TAI-TECH
P1
Power Inductor
UHP201610NF-SERIES
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
14/06/20
新 發 行
楊祥忠
詹偉特
林宜蕰
備
註
www.tai-tech.com.tw
TAI-TECH
P2
Power Inductor
UHP201610NF-SERIES
1. Features
1. This specification
n applies Low Profile Power Inductors.
2. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
2. Dimension
Halogen
Pb
Halogen-free
Pb-free
B
A
D
E
D
C
Series
A(mm)
B(mm)
UHP201610NF 2.0 -0.1/+0.2
C(mm)
1.6 -0.1/+0.2
D(mm)
E(mm)
1.0max. 0.60 ref.
0.80 ref.
Units: mm
3. Part Numbering
UHP
201610 NF
A
B
A: Series
B: Dimension
C: Lead Free
D: Inductance
E: Inductance Tolerance
C
4R7
M
D
E
Material
4R7=4.7uH
M=±20%;Y=±30%
4. Specification
TAI-TECH
Part Number
Inductance
(uH)
Tolerance
Test Frequency
(Hz)
DCR
(Ω) ±20%
I sat
(A) typ.
I sat
(A) Max.
I rms
(A) typ.
I rms
(A) Max.
UHP201610NF-R47Y
0.47
±30%
0.1V/1M
0.044
3.00
2.70
2.60
2.35
UHP201610NF-R68Y
0.68
±30%
0.1V/1M
0.062
2.45
2.00
2.25
2.05
UHP201610NF-1R0Y
1.0
±30%
0.1V/1M
0.080
1.95
1.80
1.75
1.60
UHP201610NF-1R5Y
1.5
±30%
0.1V/1M
0.130
1.65
1.46
1.40
1.26
0.145
1.45
1.26
1.35
1.20
0.245
1.05
0.90
1.05
0.95
0.360
0.85
0.77
1.00
0.90
UHP201610NF-2R2M
UHP201610NF-3R3M
UHP201610NF-4R7M
2.2
3.3
4.7
±20%
±20%
±20%
0.1V/1M
0.1V/1M
0.1V/1M
UHP201610NF-6R8M
6.8
±20%
0.1V/1M
0.500
0.80
0.72
0.70
0.55
UHP201610NF-100M
10
±20%
0.1V/1M
0.720
0.62
0.55
0.50
0.45
UHP201610NF-150M
15
±20%
0.1V/1M
1.400
0.50
0.45
0.40
0.36
UHP201610NF-180M
18
±20%
0.1V/1M
1.800
0.45
0.40
0.38
0.34
UHP201610NF-220M
22
±20%
0.1V/1M
2.000
0.43
0.38
0.30
0.27
Note:
Isat:Based on inductance change (△L/L0:≦-30%)@ ambient temp. 25℃
Irms:Based on temperature rise (△T:40℃.)
www.tai-tech.com.tw
TAI-TECH
P3
UHP201610NF-R47
0.8
1.2
Inductance(uH)
Inductance(uH)
0.6
0.4
0.9
0.6
0.2
UHP201610NF-R68
1.5
0.3
1
1.5
2
DCcurrent(A)
2.5
3
UHP201610NF-1R0
2
1
1.5
2
DCcurrent(A)
2.5
UHP201610NF-1R5
3
2.5
2
Inductance(uH)
Inductance(uH)
1.5
1
1.5
1
0.5
0.5
1
1.5
DCcurrent(A)
2
UHP201610NF-2R2
4
1
1.5
DCcurrent(A)
2
UHP201610NF-3R3
6
5
Inductance(uH)
Inductance(uH)
3
2
4
3
2
1
1
0.6
0.9
DCcurrent(A)
1.2
UHP201610NF-4R7
10
0.6
0.9
DCcurrent(A)
1.2
UHP201610NF-6R8
9
Inductance(uH)
Inductance(uH)
0.3
12
8
6
4
6
3
2
0.4
0.6
DCcurrent(A)
0.8
1
www.tai-tech.com.tw
0.4
0.6
DCcurrent(A)
0.8
1
TAI-TECH
P4
UHP201610NF-100
Inductance(uH)
Inductance(uH)
15
10
15
10
5
0.4
DCcurrent(A)
0.6
UHP201610NF-180
30
0.2
0.4
0.6
DCcurrent(A)
0.8
UHP201610NF-220
28
Inductance(uH)
Inductance(uH)
24
18
12
6
UHP201610NF-150
25
21
14
7
0.2
0.3
DCcurrent(A)
0.4
0.5
0.2
0.3
DCcurrent(A)
0.4
Void appearance tolerance Limit
Size of voids occurring to coating resin is specified below.
Exposed wire tolerance limit of coating resin part on product side.
Size of exposed wire occurring to coating resin is specified below.
:Acceptable when a≦w/2
1. Width direction(dimension a)
Nonconforming when a>w/2
2. Length direction(dimension b):Dimension b is not specified.
3. The total area of exposed wire occurring to each sides is
not greater than 50% of coating resin area, and is acceptable.
External appearance criterion for exposed wire
Exposed end of the winding wire at the secondary side should be 2mm and below.
www.tai-tech.com.tw
0.5
TAI-TECH
P5
5. Material
No.
Description
Specification
a.
Core
Ferrite Core
b.
