GS3M
GS3M
    PINGWEI(平伟)
    DO-214AB(SMC)
GS3M 数据手册
GS3M GS3M 3.0AMPS. GLASS PASSIVATED SURFACE MOUNT RECTIFIERS FEATURE SMC(DO-214AB) .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed: 260℃/10 seconds at terminals. .For surface mounted application. .Easy pick and place. .128(3.25) .108(2.75) .280(7.11) .260(6.60) .320(8.13) .305(7.75) .103(2.62) .079(2.00) MECHANICAL DATA .245(6.22) .220(5.59) .012(0.305) .006(0.152) .Case: Molded plastic .Epoxy: UL94V-0 rate flame retardant (Halogen free) .01182(0.3) .060((1.52) .00788(0.2) .Lead: MIL-STD- 202E, Method 208 guaranteed .008(0.203) .030(0.76) .Polarity:Color band denotes cathode end .002(0.051) .Packaging:12mm tape per EIA STD RS-481 Dimensions in inches and (millimeters) .Weight: 0.23 grams Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% MAXIMUM RATINGS (TC=25℃ unless otherwise noted) Parameter Symbol Maximum Recurrent Peak Reverse Voltage VRRM VRMS VDC IF(AV) IFSM trr Maximum RMS Voltage Maximum DC blocking Voltage Average Forward Rectified Current Non-repetitive forward surge current,8.3mS half sine-wave Maximum Reverse Recovery Time (Note 1) Typical Junction Capacitance (Note 2) Instantaneous Forward voltage at 3.0A @T J =25°C reverse current at rated DC blocking voltage @TJ=25°C Typical Thermal Resistance @TJ=125°C (Note 3) Operation Junction Temperature and Storage Temperature CJ VF GS3M Min Typ Units Max 1000 V 700 V 1000 V 3.0 A 120 A 5 20 us pF 1.15 V IR 10.0 250.0 uA RthJL TJ, TSTG 13 K /W Note: 1.Conditions:IF=0.5A, IR=1.0A, IRR=0.25A 2.TJ=25℃,VR = 4VDC@1MHz 3.Measured on P.C.Board with15.0mm*15.0mm*1.6mm Copper Pad Areas -1- -55 to + 150 °C GS3M RATING AND CHARACTERISTIC CURVES (GS3M) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 10 3.0 1.5 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 1.0 .1 .01 200 TJ=25℃ Pulse Width=300μs 1% Duty Cycle LEAD TEMPERTURE,(℃) 1.0 .8 .6 1.2 1.4 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 100 TJ=125℃ 8.3ms Single Half Sine-Wave (JEDEC Method) 120 INSTANEOUS REVERSE CURRENT,(μA) PEAK FORWARD SURGE CURRENT,(A) 160 80 40 0 1 10 100 TJ=100℃ 10 1.0 .1 TJ=25℃ 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz -2- GS3M Marking and packaging illustration 1、Marking B GS3M XXX SYMBOL A B C C A Explanation Color Band Denotes Cathode Product Name Date code 3、Packaging d Top cover tape thickness 0.10mm(0.004") max.thick W1 Embossed carrier tape °MAX °MAX A SPECIFICATIONS Embossed cavity Carrier width SYM BOL A SMC (DO-214AB) 6.15(0.242)Max SPECIFICATIONS mm(inch) SYM ITEM BOL K Carrier depth Carrier length B 8.41(0.331)Max Punch hole pitch P 8.00(0.315)Typ Sprocket hole d ø1.55(0.061)Typ Sprocket hole pitch P0 4.00(0.157)Typ Reel outer diameter D 330.0(13.0)Typ Embossment center P1 2.00(0.079)Typ Reel inner diameter D1 74.0(2.913)Min Overall tape thickness T 0.25(0.010)Typ Feed hole diameter D2 13.0(0.512)Typ Tape width W 16.0(0.430)Typ Sprocket hole position J 1.75(0.069)Typ Reel width W1 16.5(0.650)Min Punch hole position H 7.50(0.295)Typ mm(inch) ITEM PACKAGE -3- PACKAGE SMC (DO-214AB) 2.54(0.100)Typ
很抱歉,暂时无法提供与“GS3M”相匹配的价格&库存,您可以联系我们找货
