1N4007
1N4007
    SUNMATE(森美特)
    DO-41(DO-204AL)
    直流反向耐压(Vr):1kV 平均整流电流(Io):1A 正向压降(Vf):1V@1A 反向电流(Ir):5uA@1kV
1N4007 数据手册
1N4001 - 1N4007 AXIAL LEADED RECTIFIER DIODES VOLTAGE RANGE: 50 - 1000V CURRENT: 1.0 A Features ! ! ! ! ! Diffused Junction Low Forward Voltage Drop High Current Capability High Reliability High Surge Current Capability B A A Mechanical Data ! ! ! ! ! ! C D Case: D O - 4 1 Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.35 grams (approx.) Mounting Position: Any Marking: Type Number DO-41 Dim Min Max A 25.40 ¾ B 4.06 5.21 C 0.71 0.864 D 2.00 2.72 All Dimensions in mm Maximum Ratings and Electrical Characteristics TA = 25C unless otherwise specified Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Average Rectified Output Current (Note 1) @TA = 75°C Symbol 1N 4001 1N 4002 1N 4003 1N 4004 1N 4005 1N 4006 1N 4007 Unit VRRM VRWM VR 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V IO 1.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 30 A Forward Voltage @IF = 1.0A VFM 1.0 V @TA = 25°C @TA = 100°C IRM 5.0 50 µA Cj 15 pF RJA 50 K/W Tj -65 to +125 °C TSTG -65 to +150 °C Peak Reverse Current At Rated DC Blocking Voltage Typical Junction Capacitance (Note 2) Typical Thermal Resistance Junction to Ambient (Note 1) Operating Temperature Range Storage Temperature Range Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2. Measured at 1.0 MHz and Applied Reverse Voltage of 4.0V D.C. 1 of 2 www.sunmate.tw IF, INSTANTANEOUS FORWARD CURRENT (A) 10 1.0 0.1 Tj = 25ºC PULSE WIDTH = 300µs 2% DUTY CYCLE 0.01 0.6 0.8 1.0 1.2 1.4 1.6 VF, INSTANTANEOUS FORWARD VOLTAGE (V) Fig. 2 Typical Forward Characteristics 100 50 f = 1MHz 40 Cj, CAPACITANCE (pF) IFSM, PEAK FORWARD SURGE CURRENT (A) Tj = 25ºC 30 20 10 10 8.3ms Single half sine-wave JEDEC Method 0 1.0 1.0 10 1.0 100 10 100 NUMBER OF CYCLES AT 60 Hz VR, REVERSE VOLTAGE (V) Fig. 3 Max Non-Repetitive Peak Fwd Surge Current Fig. 4 Typical Junction Capacitance 2 of 2 www.sunmate.tw
1N4007 价格&库存
很抱歉,暂时无法提供与“1N4007”相匹配的价格&库存,您可以联系我们找货
1N4007
  • 50+0.14620
  • 500+0.11830
  • 1500+0.10281
  • 5000+0.08813
  • 25000+0.08013
  • 50000+0.07572
库存:138255
