UAT36A05L05
UAT36A05L05
    BRIGHTKING(君耀)
    SOT-363
    该器件是浪涌额定二极管阵列,旨在保护高速数据接口。它专门设计用于保护连接到数据和传输线路的敏感元件,使其免受静电放电(ESD)、电快速瞬变(EFT)和雷击引起的过电压影响。该器件的独特设计在单个封装中...
UAT36A05L05 数据手册
UAT36A05L05& UAT56A05L05 Electrostatic Discharged Protection Devices (ESD) Data Sheet Description The device is surge rated diode arrays designed to protect high speed data interfaces. It has been specifically designed to protect sensitive components which is connected to data and transmission lines from overvoltage caused by electrostatic discharge (ESD), electrical fast transients (EFT), and lightning. The unique design of the device incorporates one surge rated, and four data lines. Low capacitance steering diodes and a TVS diode in a single package. The low capacitance array configuration allows the user to protect four high speed data or transmission lines. Features ● ● ● ● ● ● ● ● ● ● ● ● ● IEC61000-4-2 ESD 15KV Air, 8KV contact compliance Protects four high-speed data lines and one power line Array of surge rated, low capacitance diodes Working voltage: 5V Low leakage current Low clamping voltage Solid-state silicon avalanche technology Lead Free/RoHS compliant Solder reflow temperature: Pure Tin-Sn, 260~270℃ Flammability rating UL 94V-0 Meets MSL level 1, per J-STD-020 UAT36A05L05 (Marking: B T35), SOT-363 UAT56A05L05 (Marking: B T55), SOT-563 6 5 4 1 2 3 Pin Configuration Applications ● ● ● ● USB power and data line protection 10/100/1000 Ethernet Video line protection I2C bus protection ● ● ● ● WAN/LAN equipment ISDN S/T interface Microcontroller input protection Portable electronics Maximum Ratings Rating Symbol Value Unit IPP 3 A Peak pulse current (tp=8/20μs) ESD voltage (Contact discharge) ±8 VESD ESD voltage (Air discharge) Storage & operating temperature range Revision:ESD-UAT36A05L05& UAT56A05L05-001(A1) TSTG ,TJ 1/7 kV ±15 -55~+150 ℃ http://brightking.pulseelectronics.com UAT36A05L05& UAT56A05L05 Electrical Characteristics (TJ=25℃) Parameter Symbol Reverse stand-off voltage Condition Min. Typ. VRWM Reverse breakdown voltage Max. Unit 5 V VBR IBR=1mA 6 V Reverse leakage current IR VR=5V Each I/O pin 1 μA Clamping voltage (tp=8/20μs) VC IPP=1A 9.8 V Clamping voltage (tp=8/20μs) VC IPP=2A 15 V Off state junction capacitance CJ 0Vdc,f=1MHz Between I/O pins and GND 1 pF Applications Information DVI connector Tx0- Rx0- Tx0+ Rx0+ X X Tx1- Rx1- Tx1+ Rx1+ Tx2- Rx2- Tx2+ Rx2+ X X TCTC+ RCUAT36A05L05/UAT56A05L05 RC+ DVI Data Line Protection Revision:ESD-UAT36A05L05& UAT56A05L05-001(A1) 2/7 http://brightking.pulseelectronics.com UAT36A05L05& UAT56A05L05 ESD Protection Standards IEC61000-4-2 Interfaces of consumer electronic equipment are widely specified according to the International Electrotechnical Commission standard IEC61000-4-2. This standard is not targeted towards particular devices but towards general equipment, systems and subsystems that may be involved in electrostatic discharge. consists of a 150pF capacitor and a 330Ω series resistor representing the counterpart to the Device Under Test (DUT). IPP 100% 330Ω 50MΩ to 100MΩ v high-voltage generator 90% DUT 150pF 10% 001aaf202 t tr=0.7ns to 1ns Test circuit according IEC61000-4-2 30ns 60ns ESD surge according IEC61000-4-2 Human Body Model (HBM, MIL-883E method 3015.7) The HBM standard simulates an ESD surge generated by human contact to electronic components. IPP 1.5kΩ 10MΩ to 100MΩ Ir
