SMD1206-200C-16V
SMD1206-200C-16V
    BNSTAR(比诺星)
    SMD1206-200C-16V
SMD1206-200C-16V 数据手册
Version: 1.2 Document code:HB-WI7.3-358-2018 Effective date :2019-07-24 Page: 1 of 7 Surface-Mount Device Feature SMD1206C RoHS  Resettable over current and over temperature protection ● Low resistance  Small size of 1206 ● Fast time-to-trip  Small footprint ● RoHS complaint Application Part Numbering Product Dimensions in Millimeter A Part Number B C D E Min Max Min Max Min Max Min Min SMD1206-005C-60V 3.00 3.60 1.50 1.90 0.60 1.20 0.15 0.10 SMD1206-010C-60V 3.00 3.60 1.50 1.90 0.60 1.20 0.15 0.10 SMD1206-012C-60V 3.00 3.60 1.50 1.90 0.60 1.20 0.15 0.10 SMD1206-016C-33V 3.00 3.60 1.50 1.90 0.40 1.00 0.15 0.10 SMD1206-020C-30V 3.00 3.60 1.50 1.90 0.40 1.00 0.15 0.10 SMD1206-020C-48V 3.00 3.60 1.50 1.90 0.40 1.00 0.15 0.10 SMD1206-025C-48V 3.00 3.60 1.50 1.90 0.40 1.00 0.15 0.10 SMD1206-035C-16V 3.00 3.60 1.50 1.90 0.40 1.00 0.15 0.10 SMD1206-035C-30V 3.00 3.60 1.50 1.90 0.40 1.00 0.15 0.10 SMD1206-050C-8V 3.00 3.60 1.50 1.90 0.40 1.00 0.15 0.10 SMD1206-050C-16V 3.00 3.60 1.50 1.90 0.40 1.00 0.15 0.10 SMD1206-050C-30V 3.00 3.60 1.50 1.90 0.40 1.00 0.15 0.10 SMD1206-075C-8V 3.00 3.60 1.50 1.90 0.50 1.00 0.15 0.10 SMD1206-075C-16V 3.00 3.60 1.50 1.90 0.50 1.00 0.15 0.10 SMD1206-075C-30V 3.00 3.60 1.50 1.90 0.50 1.00 0.15 0.10 Polymer PTC Thermistor Specifications are subject to change without notice www.bnstar.net Version: 1.2 Document code:HB-WI7.3-358-2018 Effective date :2019-07-24 Page: 2 of 7 Surface-Mount Device SMD1206C RoHS SMD1206-100C-16V 3.00 3.60 1.50 1.90 0.50 1.00 0.15 0.10 SMD1206-100C-24V 3.00 3.60 1.50 1.90 0.50 1.00 0.15 0.10 SMD1206-110C-24V 3.00 3.60 1.50 1.90 0.50 1.00 0.15 0.10 SMD1206-150C-6V 3.00 3.60 1.50 1.90 0.50 1.00 0.15 0.10 SMD1206-150C-13.2V 3.00 3.60 1.50 1.90 0.80 1.60 0.15 0.10 SMD1206-200C-6V 3.00 3.60 1.50 1.90 0.70 1.30 0.15 0.10 SMD1206-200C-12V 3.00 3.60 1.50 1.90 0.70 1.30 0.15 0.10 SMD1206-200C-16V 3.00 3.60 1.50 1.90 0.70 1.60 0.15 0.10 SMD1206-260C-6V 3.00 3.60 1.50 1.90 1.00 1.60 0.15 0.10 SMD1206-300C-6V 3.00 3.60 1.50 1.90 1.00 1.60 0.15 0.10 SMD1206-350C-6V 3.00 3.60 1.50 1.90 1.00 1.60 0.15 0.10 Electrical Characteristics Part Number I(A) Vmax I max Pdtyp 25℃ -- -- -- Ttrip Rmin 25℃ R1max 25℃ Hold Trip (V) (A) (W) Current(A) (Ω) (Ω) SMD1206-005C-60V 0.05 0.15 60 40 0.4 0.25 1.50 3.60 50.0 SMD1206-010C-60V 0.10 0.25 60 40 0.4 0.50 1.00 1.60 15.0 SMD1206-012C-60V 0.12 0.29 60 40 0.4 0.50 1.00 1.60 13.0 SMD1206-016C-33V 0.16 0.37 33 40 0.4 1.00 0.30 1.00 6.00 SMD1206-020C-30V 0.20 0.46 30 40 0.6 8.00 0.10 0.35 2.70 SMD1206-020C-48V 0.20 0.46 48 40 0.6 8.00 0.10 0.35 2.70 SMD1206-025C-48V 0.25 0.50 48 40 0.6 8.00 0.10 0.35 2.50 SMD1206-035C-16V 0.35 0.75 16 40 0.6 8.00 0.10 0.25 1.50 SMD1206-035C-30V 0.35 0.75 30 40 0.6 8.00 0.10 0.25 1.30 SMD1206-050C-8V 0.50 1.00 8 100 0.6 8.00 0.10 0.15 0.70 SMD1206-050C-16V 0.50 1.00 16 100 0.6 8.00 0.10 0.15 0.70 SMD1206-050C-30V 0.50 