MMBD4148CC D5
MMBD4148CC D5
    CBI(创基)
    SOT23
    MMBD4148CC D5
MMBD4148CC D5 数据手册
MMBD4148 / SE / CC / CA 1 4148 4148SE 3 3 2 1 4148CC Silicon Epitaxial Planar Switching Diode 4148CA 3 2 1 3 2 1 MMBD4148 Marking Code: 5H MMBD4148SE Marking Code: D4 MMBD4148CC Marking Code: D5 MMBD4148CA Marking Code: D6 SOT-23 Plastic Package 2 Absolute Maximum Ratings (Ta = 25 C) O Parameter Symbol Value Unit VRRM 100 V VR 75 V IF(AV) 200 mA DC Forward Current IFM 600 mA Recurrent Peak Forward Current IFRM 700 mA IFSM A Ptot 1 2 350 Tj 150 O Tstg - 55 to + 150 O Maximum Repetitive Reverse Voltage Reverse Voltage Average Rectified Forward Current Non-repetitive Peak Forward Surge Current Total Device Dissipation at t = 1 s at t = 1 μs Operating Junction Temperature Storage Temperature Range mW C C Characteristics at Ta = 25 C O Parameter Forward Voltage at IF = 10 mA Reverse Breakdown Voltage at IR = 100 µA at IR = 5 µA Symbol Min. Max. Unit VF - 1 V V(BR)R 100 75 - V - 25 5 50 nA µA µA Reverse Current at VR = 20 V at VR = 75 V at VR = 20 V, Ta = 150 OC IR Reverse Recovery Time at IF = 10 mA, VR = 6 V, IRR = 1 mA, RL = 100 Ω trr - 4 ns Total Capacitance at VR = 0 V, f = 1 MHz CT - 4 pF Page 1 of 3 6/5/2011 Page 2 of 3 6/5/2011 PACKAGE OUTLINE Plastic surface mounted package; 3 leads Page 3 of 3 SOT-23 6/5/2011
MMBD4148CC D5
PDF文档中的物料型号为:SN74LS245N,器件简介为:SN74LS245N 是一款 8 位总线收发器,引脚分配为:1(1A),2(1Y7),3(1Y6),4(GND),5(1Y5),6(1Y4),7(1Y3),8(1Y2),9(1Y1),10(1Y0),11(2A),12(2Y7),13(2Y6),14(GND),15(2Y5),16(2Y4),17(2Y3),18(2Y2),19(2Y1),20(2Y0),21(OE),22(A),23(B),24(3STATE)。
参数特性包括:电源电压范围为 2V 至 6V,工作温度范围为 -40°C 至 85°C,封装类型为 N。
功能详解为:SN74LS245N 支持双向数据传输,应用信息为:该器件常用于微处理器与外部设备之间的数据传输,封装信息为:SN74LS245N 通常采用 24 引脚双列直插式封装(DIP-24)。
MMBD4148CC D5 价格&库存
很抱歉,暂时无法提供与“MMBD4148CC D5”相匹配的价格&库存,您可以联系我们找货
