SL54BF
Reverse Voltage 40 Volts
Forward Current - 5.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
SMBF
Metal silicon junction,majority carrier conduction
For surface mounted applications
Low power loss,high efficiency
High forward surge current capability
For use in low voltage,high frequency inverters, free
0.146(3.70)
0.138(3.50)
0.086 (2.20)
0.075 (1.90)
0.173(4.40)
0.165(4.20)
wheeling,and polarity protection applicatlons
0.051(1.30)
0.043(1.10)
Mechanical Data
Case: JEDEC 60B) molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.002 ounce, 0.057 grams
0.010(0.26)
0.007(0.18)
0.048(1.20)
0.031(0.80)
0.216(5.50)
0.200(5.10)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=65℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current TA=25℃
at rated DCblocking voltage TA=100℃
MDD
SL54BF
UNITS
VRMS
VDC
40
28
40
V
V
V
I(AV)
5.0
A
IFSM
130
A
VF
0.45
V
IR
0.3
40
mA
VRMM
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
CJ
RJA
280
pF
45
℃/W
Operating storage temperature range
T J,
-55 to+125
Operating junction temperature range
TSTG
-55 to+150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5x5cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
SL54BF
Reverse Voltage - 40 Volts
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
6.0
10
4
10
3
10
2
TJ=100°C
4.0
3.0
2.0
1.0
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μ
A
Average Forward Current (A)
5.0
TJ=75°C
101
TJ=25°C
10
Case Temperature (°C)
40
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
10
Tj=25°C
TJ=25°C
500
Junction Capacitance (pF)
Instaneous Forward Current (A)
1000
1
0.1
0.2
0.6
100
0.1
0.8
10
1
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.6- Typical Transient Thermal Impedance
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
160
100
Ta=25°C
120
100
80
60
40
8.3 ms Single Half Sine
(JEDEC
Wave
Method)
00
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance(°C/W)
Peak Forward Surage Current (A)
140
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
SL54BF
Reverse Voltage -40 Volts
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMBF
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.61
1.60
1 50
330.00
50.00
13.00
1.75
5.50
4.00
4.00
2.00
0.30
12.00
12.30
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMBF
13"
5,000
4.0
10,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
80,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
2.54
0.100
B
1.8
0.071
C
4.8
0.189
D
3.0
0.118
E
6.6
0.260
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SL54BF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.73062
- 50+0.57057
- 150+0.49054
- 500+0.43049
- 2500+0.38254
- 5000+0.35856
