SHANGHAI
June 2006
MICROELECTRONICS CO., LTD.
SESD3ZxxC
Transient Voltage Suppressors for ESD Protection
General Description
Revision:B
Features
The SESD3ZxxC is designed to protect voltage
z
Small Body Outline Dimensions
sensitive components from ESD and transient voltage
z
Low Body Height
events. Excellent clamping capability, low leakage, and
z
Peak Power up to 350 Watts @ 8 x 20 µs Pulse
fast response time, make these parts ideal for ESD
z
Low Leakage current
protection on designs where board space is at a
z
Response Time is Typically < 1 ns
premium.
z
ESD Rating of Class 3 (> 16 kV) per Human
Body Model
Applications
z
Cellular phones
Complies with the following standards
z
Portable devices
IEC61000-4-2
z
Digital cameras
Level 4
z
Power supplies
15 kV (air discharge)
8 kV(contact discharge)
MIL STD 883E - Method 3015-7 Class 3
25 kV HBM (Human Body Model)
Functional diagram
SOD-323
Absolute Ratings (Tamb=25°C)
Symbol
Parameter
Value
Units
PPK
Peak Pulse Power (tp = 8/20μs)
350
W
TL
Maximum lead temperature for soldering during 10s
260
°C
Tstg
Storage Temperature Range
-55 to +155
°C
Top
Operating Temperature Range
-40 to +125
°C
TJ
Maximum junction temperature
150
°C
ShangHai Sino-IC Microelectronics Co., Ltd.
1.
SESD3ZxxC
Electrical Parameter
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
IT
VBR
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @
VRWM
Test Current
Breakdown Voltage @ IT
Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwise specified.
VBR
C
IT
VRWM
Typ.
IR
Min.
Typ.
Max.
V
V
V
mA
V
µA
pF
SESD3Z5C
5.4
6.7
7.8
1
5.0
1
200
SESD3Z12C
13.3
14.5
15.7
1
12.0
1
100
Part Numbers
(Note1)
1. Capacitance is measured at f=1MHz, VR=0V,TA=25℃.
Typical Characteristics
Fig1. Pulse Waveform
Fig2.Power Derating Curve
2.
SESD3ZxxC
Application Note
Electrostatic discharge (ESD) is a major cause of failure in electronic systems. Transient Voltage
Suppressors (TVS) are an ideal choice for ESD protection. They are capable of clamping the incoming
transient to a low enough level such that damage to the protected semiconductor is prevented.
Surface mount TVS offers the best choice for minimal lead inductance. They serve as parallel
protection elements, connected between the signal lines to ground. As the transient rises above the
operating voltage of the device, the TVS becomes a low impedance path diverting the transient current to
ground. The SESD3ZxxC is the ideal board evel protection of ESD sensitive semiconductor components.
The tiny SOD-323 package allows design flexibility in the design of high density boards where the
space saving is at a premium. This enables to shorten the routing and contributes to hardening against
ESD.
SOD-323 Mechanical Data
Dimensions
Dim
Inches
Mil
Min
Max
Min
Max
A
0.060
0.071
1.5
1.8
B
0.045
0.054
1.2
1.4
C
0.060
0.107
2.3
2.7
D
0.043
1.1
E
0.012
0.016
0.3
0.4
F
0.004
0.010
0.10
0.25
H
0.004
0.10
CONTROLLILNG DIMENSION: MILLIMETERS
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd.
© 2005 SINO-IC – Printed in China – All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong,
Shanghai 201203, China
Phone: +86-21-33932402 33932403 33932405 33933508 33933608
Fax: +86-21-33932401
Email: szrxw002@126.com
Website: http://www.sino-ic.net
3.
很抱歉,暂时无法提供与“SESD3Z5C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.30510
- 200+0.25326
- 600+0.22443
- 3000+0.19138
- 9000+0.17637
- 21000+0.16827