1.00 30 40 0.6 8.00 0.10 0.15 0.70 SMD1206-075C-8V 0.75 1.50 8 100 0.6 8.00 0.20 0.09 0.50 SMD1206-075C-16V 0.75 1.50 16 100 0.6 8.00 0.20 0.09 0.50 SMD1206-075C-30V 0.75 1.50 30 40 0.6 8.00 0.20 0.09 0.50 SMD1206-100C-16V 1.00 1.80 16 100 0.6 8.00 0.30 0.05 0.27 SMD1206-100C-24V 1.00 1.80 24 40 0.6 8.00 0.30 0.05 0.27 SMD1206-110C-24V 1.10 2.20 24 40 0.6 8.00 0.30 0.04 0.25 Time(S) SMD1206-150C-6V 1.50 3.00 6 100 0.8 8.00 0.30 0.025 0.130 SMD1206-150C-13.2V 1.50 3.00 13.2 40 0.8 8.00 0.30 0.025 0.130 SMD1206-200C-6V 2.00 3.50 6 100 0.8 8.00 1.50 0.015 0.080 SMD1206-200C-12V 2.00 3.50 12 100 0.8 8.00 1.50 0.015 0.080 SMD1206-200C-16V 2.00 3.50 16 40 0.8 8.00 1.50 0.015 0.080 SMD1206-260C-6V 2.60 5.20 6 100 0.8 8.00 2.00 0.010 0.060 SMD1206-300C-6V 3.00 6.00 6 100 1.0 8.00 4.00 0.010 0.050 SMD1206-350C-6V 3.50 7.00 6 100 1.2 10.0 5.00 0.005 0.040 Polymer PTC Thermistor Specifications are subject to change without notice www.bnstar.net Version: 1.2 Document code:HB-WI7.3-358-2018 Effective date :2019-07-24 Page: 3 of 7 Surface-Mount Device SMD1206C RoHS IH=Hold current: maximum current at which the device will not trip at 25℃ still air reflow soldering of 260℃ for 20 sec. IT=Trip current: minimum current at which the device will always trip at 25℃ still air reflow soldering of 260℃ for 20 sec. Vmax=Maximum continuous voltage device can withstand without damage at rated current Imax=Maximum fault current device can withstand without damage at rated voltage. Ttrip=Maximum time to trip(s) at assigned current reflow soldering of 260℃ for 20 sec. Pdtyp=Typical power dissipation: typical amount of power dissipated by the device when in state air environment. Rmin= Minimum resistance of device in initial (un-soldered) state. R1max=Maximum resistance of device at 25℃ measured one hour after reflow soldering of 260℃ for 20 sec. " Value specified is determined by using the PWB with 0.030 *1.5oz copper traces. Caution: Operation beyond the specified rating may result in damage and possible arcing and flame. Environmental Specifications Test Test Conditions Accept /Reject Criteria Recommended storage conditions 40°C max, 70% R.H. max No change Passive aging: 85°C, 1000 hours ≤ R1max Moisture Resistance 85% RH,85℃,1000hrs ≤ R1max MIL-STD-202 Method 107G +85ºC /-40ºC 20 times MIL-STD-883C, Method 2007.1, Condition A ≤ R1max Thermal Shock Vibration No change Solvent Resistance MIL-STD-202, Method 215 No change Moisture Level Sensitivity Level 1, J-STD-020C No change Thermal Derating [ Hold Current (A) and Trip Current at Ambient Temperature (℃)] Maximum Ambient Operating Temperature (℃) Part Number SMD1206-005C SMD1206-010C SMD1206-012C SMD1206-016C SMD1206-020C SMD1206-025C SMD1206-035C SMD1206-050C Polymer PTC Thermistor -40 -20 0 25 40 50 60 70 85 Ihold 0.074 0.066 0.056 0.050 0.042 0.037 0.035 0.030 0.027 Itrip 0.148 0.132 0.112 0.100 0.084 0.074 0.070 0.060 0.054 Ihold 0.148 0.132 0.116 0.100 0.085 0.075 0.070 0.060 