWPH3015S2R2MT 2.2±20% 0.068 0.057 1.70 1.92 AMWPH3015S3R3MT 3.3±20% 0.098 0.082 1.50 1.55 AMWPH3015S4R7MT 4.7±20% 0.120 0.100 1.15 1.47 AMWPH3015S6R8MT 6.8±20% 0.180 0.150 1.00 1.20 AMWPH3015S100MT 10±20% 0.288 0.240 0.80 0.95 AMWPH3015S150MT 15±20% 0.360 0.300 0.70 0.84 AMWPH3015S220MT 22±20% 0.552 0.460 0.56 0.70 AMWPH3015S330MT 33±20% 1.092 0.910 0.48 0.50 AMWPH3015S470MT 47±20% 1.248 1.040 0.35 0.48 AMWPH3015S101MT 100±20% 2.880 2.400 0.25 0.30 Saturation Current Heat Rating Current Typ. Typ. AMWPH4018S Series Inductance DC Resistance Parameters 0.1MHz,1V Max. Typ. Unit uH Ω A A Symbol L DCR Isat Irms AMWPH4018S1R0NT 1.0±30% 0.036 0.030 5.50 3.00 AMWPH4018S1R5NT 1.5±30% 0.043 0.036 4.60 2.85 AMWPH4018S2R2MT 2.2±20% 0.060 0.050 4.00 2.55 AMWPH4018S3R3MT 3.3±20% 0.066 0.055 2.90 2.50 AMWPH4018S4R7MT 4.7±20% 0.094 0.078 2.20 2.00 AMWPH4018S6R8MT 6.8±20% 0.127 0.106 1.90 1.75 AMWPH4018S8R2MT 8.2±20% 0.172 0.143 1.85 1.50 AMWPH4018S100MT 10±20% 0.187 0.156 1.50 1.48 AMWPH4018S120MT 12±20% 0.278 0.232 1.75 1.10 AMWPH4018S150MT 15±20% 0.354 0.295 1.50 1.00 AMWPH4018S220MT 22±20% 0.408 0.340 1.20 0.95 AMWPH4018S330MT 33±20% 0.582 0.485 1.00 0.70 AMWPH4018S470MT 47±20% 0.774 0.645 0.70 0.65 Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2020/08/12 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS AMWPH5030S Series Inductance DC Resistance Saturation Current Heat Rating Current Typ. Typ. Parameters 0.1MHz,1V Max. Typ. Unit uH Ω A A Symbol L DCR Isat Irms AMWPH5030SR47NT 0.47±30% 0.013 0.011 13.00 5.15 AMWPH5030S1R0NT 1.0±30% 0.017 0.014 9.50 4.55 AMWPH5030S1R5NT 1.5±30% 7.50 4.00 AMWPH5030S2R2MT 2.2±20% 0.038 0.032 7.10 3.20 AMWPH5030S3R3MT 3.3±20% 0.043 0.036 5.10 2.75 AMWPH5030S4R7MT 4.7±20% 0.068 0.057 4.50 2.40 AMWPH5030S100MT 10±20% 0.115 0.096 3.15 1.60 AMWPH5030S220MT 22±20% 0.254 0.212 1.95 0.88 AMWPH5030S330MT 33±20% 0.367 0.306 1.55 0.75 0.022 0.018 AMWPH6045S Series Inductance DC Resistance Saturation Current Heat Rating Current Typ. Typ. Parameters 0.1MHz,1V Max. Typ. Unit uH Ω A A Symbol L DCR Isat Irms AMWPH6045SR55MT 0.55±20% 0.009 0.007 15.50 6.50 AMWPH6045S1R0MT 1.0±20% 0.013 0.010 10.50 5.90 AMWPH6045S1R5MT 1.5±20% 0.016 0.012 8.70 5.40 AMWPH6045S2R2MT 2.2±20% 0.020 0.016 6.90 4.70 AMWPH6045S4R7MT 4.7±20% 0.040 0.030 5.15 3.40 AMWPH6045S100MT 10±20% 0.060 0.049 3.45 2.70 AMWPH6045S150MT 15±20% 0.085 0.071 2.70 2.05 AMWPH6045S220MT 22±20% 0.140 0.116 2.25 1.75 AMWPH6045S470MT 47±20% 0.300 0.225 1.50 1.20 AMWPH6045S680MT 68±20% 0.395 0.328 1.30 1.00 AMWPH6045S101MT 100±20% 0.560 0.460 1.05 0.85 Note: ※1 : Rated current: Isat or Irms, whichever is smaller. ※2 : Saturation Current : DC current at which the inductance drops approximate 30% from its value without current. ※3 : Heat Rating Current: DC current that causes the temperature rise (ΔT=40℃) from 20℃ ambient; The part temperature (ambient + temp. rise) should not exceed 125 °C under worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2020/08/12 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
AMWPH5030S330MT 价格&库存
很抱歉,暂时无法提供与“AMWPH5030S330MT”相匹配的价格&库存,您可以联系我们找货
AMWPH5030S330MT
  • 5+4.67560
  • 20+4.23999
  • 100+3.80437
  • 500+3.36876
  • 1000+3.16547
  • 2000+3.02026
AMWPH5030S330MT
    库存:7
