SS4007
SS4007
    GW(台湾唯圣)
    SMD-2
SS4007 数据手册
SS4001 SS4007 THRU 1.0 AMP SURFACE MOUNT SILICON RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 1.0 Ampere FEATURES * Ideal for surface mount applications * Easy pick and place * Built-in strain relief * High surge current capability SS .106(2.7) .098(2.5) .051(1.3) .043(1.1) MECHANICAL DATA .144(3.65) .136(3.45) * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Terminals: Solder plated, solderable per MIL-STD-202F, method 208 guranteed * Polarity: Color band denotes cathode end * Mounting position: Any .007(0.17) .005(0.13) .037(0.95) .033(0.85) .067(1.7) .059(1.5) .033(0.85) .022(0.55) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER SS4001 SS4002 SS4003 SS4004 SS4005 SS4006 SS4007 UNITS 50 35 50 Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V at TL=75 C Peak Forward Surge Current, 8.3 ms single half sine-wave 1.0 A superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 1.0A Maximum DC Reverse Current Ta=25 C 30 1.1 5.0 A V A at Rated DC Blocking Voltage Ta=100 C Typical Junction Capacitance (Note 1) Typical Thermal Resistance RqJL (Note 2) Operating and Storage Temperature Range TJ, TSTG 50 15 30 A pF C/W C Marking Code -65 R01 NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance from Junction to Lead. 488 R02 R03 +150 R04 R05 R06 R07 RATING AND CHARACTERISTIC CURVES (SS4001 THRU SS4007) FIG.1-TYPICAL FORWARD FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 10 3.0 1.0 1.2 1.0 0.8 Single Phase 0.6 Half Wave 60Hz Resistive Or Inductive Load 0.4 0.2 0 0 20 40 60 80 100 120 140 160 180 200 LEAD TEMPERATURE,( C) Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 FIG.4-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT .01 .6 .7 .8 .9 1.0 1.1 1.2 1.3 FORWARD VOLTAGE,(V) FIG.3 - TYPICAL REVERSE CHARACTERISTICS PEAK FORWAARD SURGE CURRENT,(A) INSTANTANEOUS FORWARD CURRENT,(A) 50 50 40 30 8.3ms Single Half Tj=25 C Sine Wave 20 JEDEC method 10 0 1 100 5 50 10 100 FIG.5-TYPICAL JUNCTION CAPACITANCE 10 35 Tj=100 C JUNCTION CAPACITANCE,(pF) REVERSE LEAKAGE CURRENT, ( A) NUMBER OF CYCLES AT 60Hz 1.0 Tj=25 C .1 30 25 20 15 10 5 .01 0 0 20 40 60 80 .01 .05 .1 .5 1 100 120 140 REVERSE VOLTAGE,(V) PERCENTAGE RATED PEAK REVERSE VOLTAGE 489 5 10 50 100
SS4007 价格&库存
很抱歉,暂时无法提供与“SS4007”相匹配的价格&库存,您可以联系我们找货
