ACM4520F-401T25
ACM4520F-401T25
    MELED(美莱)
    FILTER-4P_4.7X4.5MM_SM
    ACM4520F-401T25
ACM4520F-401T25 数据手册
Meled Wire Wound Type Common Mode Filter S P E C I F I C AT I O N S Customer: Customer P/N: Seri es ACM- Drawing No: Quantity: 0 Pcs. Chilisin P/N: Date : 2017/09/06 Series/參照 ACM- SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED For Customer approval Only Qualification Status: Full Approved By Verified By Restricted Rejected Re-checked By Checked By Comments: Meled Electronics Co., Ltd. www.meledinc.com Meled Wire Wound Type Common Mode Filter Version change history Rev. Effective Date Changed Contents Change Reasons Approved By 01 / New release / / www.meledinc.com Meled Wire Wound Type Common Mode Filter 1. Features 1. High common mode impedance at high frequency cause excellent noise suppression performance. 2. ACM series realizes small size and low profile. 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~+125℃ (Including self - temperature rise) 2.APPLICATIONS ● ● ● USB2.0 of IEEE1394, PC, peripheral equipments, small digital AV equipments, etc. LVDS lines of Note PC, LCD Audio lines 3. PRODUCT IDENTIFICATION ACM □□□□ T -□□□ □ □□ Rated Current Packaging Impedance Material Code Dimension Scope 4. ShapeandDimensions [ Table 4-1] Unit: mm [inch] Part Number A C D E F 4.5±0.5 2.0 Max 2.7 Ref 0.7±0.2 1.2±0.2 1.0±0.2 6.0±0.5 3.8 Max 3.5 Ref 1.5±0.2 1.5±0.2 1.75±0.2 7.0±0.5 4.8 Max 5.7 Ref 1.5±0.2 2.0±0.2 1.70±0.2 12.0±0.5 10.8±0.5 6.4 . Max 7.0 . Ref 2.7±0.2 . . 2.5±0.2 . . 2.50±0.2 . . 15.0±0.5 13.0±0.5 6.0 . Max 10.4 . Ref 2.7±0.2 . . 3.8±0.2 . . 2.30±0.2 . . ACM4520 4.7±0.5 ACM7060 7.0±0.5 ACM9070 9.0±0.5 ACM1211 ACM1513 B www.meledinc.com G Meled 5. Circuit Wire Wound Type Common Mode Filter Diagram Appendix A: Electrical Characteristics I. ACM4520 Series Common Mode Filter Part Number Z() at 100MHz DCR Max. Irated. (A) IR (M) Rated Voltage Min (V) Max Min Typ. (m) ACM4520 -301T30 100 300 45 3.0 10 50 ACM4520 -401T25 200 400 50 2.5 10 50 ACM4520 -701T22 500 700 59 2.2 10 50 ACM4520 -901T21 700 900 68 2.1 10 50 ACM4520 -102T21 800 1000 68 2.1 10 50 ACM4520 -122T20 1000 1200 74 2.0 10 50 ACM4520 -142T19 1200 1400 81 1.9 10 50 IR (M) Rated Voltage Min (V) Max II. ACM7060 Series Common Mode Filter Part Number Z() at 100MHz DCR Max. Irated. (A) Min Typ. (m) ACM7060 -400T150 40 70 5 15.0 10 125 ACM7060 -101T90 100 140 10 9.0 10 125 ACM7060 -301T50 225 300 10 5.0 10 125 ACM7060 -501T50 275 350 10 5.0 10 125 ACM7060 -701T40 500 700 15 4.0 10 125 ACM7060 -102T30 800 1020 17 3.0 10 125 ACM7060 -132T25 910 1300 21 2.5 10 80 ACM7060 -272T10 2000 2700 63 1.0 10 125 ACM7060 -302T09 2500 3000 75 0.9 10 125 www.meledinc.com Meled Wire Wound Type Common Mode Filter III. ACM9070 Series Common Mode Filter Z() at 100MHz Part Number DCR Max. Irated.(A) IR (M) Rated Voltage Min (V) Max Min Typ. (m) ACM9070 -301T60 225 300 6 6.0 10 50 ACM9070 -501T55 450 600 8 5.5 10 50 ACM9070 -701T50 500 700 10 5.0 10 50 ACM9070 -102T40 750 1000 13 4.0 10 50 ACM9070 -222T25 1700 2200 60 2.5 10 50 IR (M) Rated Voltage Min (V) Max IV. ACM1211 Series Common Mode Filter Z() at 100MHz Part Number DCR Max. Irated.(A) Min Typ. (m) ACM1211 -800T100 80 230 2.0 10.0 10 125 ACM1211 -701T80 500 700 6.0 8.0 10 125 ACM1211 -801T80 600 800 8.0 8.0 10 125 ACM1211 -102T60 750 1000 14.0 6.0 10 125 ACM1211 -222T18 2200 2500 35.0 1.8 10 125 ACM1211 -272T15 2300 2700 50.0 1.5 10 125 IR (M) Rated Voltage Min (V) Max IIV. ACM1513 Series Common Mode Filter Z() at 100MHz Part Number DCR Max. Irated.(A) Min Typ. (m) ACM1513 -301T130 250 300 5 13.0 10 80 ACM1513 -551T100 450 550 6 10.5 10 80 ACM1513 -701T100 500 700 7 10.0 10 80 ACM1513 -152T100 1100 1500 9 10.0 10 80 Products with other electrical characteristic can be provided upon customer’s request. Please contact your local sales. www.meledinc.com
ACM4520F-401T25 价格&库存
很抱歉,暂时无法提供与“ACM4520F-401T25”相匹配的价格&库存,您可以联系我们找货
