TPSP3050-04HTG
TPSP3050-04HTG
    TECHPUBLIC(台舟)
    SOT23-6
    这款静电放电(ESD)为电压敏感部件提供保护。绝佳的箱位功能、低泄漏和快速响应时间为接触ESD的设计提供了业内最佳的保护。由于尺寸小,因此适用于智能手机、智能手表或板空间非常宝贵的其它许多便携式/可穿...
TPSP3050-04HTG 数据手册
TPSP3050-04HTG Low Capactiance 4-Line TVS Array WWW.SOT23.COM.TW Features Mechanical Characteristics       Ultra low capacitance: 0.35 pF typical (I/O to I/O) Ultra low leakage: nA level Low operating voltage: 5V Low clamping voltage Up to 4 data lines and one power line protects Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±25kV Contact discharge: ±25kV – IEC61000-4-4 (EFT) 40A (5/50ns)  ROHS Compliant              3000 USB 2.0 and USB 3.0 Ports USB OTG Digital video interface(DVI) Monitor and Flat Panel Displays PCI Express and Serial SATA Ports Gigabit Ethernet IEEE 1394 firewire ports Consumer products (STB, DVD, DSC, DVC…) BL Reel Size 7” CH PU TPSP3050-04HTG Qty per Reel IC Applications Ordering Information Part Number Package: SOT23-6 Lead Finish: Matte Tin Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 TE Dimensions and Pin Configuration Circuit and Pin Schematic 1 1 TPSP3050-04HTG Low Capactiance 4-Line TVS Array WWW.SOT23.COM.TW Absolute Maximum Ratings (Tamb=25°C unless otherwise specified) Parameter Value Symbol ESD per IEC 61000−4−2 (Air) ±25 VESD Operating Temperature Range Storage Temperature Range ±25 kV TJ −55 to +125 °C Tstg −55 to +150 °C IC ESD per IEC 61000−4−2 (Contact) Unit Electrical Characteristics (TA=25°C unless otherwise specified) Reverse Working Voltage VBR IR Clamping Voltage VC CJ CJ TE Junction Capacitance 6 CH Reverse Leakage Current Typ Max 5 VRWM Breakdown Voltage Junction Capacitance Min Note 1: I/O pins are Pin 1, 3, 4 and 6 2 Unit BL Symbol PU Parameter 0.35 Test Condition V Any I/O pin to ground V IT = 1mA, any I/O pin to ground 0.3 µA VRWM = 5V, any I/O pin to ground 20 V IPP = 3A (8 x 20µs pulse) any I/O pin to ground 0.4 pF VR = 0V, f = 1MHz, between I/O pins 0.8 pF VR = 0V, f = 1MHz, any I/O pin to ground TPSP3050-04HTG Low Capactiance 4-Line TVS Array WWW.SOT23.COM.TW PROTECTION PRODUCTS Typical charateristics Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 80 60 40 td=t IPP/2 0 0 5 10 15 20 25 30 CH Power Derating Curve 110 100 90 80 70 60 50 40 30 20 10 0 TE % of Rated Power PU t - Time ( s) Fig3. 0 25 50 75 100 125 10% BL 20 90% IC IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP Percent of Peak Pulse Current % tr 150 Ambient Temperature –TA (ºC) 3 tr = 0.7~1ns 30ns 60ns Time (ns) TPSP3050-04HTG Low Capactiance 4-Line TVS Array TE CH PU BL IC WWW.SOT23.COM.TW 4
TPSP3050-04HTG
物料型号:TPSP3050-04HTG
器件简介: - 该器件是一个低电容4线TVS阵列,具有超低电容(典型值0.35pF,I/O到I/O)和超低漏电流(纳安级别)。 - 工作电压低(5V),具有低钳位电压,并且可以保护多达4条数据线和1条电源线。 - 符合IEC 61000-4-2(ESD)和IEC61000-4-4(EFT)标准,并且是RoHS合规的。
引脚分配: - 该器件采用SOT23-6封装,引脚配置在PDF中有详细的电路和引脚示意图。
参数特性: - 绝对最大额定值包括ESD耐压±25kV(空气放电和接触放电),工作温度范围-55°C至+125°C,存储温度范围-55°C至+150°C。 - 电气特性包括反向工作电压5V,击穿电压6V,反向漏电流最大0.3A,钳位电压20V,结电容在0.35pF至0.8pF之间。
功能详解: - 该器件适用于多种应用场景,包括USB 2.0和3.0端口、USB OTG、数字视频接口(DVI)、显示器和平板显示器、PCI Express和串行SATA端口、千兆以太网、IEEE 1394火线端口以及消费电子产品。
应用信息: - 器件适用于高速数据传输和接口保护,如USB端口、DVI接口、以太网等。
封装信息: - 封装类型为SOT23-6,引脚镀锡处理,使用“绿色”成型化合物,UL阻燃等级94V-0,湿度敏感性等级3,符合J-STD-020标准。
TPSP3050-04HTG 价格&库存
很抱歉,暂时无法提供与“TPSP3050-04HTG”相匹配的价格&库存,您可以联系我们找货
