P3500SC
P3500SC
    SEMBO(深波)
    SMB(DO-214AA)
P3500SC 数据手册
Thyristor Surge Suppressor P3500SC Features Fails short circuit when surged in excess of ratings Low voltage overshoot High repetitive surge current capability Low on‐state voltage     DO-214AA (SMB) Main Applications Customer Premises Equipment (CPE) Modems, Line cards, DSL, ISDN, T‐1/E‐1 Data lines and security systems Fax machines, Telephones etc.     Thermal Ratings Type Number Symbol Value Units Operating Junction Temperature Range TJ -40 to + 150 °C Storage Temperature Range TS -65 to + 150 °C RθJA 90 °C/W Thermal Resistance: Junction to Ambient Package Dimensions DO-214AA/SMB F B1 E B A C1 D C A B B1 C C1 D E F Min 4.06 3.30 1.95 5.21 0.76 - Max Min Max 4.57 0.16 0.18 3.94 0.13 0.155 2.20 0.077 0.086 5.59 0.205 0.22 1.52 0.03 0.06 0.203 0.008 2.13 2.44 0.152 0.305 0.084 0.096 0.006 0.012 Dim Millimeters (mm) Inches (inch) http://www.sembo.com.cn Thyristor Surge Suppressor P3500SC Ordering Information P 3500 S C C: I PP=150A SMB Voltage Electrical Characteristics (T A=25ºC unless noted otherwise) Part VDRM VS IH IS IT VT CO Number V min V max mA min mA max A max V max pF min pF max P3500SC 320 400 150 800 2.2 4 25 110 Note: 1. VDRM@IDRM=5μA, VS@100V/μs, VT@IT=2.2A, CO@1MHz,2V Surge Ratings IPP Series C IPP IPP 10x160μs IPP 10x560μs IPP 2x10μs 8x20μs 10x1000μs Amps Amps Amps Amps Amps 500 400 200 150 100 ITSM 50/60Hz Amps 30 Note: 1. Peak pulse current rating (IPP) is non‐repetitive and guaranteed for the life of the product. 2. IPP ratings applicable over temperature range of ‐40℃ to +85℃ 3. The device must initially be in thermal equilibrium with ‐40℃< TJ
P3500SC 价格&库存
很抱歉,暂时无法提供与“P3500SC”相匹配的价格&库存,您可以联系我们找货