Coating
Epoxy with magnetic powder
c
Termination
Tin (Pb Free)
d
Wire
Enameled Copper Wire
6. Reliability and Test Condition
Item
Operating Temperature
Performance
Test Condition
-40~+125℃
Storage Temperature
(on board)
Electrical Performance Test
Inductance L
Agilent-4291, Agilent-4287
Refer to standard electrical characteristic list
DC Resistance
Rated Current
Temperature Rise Test
Agilent-4338
Base on temp. rise & △L/L0A≦30%.
Saturation DC Current (Isat) will cause L0
to drop approximately △L(%).
ΔT 40℃Max
Heat Rated Current (Irms) will cause the coil temperature rise
approximately △T(℃) without core loss.
1.Applied the allowed DC current.
2.Temperature measured by digital surface thermometer
Mechanical Performance Test
Appearance:No damage.
Solder Heat Resistance
Temperature
(°C)
Time
(s)
Temperature
ramp/immersion
and
emersion
rate
260 ±5
(solder temp)
10 ±1
25mm/s±6 mm/s
Inductance:within±10% of initial value
RDC:within ±15% of initial value and shall not exceed the specification value
Depth: completely cover the termination
www.tai-tech.com.tw
Number
of heat
cycles
1
TAI-TECH
P6
Item
Solderability Test
Performance
Test Condition
Preheat: 150℃,60sec.。
Solder: Sn99.5%-Cu0. 5%。
Temperature: 245±5℃。
Flux for lead free: Rosin. 9.5%。
More than 95% of terminal electrode should be covered with solder.
Dip time: 4±1sec。
Reliability Test
Preconditioning:Run through IR reflow for 2 times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles
Temperature:125±2℃(Bead)
Life Test
Temperature: 85±2℃(Inductor)
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
Step1:-40±2℃ 30±5min
Thermal shock
Step2:25±2℃ ≦0.5min
Step3:105±2℃ 30±5min
Number of cycles: 500
Measured at room fempraturc after placing for 24±2 hrs
Humidity:85±2﹪R.H,
Humidity Resistance Test
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Vibration Test
www.tai-tech.com.tw
TAI-TECH
P7
7. Soldering and Mounting
7-1. Soldering
Mildly activated rosin fluxes are preferred. TAI-TECH terminations are suitable for all wave and re-flow soldering systems.
If hand soldering cannot be avoided, the preferred technique is the utilization of hot air soldering tools.
7-1.1 Solder re-flow:
Recommended temperature profiles for re-flow soldering in Figure 1.
7-1.2 Soldering Iron(Figure 2):
Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that
a soldering iron must be employed the following precautions are recommended.
‧Preheat circuit and products to 150℃
‧355℃ tip temperature (max)
‧Never contact the ceramic with the iron tip
‧1.0mm tip diameter (max)
Iron Soldering
Reflow Soldering
PRE-HEATING
SOLDERING
20~40s
PRE-HEATING
NATURAL
COOLING
TEMPERATURE(¢X
C)
TEMPERATURE(¢X
C)
217
SOLDERING
within 4~5s
TP(260¢X
C / 40s max.)
200
150
‧Use a 20 watt soldering iron with tip diameter of 1.0mm
‧Limit soldering time to 4~5 sec.
60~150s
60~180s
350
150
Gradual cooling
Over 60s
480s max.
25
TIM E(sec.)
TIME( sec.)
Reflow times: 3 times max.
Iron Soldering times: 1 times max.
Fig.1
Fig.2
7-2. Recommended PC Board Pattern
L
H
NATURAL
COOLING
L(mm)
G(mm)
H(mm)
2.3
0.7
1.7
G
www.tai-tech.com.tw
TAI-TECH
P8
8. Packaging Information
8-1. Reel Dimension
C
B
D
A
Type
A(mm)
B(mm)
C(mm)
D(mm)
7”x8mm
8.4±1.0
50 min.
13±0.8
178±2
7"x8mm
8-2. Tape Dimension / 8mm
t
P
Ao
Bo
Po:4∮0.1
W:8.0∮0.1
P2:2∮0.05
Series
Size
UHP
201610
Bo(mm) Ao(mm) Ko(mm) P(mm)
2.5±0.10
2.0±0.10 1.05±0.10 4.0±0.10 0.23±0.05
Ko
8-3. Packaging Quantity
Chip size
201610
Chip / Reel
2000
8-4. Tearing Off Force
F
Top cover tape
The force for tearing off cover tape is 15 to 80 grams
in the arrow direction under the following conditions.
165¢Xto180¢X
Base tape
Room Temp.
Room Humidity
Room atm
Tearing Speed
(hPa)
mm/min
5~35
45~85
860~1060
300
Application Notice
‧Storage Conditions(component level)
To maintain the solderability of terminal electrodes:
1. TAI-TECH products meet IPC/JEDEC J-STD-020D standard-MSL, level 1.
2. Temperature and humidity conditions: Less than 40℃ and 60% RH.
3. Recommended products should be used within 12 months form the time of delivery.
4. The packaging material should be kept where no chlorine or sulfur exists in the air.
‧Transportation
1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils.
2. The use of tweezers or vacuum pick up is strongly recommended for individual components.
3. Bulk handling should ensure that abrasion and mechanical shock are minimized.
www.tai-tech.com.tw
t(mm)
很抱歉,暂时无法提供与“UHP201610NF-100M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.26018
- 200+0.20186
- 600+0.16946
