78L05S
78L05S
    MDD(辰达半导体)
    SOT-23
    5V 100MA 30V
78L05S 数据手册
78L05S SOT-23 Plastic-Encapsulate Three-terminal positive voltage regulator FEATURES SOT-23 Maximum output current IO: 0.1 A Output voltage VO : 5 V Continuous total dissipation PD : SOT-23 0.35 W (Ta = 25 ℃ ) 1. OUT 2. IN 3. GND ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified) Parameter Symbol Value Unit Vl 30 V TOPR 0~+125 ℃ TSTG -55~+150 ℃ Input Voltage Operating Junction Temperature Range Storage Temperature Range ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JUNCTION TEMPERATURE (Vi=10V,Io=40mA,Ci=0.33uF,Co=0.1uF, unless otherwise specified ) Parameter er Test conditions mbol Output voltage Vo 7V≤Vi≤20V, Io=1mA~40mA MIN TYP MAX UNIT 25℃ 4.8 5.0 5.2 V 0-125℃ 4.75 5.0 5.25 V 4.75 5.0 5.25 V Io=1mA~70mA Load Regulation Line regulation ΔVo ΔVo Quiescent Current Quiescent Current Change Io=1mA~100mA 25℃ 15 60 mV Io=1mA~40mA 25℃ 8 30 mV 32 150 mV 25℃ 26 100 mV 25℃ 3.8 6 mA 0-125℃ 1.5 mA 0-125℃ 0.1 mA 7V≤Vil≤20V 8V≤Vi≤20V Iq ΔIq Iq 8V≤Vi≤20V ΔIIq 1mA≤V l≤40mA Output Noise Voltage VN 10Hz≤f≤100KHz Ripple Rejection RR 8V≤Vi≤20V,f=120Hz Dropout Voltage Vd TYPICAL APPLICATION vi 0.33μF 0-125℃ 41 25℃ 2 Ci 25℃ 78L05S 3 1 42 uV 49 dB 1.7 V Vo C0 0.1μF Note: Bypass capacitors are recommended for optimum stability and transient response and should be located as close as Possible to the regulators. http://www.microdiode.com Rev:2024A2 Page :1 78L05S Typical Characteristics http://www.microdiode.com Rev:2024A2 Page :2 78L05S Outlitne Drawing SOT-23 Package Outline Dimensions e Suggested Pad Layout 0.037 0.95 0.037 0.95 L L1 E E1 Symbol A A1 b c D E E1 e L L1 θ Dimensions In Millimeters Min Typ Max 0.90 1.40 0.10 0.00 0.30 0.50 0.20 0.08 2.80 2.90 3.10 1.20 1.60 2.80 2.25 1.80 1.90 2.00 0.10 0.50 0.4 0° 0.55 10° Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 inches mm Important Notice and Disclaimer Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Jiangsu). Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Jiangsu). http://www.microdiode.com Rev:2024A2 Page :3 78L05S SOT-23 Tape and Reel Packaging Description: SOT-23 parts are shipped in tape. The carrier tape is made from a dissipative (carbon filled) polycarbonate resin. The cover tape is a multilayer film (Heat Activated Adhesive in nature) primarily composed of polyester film,adhesive laye,sealant, and anti-static sprayed agent.These reeled parts In standard option are shipped with 3,000 units per 7" or 17.8cm diameter reel. The reels are clear in color and is made of polystyrene plastic (anti-static coated). 3000 pcs http://www.microdiode.com 7 Inch 45,000 pcs 203×203×195 180,000 pcs 438×438×220 Rev:2024A2 Page :4
78L05S 价格&库存
很抱歉,暂时无法提供与“78L05S”相匹配的价格&库存,您可以联系我们找货
78L05S
  • 10+0.49713
  • 100+0.40349
  • 300+0.35662
  • 3000+0.27141
  • 6000+0.24333
  • 9000+0.22929
库存:547