0.055 Itrip 0.296 0.264 0.232 0.200 0.170 0.150 0.140 0.120 0.110 Ihold 0.18 0.16 0.14 0.12 0.10 0.09 0.08 0.07 0.06 Itrip 0.36 0.32 0.28 0.24 0.20 0.18 0.16 0.14 0.12 Ihold 0.24 0.21 0.18 0.16 0.14 0.13 0.12 0.11 0.10 Itrip 0.48 0.42 0.36 0.32 0.28 0.26 0.24 0.22 0.20 Ihold 0.30 0.26 0.23 0.20 0.17 0.15 0.14 0.12 0.11 Itrip 0.60 0.52 0.46 0.40 0.34 0.30 0.28 0.24 0.22 Ihold 0.37 0.33 0.29 0.25 0.22 0.20 0.17 0.15 0.12 Itrip 0.74 0.66 0.58 0.50 0.44 0.40 0.34 0.30 0.24 Ihold 0.50 0.45 0.40 0.35 0.30 0.27 0.24 0.21 0.15 Itrip 1.00 0.90 0.80 0.70 0.60 0.54 0.48 0.42 0.30 Ihold 0.71 0.64 0.57 0.50 0.42 0.39 0.35 0.31 0.25 Itrip 1.42 1.28 1.14 1.00 0.84 0.78 0.70 0.62 0.50 Specifications are subject to change without notice www.bnstar.net Version: 1.2 Document code:HB-WI7.3-358-2018 Effective date :2019-07-24 Page: 4 of 7 Surface-Mount Device SMD1206-075C SMD1206-100C SMD1206-110C SMD1206-150C SMD1206-200C SMD1206-260C SMD1206-300C SMD1206-350C SMD1206C RoHS Ihold 1.14 1.01 0.88 0.75 0.65 0.59 0.54 0.49 0.41 Itrip 2.28 2.02 1.76 1.50 1.30 1.18 1.08 0.98 0.82 Ihold 1.45 1.31 1.15 1.00 0.84 0.77 0.69 0.61 0.48 Itrip 2.90 2.62 2.30 2.00 1.68 1.54 1.38 1.22 0.96 Ihold 1.60 1.45 1.30 1.10 0.95 0.80 0.72 0.66 0.55 Itrip 3.20 2.90 2.60 2.20 1.90 1.60 1.44 1.32 1.10 Ihold 2.18 1.94 1.72 1.50 1.28 1.17 1.06 0.96 0.77 Itrip 4.36 3.88 3.44 3.00 2.56 2.34 2.12 1.92 1.54 Ihold 2.88 2.63 2.34 2.00 1.74 1.58 1.42 1.17 0.93 Itrip 5.76 5.26 4.68 4.00 3.48 3.16 2.84 2.34 1.86 Ihold 3.43 3.22 2.93 2.60 2.23 2.03 1.87 1.57 1.35 Itrip 6.86 6.44 5.86 5.20 4.46 4.06 3.74 3.14 2.70 Ihold 4.05 3.66 3.36 3.00 2.50 2.28 2.00 1.62 1.38 Itrip 2.10 7.32 6.72 6.00 5.00 4.56 4.00 3.24 2.76 Ihold 4.65 4.22 3.92 3.50 2.92 2.68 2.35 1.91 1.42 Itrip 9.30 8.44 7.84 7.00 5.84 5.36 4.70 3.82 2.84 Solder Reflow Recommendation Recommended reflow methods:IR,hot air oven ,nitrogen oven Devices can be cleaned using standard industry methods and solvents. NOTE: If reflow temperatures exceed the recommended profile,devices may not meet the performance requirements. Caution: Operation beyond the rated voltage or current may result in rupture electrical arcing or flame Packaging Quantity and Marking Polymer PTC Thermistor Specifications are subject to change without notice www.bnstar.net Version: 1.2 Document code:HB-WI7.3-358-2018 Effective date :2019-07-24 Page: 5 of 7 Surface-Mount Device SMD1206C RoHS Device Marking Standard Quantity (pcs) SMD1206-005C-60V BZ 3500 SMD1206-010C-60V BN 3500 SMD1206-012C-60V BN 3500 SMD1206-016C-33V BT 3500 SMD1206-020C-30V BA 3500 SMD1206-020C-48V BA 3500 SMD1206-025C-48V BA 3500 SMD1206-035C-16V BB 3500 SMD1206-035C-30V BB 3500 SMD1206-050C-8V BF 3500 SMD1206-050C-16V BF 3500 SMD1206-050C-30V BF 3500 SMD1206-075C-16V BG 3500 SMD1206-075C-30V BG 3500 SMD1206-100C-16V BH 3500 SMD1206-100C-24V BH 3500 SMD1206-110C-24V BH 3500 SMD1206-150C-6V BI 3500 SMD1206-150C-6V BI 3500 SMD1206-150C-13.2V BI 3500 SMD1206-200C-6V BK 3500 