VG2389S433N0S1
VG2389S433N0S1
    VOLLGO(沃进)
    SMD_13.5X12MM
VG2389S433N0S1 数据手册
VG2389SxxxN0S1 SUB-1G 无线模块 VG2389SxxxN0S1 无线模块 硬件规格书 V01 1 VG2389SxxxN0S1 SUB-1G 无线模块 目录 一、应用说明............................................................................................................................................................................ 1 二、技术参数............................................................................................................................................................................ 3 一、 引脚位置图....................................................................................................................................................................... 4 四、引脚说明............................................................................................................................................................................ 5 七、编程开发注意事项............................................................................................................................................................ 7 八、回流焊曲线图.................................................................................................................................................................... 7 九、静电损坏警示.................................................................................................................................................................... 7 十、封装信息............................................................................................................................................................................ 8 10.1 机械尺寸(unit:mm)................................................................................................................................................. 8 十一、版本更新说明................................................................................................................................................................ 9 十二、采购选型表.................................................................................................................................................................... 9 十三、声明.............................................................................................................................................................................. 10 十四、联系我们...................................................................................................................................................................... 10 VG2389SxxxN0S1 SUB-1G 无线模块 一、应用说明 VG2389SxxxN0S1 系列无线模块,基于 SEMTECH 的 SX1278 高性能无线收发芯片设计,是一款体积小巧、低功耗、 远距离的双向无线收发模块。 SX1278 收发器采用 LoRa®远程调制解调器,提供超长距离扩频通信和高抗干扰性,同时最大限度地减少电流消 耗。使用 Semtech 的专利 LoRa 调制技术 SX1278 可以实现超过-148dBm 的灵敏度。高灵敏度与集成+20 dBm 功率放大 器相结合,产生了业界领先的链路预算,使其适合任何需要范围或鲁棒性的应用。与传统的调制技术相比,LoRa 在 阻塞和选择性方面都具有显著的优势,解决了传统设计在距离、抗干扰性和能量消耗之间的折衷问题。这些设备还 支持 WMBus、IEEE802.15.4g 等系统的高性能(G)FSK 模式。SX1278 提供卓越的相位噪声、选择性、接收器线性度 和 IIP3,与竞争设备相比,电流消耗显著降低。 模块集成了所有射频相关功能和器件,用户不需要对射频电路设计深入了解,就可以使用本模块轻易地开发出 性能稳定、可靠性高的无线方案与无线物联网设备。 产品主要特点: 1. LORA®调制解调器 2. 168 dB 最大链路预算 3. +20 dBm-100 mW 恒定射频输出与 V 电源 4. +14 dBm 高效功率放大器 5. 可编程比特率高达 300 kbps 6. 高灵敏度:低至-148 dBm 7. 防弹前端:IIP3=-11 dBm 8. 出色的阻断免疫 9. 低 RX 电流 9.9 mA,200 nA 寄存器保留 10. 分辨率为 61hz 的全集成合成器 11. FSK、GFSK、MSK、GMSK、LoRa® 和 OOK 调制 12. 用于时钟恢复的内置位同步器 13. 前导码检测 14. 127 dB 动态范围 RSSI 1 www.vollgo.com VG2389SxxxN0S1 SUB-1G 无线模块 15. 基于超快 AFC 的射频自动检测与 CAD 16. 数据包引擎,最多 256 字节,带 CRC 17. 内置温度传感器和电池电量低指示灯 应用: 1. 智能电表 2. 供应链和物流 3. 楼宇自动化 4. 农业传感器 5. 智慧城市 6. 零售店传感器 7. 资产跟踪 8. 路灯 9. 驻车传感器 10. 环境传感器 11. 医疗保健 12. 安全和安保传感器 13. 远程控制应用程序 2 www.vollgo.com VG2389SxxxN0S1 SUB-1G 无线模块 二、技术参数 技术指标 参数 备注 电压范围 1.8 ~ 3.7V 一般应用 3.0V/3.3V 频率范围 433MHz、490MHz 适用频段由硬件决定 输出功率 -1 ~ 20dBm 步进值 1dBm 无线速率 1.2kbps ~ 300Kbps@FSK 可编程配置 0.018kbps ~ 37.5kbps@LoRa 调制方式 FSK, GFSK, MSK, GMSK, LoRa® , OOK 接收灵敏度 -148dBm@LORA,SF=12,BW=7.8kHz 接收带宽 2.6kHz ~ 250kHz@FSK 可编程配置 7.8kHz ~ 500kHz@ LoRa 发射电流 120mA 接收电流 12mA@Bands 2&3 休眠电流
VG2389S433N0S1 价格&库存
很抱歉,暂时无法提供与“VG2389S433N0S1”相匹配的价格&库存,您可以联系我们找货