SMD1206-200C-12V BK 3500 SMD1206-200C-16V BK 3500 SMD1206-260C-6V BO 3500 SMD1206-300C-6V BP 3500 SMD1206-350C-6V BV 3500 Tape Specifications:EIA-481-1(mm) Polymer PTC Thermistor Specifications are subject to change without notice www.bnstar.net Version: 1.2 Document code:HB-WI7.3-358-2018 Effective date :2019-07-24 Page: 6 of 7 Surface-Mount Device SMD1206C RoHS Governing SMD1206-005C-60V~ SMD1206-050C-30V~ SMD1206-100C-16V~ Specifications SMD1206-050C-16V SMD0805-075C-30V SMD1206-350C-6V W 8.0±0.3 8.0±0.3 8.0±0.3 F 3.5±0.05 3.5±0.05 3.5±0.05 E1 1.75±0.1 1.75±0.1 1.75±0.1 D0 1.55±0.05 1.55±0.05 1.55±0.05 D1 1.0±0.1 1.0±0.1 1.0±0.1 P0 4.0±0.1 4.0±0.1 4.0±0.1 P1 4.0±0.1 4.0±0.1 4.0±0.1 P2 2.0±0.05 2.0±0.05 2.0±0.05 A0 1.95±0.1 1.95±0.1 1.95±0.1 B0 3.65±0.1 3.65±0.1 3.65±0.1 T 0.2±0.1 0.2±0.1 0.2±0.1 K0 0.74±0.1 1.04±0.1 1.35±0.1 Leader min 390 390 390 160 Trailer min Reel Dimensions:EIA-481-1(mm) 160 160 Governing EIA481-1 Specifications C Φ178±1.0 D Φ60.2±0.5 H 11.0±0.5 W 9.0±1.5 NOTE: BNstar Co.,Ltd. makes no representations or warranties with respect to the accuracy or completeness of the contents of this publication and reserves the right to make changes to specifications and product descriptions at any time without notice. The products described in this document are not designed, intended, authorized or warranted for use as components in systems intended for surgical implant into the body, or in other applications intended to support or sustain life, or where malfunction of BNstar’s product may result in direct physical harm, injury, or death to a person or severe property or environmental damage. BNstar Co.,Ltd., reserves the right to discontinue or make changes to its products at any time without notice. Website: http://www.bnstar.net For additional information, please contact your local Sales Representative. ©Copyright 2006, BNstar Co.,Ltd. Polymer PTC Thermistor Specifications are subject to change without notice www.bnstar.net Version: 1.2 Document code:HB-WI7.3-358-2018 Effective date :2019-07-24 Page: 7 of 7 Surface-Mount Device SMD1206C RoHS Operation beyond the maximum ratings or improper use may result in device damage and possible electrical arcing and flame. The devices are intended for protection against occasional over-current or over temperature fault conditions and should not be used when repeated fault conditions or prolonged trip events are anticipated. Device performance can be impacted negatively if devices are handled in a manner inconsistent with recommended electronic, thermal, and mechanical procedures for electronic components. Contact information Rev. letter Date BNSTAR NEW MATERIALS CO., LTD. 130Meilong Road Shanghai, P.R.China Tel:86-021-64251576 Design Check Audit Approve Fax: 86-021-64250020 EMAIL:info@bnstar.net Polymer PTC Thermistor Specifications are subject to change without notice www.bnstar.net
SMD1206-200C-16V 价格&库存
很抱歉,暂时无法提供与“SMD1206-200C-16V”相匹配的价格&库存,您可以联系我们找货
